Question about Sharp R-1481B Microwave Oven
Hood lights will not work everything else does ,tested bulbs
We have had the same problem with this microwave and have changed the bulb but that did not work. Did you ever find out what it was and if so how it was fixed?
Posted on Aug 14, 2006
    President:
  • 3,130 Answers
The problem is a bad light socket or the door switch. If you know how to do a continuity check with the power cable unplugged then thats what needs to be checked. Unplug microwave.. Take a meter lead insert it into the socket to the light bulb Follow that wire to where it goes as it should go to one of the switches on the door assy. Now these switchs can be tricky so be carefull when you check them as whith the door open theres a terminal that says N.O. that means normally open as when the doors open. The other lead should say on the door switch N.C., that means normally closed so you now that if the wire coming from the light bulb goes to a switch point on the door says N.C. the it shoud read a short from the light bulb socket to both the common and the N.O. side of the switch. If it dosent then the switch is bad. Now on a rare accation the socket itself is bad but thats easy to look at and see if its all corroded and stuff. If this dosent help lets us know and we can assit ya more and by all means if you dont know what im talking about PLEASE dont attempt to trouble shoot this as it could cause bodily harm!! Good Luck
Posted on May 31, 2006
THE STOVE TOP LIGHT ONDER THE MICROWAVE BLEW OUT. WHEN I REPLACED THE BULB BOTH LIGHTS NO NOT WORK.
Sounds like a power source issue from under the hood.
Unplug or turn off all power and take a closer look in there,. alternatively - this may sound crazy, but are you certain both bulbs are working by testing in another fixture??
Jan 05, 2011 | Sharp R-1480 Microwave Oven
The range-top light blew and now replacement bulbs
My Whirlpool/Roper microwave/hood combo has the same problem. I replaced the bulb twice, checked the bulb and it works, but not in the microwave. I wrote to Whirlpool asking about the problem. Haven't heard from them yet.
Apr 02, 2010 | Whirlpool MH1150XMQ Microwave Oven
The hood light blew and I replaced it. It worked
The cause could be anything from defective bulbs(least likely, to a bad bulb socket or vibration during operation. A voltage measurment at the bulb will tell you if it is getting too much.
Eric
Dec 24, 2009 | Microwave Ovens
Internal light does not come on
Relay RY1 on the control circuit board has probably failed.
It's the relay closest to connector CN1, the 7-pin connector.
Have you had trouble with the cooktop lights of hood vent exhaust fan recently?
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number 721.62644200) for more information & help or see our Web site.
William E. "Ed" Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Feb 14, 2009 | Kenmore 62622 Microwave Oven
GE Spacemaker XL1400 - lights underneith don't work.
Check power outlet and breaker , recock breaker .
Open oven fuse test both end , test power cord both, if those testing point okey , try plug power and test it .
Jan 17, 2008 | Samsung MW1030WA Microwave Oven
Hood lights do not turn off...
The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This is far less than a replacement circuit board, assuming it's even available anymore.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on.
We have full details and critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 15, 2007 | Sharp R-1481B Microwave Oven
Hood lights
first remove mains cord from main power. and remove the microwave oven top cover and check the bulb and crefully remove the old bulb and put new bulb. at high voltagae section dont touch any thing ,that area very dangerous ,thats why very carefully work inside the microwave oven ..
Sep 09, 2007 | Goldstar MV-1320W/B Microwave Oven
Light socket is dead on my Maytag
Yes, this is caused by not disconnecting the microwave from the power line when removing or installing a bulb or by the filaments shorting when the bulb blows. This is a problem with the control panel assembly, which we repair nationwide for $39.95. If you or a friend decide to send it to us, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Apr 01, 2007 | Maytag MMV4205 Microwave Oven
GE Microwave Surface Lights
The control circuits for the cooktop lights and the hood fan are spearate. The problem is indeed with the control unit. It's usually caused by either the filaments shorting when the lamp blows or by removing or installing the bulbs while the oven is still plugged into the power line. We regularly repair these nationwide for $32.50. Details of our service, as well as *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Hood Lights not working
The problem lies in the circuit board / control panel. We regularly repair these control panel assemblies nationwide for 32.50.
Oct 06, 2006 | Sharp R-1610 Microwave Oven
Sharp R-1481B Microwave Oven Logo
111 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
