Question about Panasonic NV-GS15 Mini DV Digital Camcorder
COPY FROM RECORDED TAPE TO PC
How to copy the recoded tape into my pc
Open movie maker software and press caputre button
Posted on Oct 25, 2008
Will this model record from the vhs tape to the dvd?
You don't state the manufacturer or model number in your question, thus we cannot answer. I will say that many do, but there is a caveat. If the the VHS tape is a commercially made movie, chances are it has copy protection on it. Most machines will sense this copy protection and will refuse to copy the protected VHS tape to DVD. This was done to prevent piracy. Home recorded tapes and non-protected tapes will usually work ok. Do not confuse write protection with copy protection however. Write protection is merely the tab on the tape that prevents re-recording of the tape. Copy protection is recorded right onto the tape itself and is read by the machine during playback.
Nov 19, 2015 | Televison & Video
Tip
Recods Recods or taps to MP3 File foremat
I have found a turntable called ION PROFILE Pro It connects to your USB connection and can rip your records or tapes to MP3 songs. It have an input for cassette tapes or 8 track tapes it also alows you to store them then in digital format. t can connec to 8 tracks cassentt tspes and has a plug in to plug into your sterero system and can paly records as well. You can connect it to your stero system and if yo have a mp3 device for your video recored you can recod music here as it has a volumr control as well. It uses software called aduacity that converts vinal taoe ti mp3's and ajudio converter that allows you to burn music in standard music format. This is an inexpensive set up and costs $79.00
on Aug 10, 2010 | Computers & Internet
Why won't the Sony controls let me click onto finalize using a Sony TV w/recoder to transfer VHS to DVD?
Is the VHS tape you are trying to record a commercial VHS tape (movie)? If so, it may have copy protection on it. The recorder is probably programmed to prevent you from making and using DVDs of commercial copy-protected VHS tapes.
Nov 13, 2015 | Zenith XBR716
How to dub tape to tape
Hi Dale,
You're kind of light on details of the equipment you're going to use - so the best I can do is provide generic instructions. You'll need two devices - one must be able to perform playback for source media and the other for recording or copying duties. Inspect the jacks provided on the rear of both units. Most provide standard RCA type "Phono" jacks for left and right audio channels. Connect a stereo patch cable (with plugs that match the jacks of the playback and recording devices) between the left and right OUTPUT (or "PLAY") jacks on the source device and the left and right INPUT (or "RECORD") jacks on the recording device. Insert the source tape, cd, album, etc. in the device that will playback the original and insert a high quality blank media into the device that will provide recording capabilities. Begin playing the source. Set options such as tape bias, Dolby Noise Reduction, etc. on both source and recording devices to match media in each. Advance the playback source to a point that contain the loudest sections. Set recoding levels by monitoring the VU meters on the recoding device and vary the input adjustment levels so that only the loudest prortions of the program just begin to briefly "flirt" with the 0Db or red zone of the meter. Signals that cause the meter to indicate into this area and beyond begin to overload the amount of information that can be recorded on the blank media and often result in muddy audio quality during playback, later. You should also record the same section repeatedly with differnt options (bias, noise reduction, etc.) to actually hear the difference to determine which sounds best to you. Once levels are set, queue the playback device and start recording. In the case of tape, allow enough recording time to let the leader section of the tape to pass beyond the recording heads for several seconds or more. Once the desired amount of silence has elapsed, play the source program. Allow it to run to completion using both sides in the case of tape and then playback the entire new recording to make sure it recorded without any issues.
Apr 09, 2015 | Televison & Video
My olympus vn-8100 flashed system error and stopped working
Ok, try this, works for me:
- Remove the batteries- Insert its again- Connect the recorder via usb to pc- Copy one by one each archive you need to recover, after copy delete them from the recorder- Copy SYSTEM, RECORDER AND MANUALS FOLDER to pc- Format from the pc the recorder (i use a mac - disk utility) yes it is, ERASE!- Copy again the folders: SYSTEM-RECORDER-MANUALS- Unplug the recorder, remove the batteries, insert again- Turn on the recorder, it will display a different error, format the recoder, it will restore and reset the systems files.- It works for me!-
Jan 10, 2012 | Olympus VN8100PC Voice Recorder
I have a scientific atlanta explorer 8300hd dvr that I want to offload the recordings to either an external hard drive or a pc or laptop''
The 8300DVR has a feature built in for outputting redcordings to a VCR. To output to a PC you will need a TVTuner card with RCA inputs. Pinnacle offers several products including a Hard Drive backup. You will follow these instructions below, the VCR will be your computer.
Copy a Recording to a VCR Tape
1. Connect the VCR to the OUT 2 connection on the back of the Explorer DVR.
See page 12 for more information.
2. Make sure that a tape is in your VCR and that the VCR is set to record.
3. Press List . The Recorded List
screen appears.
4. Press Move Up or Move Down
to highlight the recording you want
to copy to the VCR. Make sure to select
a program that is not currently being
recorded.
5. Press Select . The Recorded
Program Options screen appears.
6. Press Move Up to highlight “Copy
to VCR.”
7. Press Select . The Copy to VCR
screen appears.
8. Make sure your VCR is properly connected
to your DVR outputs, and press
Record on your VCR.
9. Press Start copy A . The recording
begins copying to VCR tape. The
Recorded List displays the VCR symbol
for the recording that is copying to
VCR.
Note: You can watch the copying in
progress through the PIP.
Mar 31, 2009 | Televison & Video
Mini cassette tape is wrapped around one spool inside the casette
1). Remove the five screws from top half of cassette shell. If the cassette shell halves are glued together, very carefully split the shell with a Phillips-head screwdriver. Maneuver the screwdriver around the shell to break its seal. Avoid getting cut or damaging internal components of cassette.
2).Carefully lift off the top half of the cassette shell.
3). Pull the head if the tape from the left reel.
4). cut-off the damaged edge, and attached a peice of sctoth tape to the shining side of the tape, and leave about 1/2 inches of scotch tape beyond the head of the recording tape.
5). trim the sctoch tape using single edge of the sctoch tape razor or X-Acto knife to the same width as the recording tape.
6). carefully insert and tape the head of the recording tape to the right reel. and manually wind the tape till the recoding tape is flat to the front of the recoding pad.
7). carefully close the top shell, make sure not to pinch the tape. use your finguer trun the right reel, make sure the tape winds freely.
8). secured the top with screws.
Nov 24, 2008 | Maxell 179030 Microcassette 3-Pack (60...
Toshiba tecra m3
The window sound recorder is not very good this purpose. You would need a sound recoder progam :
check this link:
http://www.sound-recorder.com/
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 19, 2008 | Toshiba Tecra M3 Notebook
IVE GOT A TOSHIBA RD-XV45KB VCR to DVD RECODER.
i too have the same error 03-56 the only way i have found around it is to use the really cheap basic -r discs from tesco
Feb 14, 2008 | Panasonic DVD-RV41 DVD Player
Panasonic NV-GS15 Mini DV Digital Camcorder Logo
66 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
