Question about Dell E771a 17" CRT Monitor
Can it be sorted
My monitor began started fickerin,then the screen display switched from 1024x768 to a shrink screen,with white lines running tru it..an turns on and off by itself while the green light is still on (dell e771a)...is there any help for me?..oh it was about 3feet away from my tele is that a problem 2?
  • Dell Master
  • 3,399 Answers
Its old and no monitor this old works.
its older than 2001 year. on or about.
its a vacuum tube CRT relic o f the past.
dump it.
it is a fire hazard this old (dust /lint and 17,000 volts are not friends)
this monitor has this magic I2C chip inside that scans for errors 24/7 if it seen things that can burn up the screen it shut down.
fixing it will cost 5 time the price of a nice LED flat screen used, 17"
why mess with relics?
CRTs are endsville.
the monitor if you attempt to use an ******* resolution of any kind
my reset it self to avoid screen burn, CRTs can burn up.
each maker handles this in a different way,
one shuts off
other just cut the electron beam (Z axis ) to ZERO black screen.
there call there design.
1024 x 768 at 75 Hz, is max.,.. for a fact. so say the manual
try 60 Hz, did you?
Posted on Jun 01, 2018
SOURCE: White screen
First, always try it on multiple types of computers (different video cards), and multiple cables. Then, open it up and make sure the internal connections are solid. Finally, consider putting in a new inverter. This has been known to fix all-black and all-white monitor problems.
Posted on Oct 08, 2007
SOURCE: Dell E172FP 17 monitor keeps blinking
That sounds like the backlight inverter board. Check ebay for the board or a repair kit for it.
Posted on Oct 23, 2007
SOURCE: Partial Screen Display
Problem in the LCD back panel board. check the interface unit or ADC unit, also check the video clock pulse. one section is not working.....
Posted on Feb 08, 2008
  • 1684 Answers
SOURCE: Dell monitor shows blank screen, green power light stays on
You have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of he monitor. If you aregood at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htmYou can take the back cover off your monitor and look for the bad parts,replace any that look like the pictues and your monitor should workfine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one thesame way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 03, 2009
yashrajsen
  • 61 Answers
SOURCE: When I set the resolution to 1280x1024, the
IF the screen is wider then try to change the settings from the monitor buttons. We change change the screen size , move it , change brightness,etc.
Posted on Jul 09, 2009
Can't get my Dell Precision M50 Laptop video to fill the screen at 1024 768 resolution. Video will only fill the screen when I set resolution to 1600 1200. Is there something wrong with my video card?
1024x768 is a native wide-screen resolution. more than likely your video card is fine and your notebook monitor does not support that format without shrinking the top and bottom which defeats the purpose of filling the whole screen. plug the kappy into an external widescreen monitor or TV and it will work at 1024x768.
Regards
Jun 06, 2010 | Dell Precision M50 Notebook
I have samsung syncmaster 740nw how can i increase screen resolution to 1024x768?
you cannot set the resolution to 1024x768 but instead try 1280x720 or if you have graphics card try to set the resolution using its custom resolution by setting 1280x768.
It will surely solve your problem.
-ravi
Dec 31, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
LCD monitor have Vertical lines and black colour become greenish
normally the 19" resolution can support up to 1280*1024, but if it comes with vertical lines in full screen, it might indicate the panel is no longer to work and probably it's time to replace new one.
Aug 12, 2009 | Neovo S 19 19 in. Flat Panel LCD Monitor
Black colour displaying become greenish and narrow vertical lines
Most LCD monitors have a default refresh rate of 60 Hz. Older monitors also have limited resolution. Please check your display settings and ensure you're not using a refresh rate higher than 60, or a resolution higher than what it supports. If either one is the case, you're lucky the LCD still works.
Aug 12, 2009 | Computers & Internet
Samsung 244t Monitor display issue
if the monitor will match well with Nvidia GTS8800 graphic card, you need to consider two issue:
1) resolution match from windows display property and moniter manu same one.
2) refresh frequency match from windows display property-->advance-->monitor and monitor manu--> refresh frequency
if two side setting could be all matched that you can use normally
if two side setting could not be matched any above step that you can not use some resolution normally possible.
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
May 29, 2009 | Samsung SyncMaster 244T 24" LCD Monitor
The shrinked screen with two white vertical line in the middle
B+ line going hi.
probably bad capacitor on hot's collector.
could also be leaky dual diode.
if non of above, look for swollen cap on main board.
Jul 12, 2008 | LG Studioworks 700S 17" CRT Monitor
PC or monitor, signal problems
your monitor is telling you it's on it's last legs..either that or your compaq has a bad video section. either is more vital than a video cable being loose.
Mar 10, 2008 | Computers & Internet
Cant get 1280x1024 when connected to laptop
the only way you may get it to work is if you use the monitor a secondary device and also use the notebook monitor as well. But the problem may also be the vga connector converting the signal, as you may have to have a DVI connection on your monitor to obtain widescreen resolutions.
May 28, 2007 | LG Flatron L1710B 17" LCD Monitor
Monitor has white lines an screen display shrunk
check that the cable between the computer and the monitor is still plugged in properly
Feb 05, 2018 | Dell E771a 17" CRT Monitor
Computers & Internet Logo
70 people viewed this question
Clive
Clive
Alun Cox
