Question about Kodak EasyShare C340 Digital Camera
Not turning on
The camera was on my wrist and it hit the counter, making the batteries fly out. When i put them back in and turned it on the battery lid was not closing all the way and made the camera turn off, leaving the zoom lense stay stuck out. (it closes when i turn the camera off normally)
  • Ariel Huchro May 31, 2006
    it won't charge, let me see the images or anything. i taped the lid to the batteries closed and turned it on and it still won't turn on.
  • 215 Answers
Make sure you're putting the batteries back in the correct way. In the door should be a piece of metal which efectively shorts the top and bottom of each battery together (there's only 2 as you know) The act of closing the lid activates a small switch inside the camera. This is done by a small piece of plastic which pushes the switch when the door is closed. Have you broken the piece which holds the door? or the actual hinge? If it's the door locking mechanism the door should close in it's proper way but just won't stay locked. Putting tape over the door should make the camera work as long as it's fully closed and aligned as it used to be. If it's the hinge then the small piece of plastic which activates the switch may have broken off too. So the camera won't work until you replace complete door. What worries me is the fact that when you tried to get it going again the lens extended which obviously means you did indeed have power applied and the batteries were working. What I think may have happened is you've not only damaged the battery door but the lens assembly as well. Leaving the batteries out for a few hours and then trying again with a fully charged pair could retract the lens and by switching the camera back on it may work again (no guarantees though) If it does work again you'll have to get yourself a new door or simply use a piece of tape to hold it closed. BMW
Posted on May 31, 2006
    Scholar:
  • 116 Answers
Hello Ariel, You need a new battery lid. The problem is the lid has a pin that when closed properly, allows the battery to power up the camera. You can get one for $30.00 on Ebay item number 7623965577 if you act fast. This is a good camera and would be worth $30.00 (plus 5.50 shipping) to fix it. Please let me know how it works. Best regards, nightdiver
Nikon Coolpix S570 - Monitor freezes after pressing any button on the camera body.
The new battery may be really dead (discharged). Please leave battery out for a while and then put it back in and plug in the power plug. (Do NOT push any button on the camera) Make sure the camera CAN CHARGE the battery first. Typically one Green LED lights up and another one flashes. If it does this then WAIT until the battery is fully charged.
Apr 21, 2018 | Nikon Cameras
My watch only works when it is worn on wrist when it is off the wrist it stops i think the temperature of the body keeps it going and it is battery powered
Is it all digital (with a digital readout), or does it have two, or even three hands that point to the time?
May 12, 2017 | The Watches
Make a noise but wont turn on
What type of noise a click? Usually means starter motor not getting enough power to turn over, flay or low battery, or got stuck . Try hitting with a soft mallet. Or put car in gear and rock back and forward, as fly wheel movement may just loosen it off.
Mar 31, 2014 | 2006 Chevrolet Impala
Need help replacing battery in my nike Imara Womens watch? Which way does battery go in with plastic cradle?
1. Use a coin turn the battery hatch one-quarter turn counter-clockwise
2. Remove old battery from compartment. Keep plastic cradle and replate with 395/SW927R battery. Replace the new battery positive side facing up in the plastic cradle into the metal compartment in the watch. Ensure all three little tabs line up and twist cradle to lock into place. Make sure the O-ring is in proper placement on the cover and replace the battery hatch ensuring it is sealed completely!
Jan 28, 2010 | Nike Imara Run WR0075-014 Wrist Watch
Err message appears on the display of my D80.
This may be due to the aperture ring in your lens. Try the following:
1. Turn off your camera
2. Move the aperture ring clockwise then lock
3. Turn on your camera and try again.
If this does not work, do the same thing again but turn the aperture ring counter-clockwise.
Nov 08, 2009 | Nikon D80 Digital Camera with 18-135mm...
Camera Froze
maybe remove the batteries and try to turn it on .. than let it sit most of the day.-4 hours.. Then put the batteries back in and try to turn it back on.. Also check the lens cover and make sure its not stock...
Jul 17, 2009 | Samsung Digimax A503 Digital Camera
My camers keeps on asking me to "press the reset switch" and reseting does not seems to fix any problem for me.
I found the fix. It's so easy.
Take out the battery
When it says hit the reset button, hit the reset button.
Turn the camera to off
Wait 2 minutes
Put the battery back in.
Turn on the camera. It won't say reset anymore.
Jun 30, 2009 | Panasonic Palmcorder PV-GS9 Mini DV...
It dosent turn on
i have the same problem. i bought new rechargeable batteries and they went dead really fast and then i put some new batteries in and i took like 5 pics and then the battery indicator said the battery is low. i dont get it whats going on with this camera.
Jan 05, 2009 | Kodak EASYSHARE Z1285 Digital Camera
Will not turn on
I had this same problem with my camera a few years back and took it into a camera store to get it fixed. It turned out that it was just the batteries I was using. You cant use regular AA batteries for this camera because they give too much power. If you just go to a walmart or target or anywhere like that, you can get AA camera batteries and that SHOULD solve the problem. let me know if that works.
Sep 14, 2008 | Sony Cyber-Shot DSC-S60 Digital Camera
Samsung S500 beeps and turns off when i hit shutter
If the Olympus is using the exact same batteries as the Canon, there is a high chance that the problem is with the batteries.
Dec 13, 2007 | Samsung Digimax S500 Digital Camera
Kodak EasyShare C340 Digital Camera Logo
165 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
