Question about Dell Axim X5 Pocket PC
My DELL AXIM X5 CF SLOT not fuctioning
I've been at this one for a couple of years. My SD slot works fine but having trouble with CF slot. It doesn't read anything.
  • 35 Answers
Check the pins inside the slot. I had one that bent and the cards were no longer recognized
Posted on Aug 16, 2009
Axim x5 sd not reading
I would think it is having more trouble with the adapter than the actual card. It could also be the storage size of the card that is the problem as well. Try a regular 2GB SD Card and see if it works. If it does, then it is probably just the adapter.
Jan 01, 2009 | Dell Axim X5 Pocket PC
Can I use Standard 4G or 8G SD or Cf cards in a Dell Axim X5?
SD cards must be SD not SDHC, there is not an SDHC driver for the X5. You can find regular SD cards up to 4G.
CF is no problem, all flash based CF cards will work. Microdrives can be problematic.
Dec 20, 2008 | Dell Axim X5 Pocket PC
Sdio Wireless Lan Card Wlan 802.11b
The blank plastic is NOT to be used while other cards. I am assuming you are talking about the SD card slot on the side (black plastic filler) There should be no movement of the SD card when in place.
If you are talking about the CF card slot on the top of the Axim, again the blank plastic is a dust cover when no card is in place and is not used with cards inserted. There is a bit of open area on one side of the card. Carefull with the pins at the bottom and be sure to insert correctly. Again there should be no movement of the card once inserted fully.
Don't know what you are quoting from the manual. I still have mine and the only thing I see similar to your quote is to "align the tab on the back of the CF card with the notch in the CF slot.." This is to make sure you have the front and back correct and for removal of the card (by grasping the ridge/tab)
Jul 29, 2008 | Dell Axim X5 Pocket PC
Wireless compact flash card installation on dell axim 5
Go to Wal Mart and buy a 1 gig SD card----- and then buy a AmbiCom 54G wireless CF card. Works perfectly in my X5.
Oct 30, 2007 | Dell Axim X5 Pocket PC
Type 1 CF Cards
They will work. The only difference is the number of pins.
Sep 14, 2005 | Dell Axim X5 Pocket PC
Problems with SD Slot on Axim
I once used Mazingo on another pocket pc. I had it set to use the CF card in it. It did the same thing it's doing on yours now. It caused word to take a long time to open and it loaded the pages in it really slow. I stopped using it for that reason. I think it may just me the Mazingo program.
Help : Can I access Memorysticks on AXIM
Since a SD memory card is about the same size [width and thickness] as a Memory Stick, I doubt there will ever be an adapter available between these two formats. There just isn't any room unless they came up with a very large adapter which would stick out and be unwieldly. You can get Compact Flash adapters (which are much larger) from a company called Pretec for about US$59.00, plus I'm sure there are others. I use a full sized PC Card adapter on my laptop to convert between the SD Memory card for my Axim X5 and the SmartMedia card for my digital camera and MP3 player.
Sep 13, 2005 | Dell Axim X5 Pocket PC
SD/MMC Compatibility?
I'm not sure that this will be a once a for all answer, but the link below says that any device with an sd slot can handle mmc but devices with slots designed exclusively for MMC cannot handle SD. Since the axim has an SD slot, I would say that it is compatible with MMC although I haven't tried an MMC card and the manual doesn't specific mention MMC memory.
Is the Axim compatible with IBM 1 Gig MicroDrive? As this is the only way to put full length feature film onto the PocketPC platform. I know that the Axim has a type II Flashcard slot but want to make...
The advanced Axim appears to work fine with the 1GB Microdrive. Just appears as a "CF Card". MP3's etc play fine from it with no noticeable problems.
Dell Axim X5 Pocket PC Logo
145 people viewed this question
Alun Cox
