Question about Dell 1700n Laser Printer
All lights are on solid, printer won't start/work at all
Hi
Yesterday I switched on my dell 1700n after not being used for several months.
All the status lights (I mean every one) come on and stay on. They don't flash.
The printer won't do anything.
I assume it's a fatal logic board error, but can anyone clarify.
I'm was also having the paper jamming in a fan at the back "hatch". Can this be fixed also?
Thanks
Darrin Smith
  • 624 Answers
SOURCE: Dell 1700n Laser Printer paper jams
Some questions first: -Where in the paper path is it jamming? -Is it always in the same spot or does it vary? -Roughly how many pages have you printed with this printer? -Did anything lead up to this or has it progressively gotten worse?
Posted on Feb 21, 2007
SOURCE: Dell 1700n Laser Printer Jam trouble
Remove the image drum and at the front of the printer you will see a rectangle flap that lifts up. Under the flap are three rollers. Clean them and it should take care of the problem. I use a product call Caikleen, it is a rubber cleaner and rejuvinator.
Posted on May 22, 2007
SOURCE: My dell 1700n Laser Printer Paper Jam Light stays on
Had the same issue with the "Paper Jam" light blinking... but no paper jam. Turned the printer off then back on and the light went out.
Posted on Sep 05, 2007
SOURCE: Dell 1700n Jamming
Rotating the rubber worked perfecty, thanks!
Posted on Sep 02, 2008
frankzjm
  • 191 Answers
SOURCE: Dell 1110 Laser Printer Solid red warning light
Hi in this case the paper jam made some sensor through the paper road they are not in normal position or still tigger on by piece of something or error stander. you may try:
1) check paper input sensor near paper tray roller\
2) check margin sensor inside paper way before drum unit
3) check fuser sensor near fuser unit
4) check paper output sensor near output tray roller
sometime need sensor adjustment back to normal position
Posted on Dec 22, 2008
Started out with paper, would start to load paper them as soon as paper stared in would stop. After several tries it would work. Then it stoped taking paper at all. Each time you try to print it stops and...
First I would remove the paper tray and check the rollers and print path for any scraps of paper that may be tripping up a sensor. If all seems well, ...
Try this next: It will reset the printer's configuration info.
To factory reset your Dell 1700 series printer follow these steps.
  1. Turn off your printer
  2. Open the front cover (push the button on the left side)
  3. Hold down the "Continue" and "Cancel" buttons and turn the power back on.
  4. When the "Error LED" light on the control panel is solid, close the cover and release the "Continue" and "Cancel" buttons.
Tip: To print a configuration sheet push the "Continue" button twice. This will give your printers IP Address.
Dec 31, 2010 | Dell 1700n Laser Printer
My Dell 1700n Printer keeps showing up as offline. I have a Dell Optiplex GX520 PC. My printer has been working fine, I moved the printer to a new PC temporarily and then moved it back to my PC and now...
hi
i suggest you reinstall the drivers on the computer(s) which will use the Dell 1700n printer.
let me know if this helps
if you need the drivers go to this link all you have to do is select the operating system (go to My Computer, right click and properties, will give you the OS)
http://support.dell.com/support/downloads/driverslist.aspx?c=ca&cs=cadhs1&l=en&s=dhs&ServiceTag=&SystemID=PRN_LSR_1700N&os=WW1&osl=en&catid=&impid=
Nov 03, 2010 | Dell 1700n Laser Printer
HP 1700n laser printer. Won't reset.
Hi, first; lets’ start from scratch. Turn off your (Computer), turn off the (Printer), unplug the printer from the power outlet; do not make any changes to the computer. Disconnect (all) the printer cables from the computer; reconnect the cables to the computer, and plug in to power outlet. Turn on the computer (first), turn on the printer. Go to; Control Panel, (Hardware and Sound), click Printer; if the Printer is present; click to open, Properties, click (Drivers): Update Drivers. Restart computer. Thanks paul7of9
Jan 12, 2010 | Dell 1700n Laser Printer
Dell 1700n error light after print job.
double pressing the continue button twice , the printer will give a secondary error code: then check here (link below) : toner is low, with blinking lights = Replacing the Imaging Drum
http://support.dell.com/support/edocs/systems/1700n/en/index.htm
download the manual above and look under Troubleshooting->Maintenance for your printer-> replace imaging drum...
good fortune, please leave rating...
May 11, 2009 | Dell 1700n Laser Printer
Error light stays on
Clear the Error Log: a. Turn the printer off. b. Open the front cover. c. Hold down both buttons while powering on. d. Release the buttons when the error light stays on solid. e. Close the front cover.
Mar 20, 2009 | Dell 1700n Laser Printer
Paper jam light is on with no sign of a jam printer wont print.
1-paper is most likely stuck in the fuser, (where it exits and gets hot) you will have to remove it
2-it would be better to clean the rollers w/ alcohol then inside out.
Oct 09, 2008 | Dell 1700n Laser Printer
DELL Laser printer 1700/1700n
All flashing lights for the Dell 1700 series (1700, 1710, 1720 including those that have n or dn as part of the model) printers is a service related error. When double pressing the continue button twice quickly, the printer will give a secondary error code, narrowing down the printer part being effected. It is possible to even narrow the error code down even futher by double pressing the continue button and taking note of which combination of lights come on, wether they are steady or blinking. Most generally when this series of printers, when you get all flashing lights, something major is going on with the printer. It could be pointing to the fuser, or main board, etc. You can call dell warranty support and they will help narrow down which part is being effected. Most generally, what is being effected is not cost effective to get fixed if you are no longer under warranty.
Sep 18, 2008 | Dell 1700n Laser Printer
Light blinking
The Controller card is faulty
Sep 01, 2008 | Dell 1700n Laser Printer
Dell 1710
If that is the only light:
Remove the toner cartridge and firmly shake it from side-to-side and front-to-back several to use the
remaining toner, and then reinsert it and continue printing. Repeat this procedure multiple times until
the print remains faded. When the print remains faded, replace the toner cartridge
If not let me know.
Nov 16, 2007 | Dell 1700n Laser Printer
Feb 20, 2007 | Dell 1700n Laser Printer
Dell 1700n Laser Printer Logo
53 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
