Question about Durabrand WD810
In-Dash car cd player
My cd player when vehicle is started sometimes will be on with power but the cd will not activate it just sits there doing nothing.Also while the cd is playing it will skip and continue,or skip over and over,or it will stop playing for a short time then come back on.It also will just start scanning forward and or backward in a scramble type mode.The entire time the power is on and the unit is lit up.I have cleaned the player twice,moved the power source and adjusted the stereo angle.The problem has happened on 2 homemade cds and 1 factory cd.Can someone give me a solution please? Thanks!
  • 215 Answers
It sounds as if you've covered about as much as you can do without pulling it out and taking to the repair shop. Something you should definitely do if all this skipping is taking place whilst the car is stationary. A lot of earlier car CD players wouldn't accept the burn it yourself type disks and perhaps the factory CD was damaged. Try a few more factory CDs before you do anything else. Just because a disk plays on the Computer or cd Player in the house doesn't mean it will behave itself in the car. If you've has the unit for a while you could have the smear of grease they put on the worm drive gummed up with dust and this is stopping the disk carriage from moving freely. Or perhaps the heads are out of alignment due to constant vibration from rough roads. Either of these problems would mean a removal and either a clean or the repair shop. BMW
Posted on May 31, 2006
Reset computer in a 2008 impala
Have you driven the vehicle? Sometimes after battery replacement some of the dash lights illuminate but once the vehicle is driven they reset!
Dec 11, 2014 | 2008 Chevrolet Impala
CD issue and Battery Dies
Your cd changer is stuck in the read mode and drawing power. Sounds like you need to replace the cd changer before it overheats the wiring and starts a vehicle fire.
Feb 29, 2012 | 2009 Cadillac Escalade
Just installed the unit into vehicle and can not get tuner to lock onto any stations. Thoughtrs?
Sometimes the aerial connectors don't fit tightly and can come off when seating the radio into the cage, try pulling the radio and powering it when it's out of the dash and still connected.
Good luck
Oct 17, 2010 | JVC KD-R600 Car CD/ MP3 Player
Security feature problem on car cd deck
i have never seen a jvc that required a security code. it is possible that you may have a bad power or ground connection if lights are blinking off and on. sometimes when a deck has been sitting for a long time capacitors may dry out.
Apr 13, 2010 | JVC AM FM CD DET FACE CAR STEREO
CD player cuts in and out
Look on the catera forum.. I think I have the info correct that there is a relay under the dash that controls radio fog lights and other stuff.. the solders break thus getting dead zones. its a k34 dealer item. Grey bok under dash on driver side toward center of car!! check it out!
Dec 02, 2009 | Bose Car Audio & Video
Where is the cd player the radio says that there is no disk
Most cd players are in the main dash panel. If you do not have a cd slot, you likely don't have a cd player. These vans usually don't come with them and you have to install an aftermarket cd player.
If you have a cd disc changer, it is likely in the very rear of the vehicle.
Nov 17, 2009 | 2000 Ford Windstar
Sometimes when i start my car there is no sound. all of the options (radio, cd, dvd) seem to be working and i can switch between them, however there is no sound. i have to turn off the car and let it sit...
sometimes when i start my car there is no sound. all of the options (radio, cd, dvd) seem to be working and i can switch between them, however there is no sound. i have to turn off the car and let it sit for a few min. once that is done, i get sound again. is there a reboot option while the system is powered? and what else is there to check?
Jul 10, 2009 | Eclipse AVN5495 Car DVD Player
CD player wont come on was doing weird things
You have your accessory wire (red wire) and remote ran together and the yellow (constant wire ran separately in the dash?
You need the red wire to so you can use accessory and to turn off your cd player when your vehicle turns off.
You need the yellow wire to keep all your settings stored. base/treble/time clock
Just a little clarification. Your amp turns on with the remote wire (blue) wire, if that is not hooked up you will get no power to the amp.
Here's the in-dash diagram to your vehicle at the bottom of this pdf.
http://www.installdr.com/Harnesses/Ford-Wiring.pdf
You want to focus on N,O, and P
Do you happen to have an after market wiring harness? These can be bought from walmart for your vehicle. You just take the male end connect the colors together and plug end that goes to your cd player into the female end. Very easy to do.
Windshield wiper issue: http://www.allfordmustangs.com/forums/attachments/4-6l-tech/32492d1188791176-2003-mustang-fuse-box-diagram-2003-enginefuseblock01.pdf Check C1002, 1003, and 1004 under your hood.
You could also have one of these fuses out under your hood, that might cause you to lose power to everything.
http://www.allfordmustangs.com/forums/attachments/4-6l-tech/32493d1188791176-2003-mustang-fuse-box-diagram-2003-enginefuseblock02.pdf
Let me know if you need more assistance =)
Feb 01, 2009 | Kenwood KDC-MP238 CD Player
Mercedes benz ml320
Depending on the year of your ML, there are two types of CD players. The changer in the back of the vehicle or the single CD player, part of the stereo.
Rear mounted CD changer, disconnect power for several minutes, this can act as a reset and bring the changer back to working.
Dash mounted CD player, may have Nav too. Again, depending on the year of the vehicle, there are some players that require some modifications at the repair level. Bosch, one of the manufacturers to be specific, for these units.
Nov 06, 2008 | Car Audio & Video
Durabrand WD810 Logo
95 people viewed this question
Top Durabrand Car Audio & Video Experts
Steve Allison
Steve Allison
Mohamed Ismail
Mohamed Ismail
Are you a Durabrand Car Audio and Video Expert? Answer questions, earn points and help others
