Question about Magellan SporTrak Color GPS Receiver
MAGELLAN SPORTRAK COLOR DISPLAY REPLACEMENT
I ran over my sportrak color and the LCD is shattered. Does anyone know where I can buy a replacement display. Does anyone know how to take the case apart. Even with the 4 screws removed there appears to be something at the bottom end holding it together.
Whats up rjallan?
There is 6 screws holding it togather, the bottom two are under the rubber under where the batteries go. You also have to pull the plugs out. By the way I have a screen for you. I have 3 demo nits so i cant program them to use. But the screens are good.Email me your address and I will send you the screen in the mail. My email address is erik_jacobson2007@yahoo.com.
Let me know
Erik
Posted on May 29, 2009
Can you tell me where I can find a "keyboard use
Hi!
You'll have to go to the Legacy products link:
http://www1.magellangps.com/support/obsoleteProducts.asp
Scroll down until you see your unit model and click on the link. I'm not sure if you have the SporTrak Color (North America) OR the SporTrak Nort America (Blue) unit. Either way, click on your model and you'll be good to go! The ENTIRE manual is available (.pdf) but requires you to download the manual in two parts. (English Part 1 is second from the top of the page, Part 2 is eleventh from the top)
Good Luck!
Jan 23, 2011 | Magellan SporTrak Color GPS Receiver
Problem with SporTrak pro connection to PC
are you able to sync it with laptop or not?
is your laptop detecting the device first?
Jul 01, 2008 | Magellan SporTrak Color GPS Receiver
Sportrak color pc connection problems
It could be the setting on your gps or the cable could go bad. (Mine did) To test the cable - Instructions from Magellan FAQS - With PC data cable still connected to the unit power ON the unit and press both the ?Power? and ?Zoom Out? buttons at the same time and hold them down for two seconds. The following message appears: ?Test Serial Port Press Enter?. Do not press the ?Enter? button yet. Next, use the paper clip or jumper wire and insert the ends to Pin #2and #3. Pin #2 is the NMEA Positive (TX+) Transmitter; #Pin 3 is the DBR Positive (RX+) Receiver. While performing the cable test you will see a series of check points in each individual Baud Rate point. 1200, 4800, 9600, and 19200. Each point should display the message ?OK?at the bottom. If the user sees the initials ?NG? (NO GOOD) perform the test again. If the test continues to display the message ?NG? the problem may be due to a bad cable. When the cable test is finished press the ?Power Key? to power off the unit.
Sportrak pro does not turn on
Did you manage to fix it? If not, do you want to sell the dead unit for parts?
May 23, 2008 | Magellan SporTrak Color GPS Receiver
Magellan SporTrak
As far as I know you can only get parts from magellan. The lenses are usually part of the display screen assembly in order to prevent condensation between the lense and the screen.  It is probably seald to the screen and may not be easy to replace.
Jul 29, 2007 | Magellan eXplorist 200 GPS Receiver
Owners/Operators Manual for Magellan SporTrak Pro
Here you go!!! :-D http://www.magellangps.com/assets/manuals/SporTrak_series_en.pdf please give feedback! thanks! hope this helps you!
Jul 26, 2007 | Magellan SporTrak Pro GPS Receiver
Magellan SporTrak Color GPS Receiver Logo
250 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
