Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWM 1003 Washer - Bellows Seal
How to replace the bellows seal
  • 5,911 Answers
The following link gives you step-by-step instructions on how to replace the bellow:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
I hope this helps you. Let me know if you have questions or require additional assistance.
Posted on Sep 14, 2008
Rubber seal and wire has come off the inside of my washer, how do you fix or do you need repair service?
Wire and bellows repair.Check to see if the rubber gasket bellows has a tear. If it loooks good the bellows goes over the front lip of the washer ,than place the wire that should have a spring attached over the lip. you will need a extra set oh hands to help hold the wire in place as you use to butterknifes to slde the spring over the lip.
Dec 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
With towels we get leaky front door like load is too heavy? does not happen with other loads whirlpool duet sport front loader washer 2 years old. new problem last two months.
Most likely cause is the door seal or proper name for part is door bellows where the door seal to the machine. Check for tears or rips inside the bellows and any cuts where the door meets the seal. The seal could also be pronated toward the inner tub too much just from wear. The seal would need to be replaced. Also make sure the door is locking. The reason it happens with the towels (heavy load) is b/c they put more pressure on the door making it easier to break the water tight seal. Please rate this post.
Dec 14, 2009 | Refrigerators
Leaking bellow for duet washer
Whirlpool sells a product called Silco-seal it is a high temperature adhesive for sealing tub hoses to tubs this can be purchased at an appliance store it sometimes works to seal a tear or, hole in a bellows
Jun 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How to replace the door bellows seal ?
The following link explains how to replace a door bellow:
Another method involves removing the washer top panel and working down through the top of the washer. The method I have described, offers the best open access, however. If you have questions along the way, please let me know. I hope you find this informaiton helpful.
May 11, 2009 | Whirlpool GHW9200L Front Load Washer
WFW 9400SW01
Go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=WFW+9400SW01
and click on your model number. In the new window click on a diagram in the left-hand side of the window to show the location of the bellows seals. I believe you want the Door and latch parts diagram.
Mar 23, 2009 | Whirlpool WFW9400S
Reinstalling whirlpool front load washer bellow
The easiest way to replace the bellows seal is remove the complete front panel.
This will really help: Duet front load washer repair manual
www.RepairClinic.com
Feb 03, 2009 | Whirlpool Washing Machines
Thank you for your advice on replacing washer bellows
Chuck Askew, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Chuck Askew), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 19, 2017 | Whirlpool Duet GHW9150P Front Load Washer
this is general for all door seals - all are much the same.
disconnect from mains. take lid off
prise off the clamp holding seal to cabinet - usually a wire circle with a spring - and peel seal off cabinet. fold seal back inside drum
seal is held onto lip of tub with what is really a giant hose clip. undo this and the seal will come away from tub.
on new seal, lubricate the slot in the seal that goes onto the lip of drum with washing up fluid.
starting at top, enter the slot in seal on lip of tub. work your way round in both directions pushing slot onto lip. this is the hard part and it may take more than one attempt.
when seal is on all the way round, replace the clamp.
refix seal to cabinet (easy to do) and refit outer clamp.
test for leaks on rinse as water level is higher
Nov 10, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
Door Bellows
ben it is very complex to replace
May 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I need some one to tell me how to install the rubber seal on a bosch maxx Eurowasher front loader washing machine. Part of the seal ripped off so water leaks out. Its only 6 months old and its not covered by warranty.
Jan 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
756 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
