Question about Kodak EasyShare C315 Digital Camera
Camera dropped all writing on lcd screen is reversed
I was bumped and my kodak C315 was dropped. When I turned it on all the writing on the LCD screen was reversed. And when you got to take a picture if you think you need to go right you have to go left etc. I went on Kodak's website and it will cost $69.00 + shipping the camera only cost $80.00 plus it still takes pictures fine. Can I fix this myslf??
  • Anonymous Dec 04, 2008
    same thing for me. dropped it in london and the screen flipped on me!
These solutions are right. You need to take the camera apart and fiddle with the LCD ribbon that attaches to the motherboard. Take it out and put it back in. That did it for me!
Posted on Dec 06, 2007
Ok, I was having the same problem, and i found this post. I just now figured out how to fix it, thanks to Bmw and some of my own little techniques. 1) Take off the 6 screws holding the camera together. ( Be careful around the on/off switch ) 2) Hold the camera as if you were looking at the screen. 3) Tilt it slightly forward. 4) Blow under the Lcd screen. Done. I Had mine turned on when i did this, and it flipped the screen around right in front of my face. Hope this is not too late.
Posted on Aug 28, 2007
  • 215 Answers
Wow, this is one that I've never come across before. To fix it you'll have to bite the bullet and using great care and light fingers dismantle the case of the camera. Look for the flat piece of plastic with small lines in it which enters the LCD (this is the wiring) make sure the other end is correctly connected to the board. These flat ribbon cables connect to small blocks of plastic and are retained by either another piece of plastic which you carefully lever off both ends and this leaves the cable easy to remove. Whatever you do don't force that plastic keeper too far or it'll just snap one end. The other way they can be retained is by a small plastic flap which locks over the top of the cable. To release it you'll need a small fine bladed screwdriver or blade. Just slip it under the edge of the flap and pry upwards. When it clicks upright you can just remove the cable. Take a look at the cable and make sure it's not fractured anywhere and then reinsert in it's holder and close the retainer. Just check there aren't two flat ribbon cables connected to the LCD. If there is, check them both. The shock may have knocked one of these cables loose so check them carefully. You may find another one which looks out of center, remove and replace it the same way. It doesn'[t sound as if you've damaged anything too bad as you'd get nothing at all. But it's still a weird fault. I wish I had it on the bench. I'd love to know what caused it. Whatever you do treat everything with kid gloves. The innards are very fragile. And if you can get it all back together without ending up with a spare screw or two you've done very well. BMW
Posted on May 31, 2006
  • Stuart Bazley
    Stuart Bazley May 31, 2006
    Well I've spent the last hour on the phone trying to get an answer to this problem. I found out you are not alone and it's a rare problem. All I could get out of Kodak is "It sounds as if the LCD was put in the wrong way" HaHAhA If it was right in the first place I wonder how it got turned around. I think that's a typical manufacturer's answer of "I wouldn't have a clue"
    All I can say is if it's under warranty send it back. If it's not and you don't want to spend any money take the above course or simply transfer your photos to Photoshop and mirror flip them.
    I might add almost everyone I spoke to said "You're kidding"
    BMW
2 Suggested Answers
SOURCE:
PA8558
  • 28 Answers
SOURCE: Camera dropped all writing on lcd screen is reversed
These camera break very easy. If it was dropped, you are lucky it still takes pictures. I have dropped a few myself. I will cost you more to have it fixed and still there won't be any guarentees of operation. If it is new, take it back to the store and exchange it. Don't wait long. Some stores will only take it back up to 30 days. The company will replace it up to 90 days. It should say on the warrenty. It is best just to replace it if these other options are not available to you.
If this helps, please rate me. Thanks, Patty
Posted on Dec 30, 2007
Cracked screen cover on Kodak camera
screen protectors are only plastic covers that protects the screen from scratches and such.
It is not possible to buy a new LCD screen.
Since the camera is now Out of Warranty a repair will cost 48 pounds with KODAK.
In order to organise your repair or Trade up please Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 13, 2010 | Kodak EasyShare M1033 Digital Camera
Camera still takes pictures but LCD suddenly went dark. Battery works, camera turns on, camera was not dropped or damaged. LCD screen is intact. Time for new camera?
KODAK can repair this fault. However if OoW it will cost about 88 pounds. However KODAK offers a trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price.
Contact KODAK:
Nov 27, 2009 | Kodak EasyShare Z730 Digital Camera
KODAK eASYSHARE c530 BLACK SCREEN DOES NOT TAKE PICTURE
You may still be able to take pictures with your black screened Kodak camera. This problem occurs in the line of Kodak EasyShare digital camera models.
When you turn on your Kodak EasyShare digital camera, turn off the LiveView function. Take a picture using the small-windowed viewfinder (this is not the LCD screen). Also, try zooming in and out.
After taking a picture, review the picture to see if the picture has been taken. Then turn on LiveView and occasionally the LCD screen should no longer be showing a black screen.
Aug 31, 2008 | Kodak EasyShare C315 Digital Camera
Kodak CX7330. turns on but LCD screen is black and won't take a pic
It sounds like a bad connection on the ribbon cable of the LCD screen to the camera's motherboard. The fact that when you physically move the camera around and you can get the screen to then work, tells me something is loose inside.
- Jim
Jan 14, 2008 | Kodak EasyShare CX7330 Digital Camera
Dec 30, 2007 | Kodak EasyShare C875 Digital Camera
Picture is upside down and backwards
I have the same problem. How and where does this come from? My camera was sitting in the dock when I noticed the problem!!
Nov 26, 2007 | Kodak EasyShare C315 Digital Camera
My lcd screen is broken
you may be able to get the lcd screen from the parts dept. of Kodak but professional repair is highly encouraged
Nov 22, 2007 | Kodak EasyShare C315 Digital Camera
Lcd screen broken C530
I FOUND A GUY THAT USES NAME BRAND LCDS AND REPAIRS OR SELLS YOU THE LCDS NEW, AND THERE CHEAPER THEN ANYONE IVE FOUND, HE HAS REPAIR 3 FOR ME SO FAR. IF YOU CAN DO IT YOUR SELF YOU CAN SAVE 20-30 CAUSE THATS WHAT HIS LABOR COST IS PLUS FREE SHIPPING. http://j2agent.googlepages.com
Oct 27, 2007 | Kodak EasyShare C315 Digital Camera
Screen i broken
Yes it can be fixed.  Depending on where you live will depend on what you do next.  you can go to any phot repair shop and they will either have the part and can fix it there or they will need to send it out.
Either way, it'll be cheaper than buying a new camera.
Damaged LCD Screen
The following procedure works on the V1003. It uses the same LCD screen as the V803.
It would appear you have a damaged LCD screen. The same problem happened to my daughter's V803. The camera will take pictures fine but you will only be able to see them if you download them onto a PC. A replacement screen can be easily ordered and replaced. Call Eastman Kodak. Their parts department can be reached at (800) 431-7278 ext 3. Tell them the model number of your camera and tell them you want to order a LCD screen for it. The cost of the new screen is $31.00 + $15.00 shipping. Don't let them talk you into sending it back for repair. You are looking at a repair bill over $80.00. To replace the screen, remove all of the small philips head screws that are in the chrome band that runs around the center ridge of the camera. After removing the screws, you will be able to separate the rear half of the camera from the front half. The LCD screen is pressed into a rubber gasket in the rear half of the camera. You will see that there is a small, flat orange ribbon cable that connects the old LCD screen to a black connector on the camera's motherboard. Using a VERY small flat blade screw driver, pry up the top tab on black connector. This will unlock the connector and allow you to remove the flat ribbon cable from the black connector. Remember the orientation of the old screen and its cable as you will want to replaced the new screen and cable exactly the way the original was installed. Using the same small flat blade screw driver, pry out the old display. Install the new display into the rubber gasket into the back half of the camera. Insert the ribbon cable into the mother board's black connector and press down on the panel to lock the cable into place. Lay the rear half of the camera face down on the table (rear buttons facing down) and place the front half of the camera over top of the rear half. This will allow you to put the camera back together and help prevent the new LCD screen from falling back out. The LCD screen has pads attached to the surface behind it. When you reinstall the front half of the camera, those pads help hold the LCD screen in place with pressure from the motherboard. Replace all of the screws. If you did it correctly, the camera will operate like new. Last word of advice. Buy a padded hard shell case for this camera. These cameras are well known for LCD screen failures due to shocks and drops.
Good Luck!
- Jim
Aug 13, 2007 | Kodak EasyShare V1003 Digital Camera
Kodak EasyShare C315 Digital Camera Logo
107 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
