Question about Vodavi Starplus DHS 7312 Enhanced Phone
Only 1 phone rings
Seems that, systematically, our phones have stopped ringing - well, all but one. the phones are otherwise operational. we have 2 executive phones and 4 enhanced phones. Only 1 executive phone rings now. I keep thinking it's a programming issue, but maybe a power outage/surge happened. I just don't know.
  • zooba7 Dec 27, 2008
    Had the same problem-got a UPS but we are still losing the programming overnight every 6 or 7 days???
    Novelist:
  • 201 Answers
There is a small battery inside your main control unit that keeps programming in memory during a power outage. The life of the battery is about 5 years give or take. When the system goes down for an extended period (or possibly several quick on/off cycles) your programming will be wiped out. By default, only a few telephones will ring. The battery is most likely a small blue 3-cell battery soldered right on the main board. It's not easily replaced. You can get a technician to replace it or hook up a standard battery backup unit (UPS) made for a computer. Your phone system uses less power than a computer so it can use any UPS and will last longer than advertised. Hard to say exactly how long. Just don't re-program the system until you take care of the problem or it will just default on you again.
Posted on Jul 05, 2007
I cannot find how to set the number of Ring Count on my phone AND How do I set my personal Greeting for the answering machine? I've tried for 3 weeks using my 'operating instructions manual'
The manuals can be overwhelming. The KX-TGC210
manual obtained from www.manualslib.com has the
Answering System details beginning on page 29.
==============pg 29================
To summarize, "Recording your greeting message:"
press [menu] # 3 0 2
scroll to "Yes" press [select]
phone will (beep) [[ speak your message ]]
press [ stop ]
press [ off ]
==============pg 32================
To summarize, "Number of rings ..." (Ring count):
press [menu] # 2 1 1
scroll to ((your desired number of rings)) press [select]
press [ save ]
press [ off ]
May 21, 2016 | Panasonic Lands Phones
Phone doesn't ring
seems like since it was refurbished, it night of finally decided it was time to stop working, unfortunately tried to see if there was support for this model there is none.
Aug 13, 2014 | Toshiba EKT-6510S Speaker Phone Charcoal /...
I can make calls but phone doe not ring
You said "it seems to ring once then stops." One possible cause of what you're describing is called a "Ring Trip." It is characterized when the button that flashes to indicate an incoming call changes to steady red (which would normally indicate the call is answered) although no one actually answered the call. If that occurs, then you have to test to see whether you can tell where the problem is coming from. If you unplug all the phones, you can then call in (from a cell phone or other phone that's not part of the system) and see if the incoming call rings unanswered, as it should when no phones are attached. If all rings in OK, plug just one phone in at a time and call in to see if any particular phone causes the problem. If one causes the ring trip, then disconnect that broken phone. If ringing still stops when no phones are attached, you'll have to disconnect the phones' connection wires (Station Wires) at the phone system box that plug into the "Station Ports" (label them before you unplug any!). Do not unplug the plugs for the wires that feed phone company lines into the phone system, the jacks are called CO line ports. With the "Station" wires unplugged, see if If all rings in OK by calling in from a cell phone or other phone that's not part of the system. If all rings in OK, plug just one station wire in at a time to see if one causes the problem. If one station wire causes the ring trip, then disconnect that troublesome wire and inspect its "system box jack" and its phone jack for water damage, carpet cleaning solvent, exterminator spray or any other corrosive liquid damage. Sometimes a staple through a wire where there's humidity can cause the problem. This process will find the offending wire, jack or phone that causes a "Ring Trip." There are many other possibilities, but the extremely limited description you've provided "it seems to ring once then stops." doesn't help me send you a better answer yet.
Jun 27, 2014 | Panasonic KX-T7730 Corded Phone
How do I stop all phones ringing when a specific line rings with a Norstar M7310
Normally tech side programming
If you do not know how to program, navigate or the password call a tech.
otherwise go to Sets/Ext#/Line Access/Line Assignment, enter line # in question, press Change until you see the option you want ie.e appear only or not assigned.
Oct 20, 2012 | NorStar Meridian M7310 Phone
How do i set the digital messaging system to ring less times before it answers?
in many phones auto answer function is awailable. otherwise go to menu, thereis an option for TAM ring activation minimum is 2. if there arent any messages it starts on 4 rings.
Jul 08, 2009 | Panasonic KX-TG2313 Cordless Phone
How to access messages remotely
While you are away from your home or
office, you can use a touch-tone phone,
or a pulse (rotary) phone with a pocket
tone dialer (available through your local
RadioShack store) to enter your PIN and
do any of the following:
• set the phone to answer or not
answer calls
• listen to your messages
• record a new outgoing message
• erase messages
• monitor the room where the phone
is located
Notes:
• You cannot remotely operate the
phone using its handset or another
telephone on the same line as the
phone.
• You can also listen to the message
recorded on Line 2 by making a call
to Line 1’s number (or vice versa).
USING THE TOLL-SAVER
If RING TIME is set to TS (toll-saver),
(see “Setting the Number of Rings” on
Page 15), the phone answers after three
rings if you have new messages (ones
you have not listened to). If there are no
new messages, the phone answers after
five rings. This gives you time to hang
up before the phone answers so you
can avoid unnecessary long-distance
charges.
Note: Toll-saver works only on the line
you called. If Line 1 has no new messages,
but Line 2 has one, the telephone
answers after five rings when you
call Line 1.
USING REMOTE
COMMANDS
Follow these steps to operate the phone
from a remote location.
Note: If you wait more than 15 seconds
between keypresses, the phone sounds
a long beep and hangs up.
1. Dial your phone number and wait for
the phone to answer.
2. If the phone is not set to answer
calls, it answers after about 10 rings
and sounds a series of beeps.
3. When the outgoing message begins
(or the phone sounds a series of
beeps), press #, then enter your PIN
within 2 seconds.
If the PIN is correct, the phone announces
the day and time, then it announces
the number of new and old messages.
The phone plays all new messages,
then beeps about every two seconds to
let you know it is ready to accept remote
commands.
Notes:
• If the phone does not respond, try
entering your PIN again. If you enter
an incorrect PIN three times, the
phone beeps and hangs up.
Remote Operation 27
• When the phone is operating from a remote location, it stops all answering functions
and rC appears on the display on the base. The phone resumes answering
functions when it is no longer in remote operation, if you have not turned it off.
• The remote playback of incoming messages is limited to 4 minutes. If you have
more messages after 4 minutes have passed, you must press # 2 again to listen
to the rest of the messages.
• When using remote operation, you can only delete the current message during
playback. You cannot delete all the messages stored at one time.
The following table shows the remote commands you can use.
Note: Remote operation stops when someone picks up the handset and presses either
LINE 1 or LINE 2 (whichever is flashing), or any phone on the same phone line.
Remote Commands
Press #
then (within
2 seconds:
Function
Repeat current message during playback.
2 Play messages.
3 Skip current message during playback.
4 Delete current message during playback.
5 Stop playback, recording, and room monitoring.
6 Set the phone to answer or not answer calls.
7 Record or stop recording a new outgoing message.
8 Play the outgoing message.
9 Switch to the other line (Line 1 or Line 2).
0 Monitor the room where the phone is located for 15 seconds
Mar 19, 2009 | Lands Phones
Lucent Partner 18D - stop ringing of line 2 at phone
From extension 10 or 11
Press feature 00
Left intercom
Left intercom
right intercom
enter your extension number
all lines that are programmed on your phone will light up.
Solid means immediate ring. Slow flash means delayed ring. Really fast flash means no ring.
Press the line you wish to not ring, 2 times.
Feature 00 when you are done.
Oct 14, 2008 | Lucent PARTNER18 Corded Phone
How can I change the number of rings?
Not sure what you are asking. Are you saying your phone only rings twice before going to voicemail?
Mar 27, 2008 | NorStar M7310 Corded Phone
Intermittent Ring
Sounds like you are having a problem with the generated ring signal from the cable phone service. An old fashioned Ma-Bell ring signal is a pure 90v AC 30hz pulse. Your cable box needs to generate a simulated ring signal from a DC power supply. I have seen many examples of this fake ring signal not cooperating with specific phones. It's a long shot but your phones MAY have a setting for the phone line(s) (A/B) (Analog/Digital) etc... of you can find a setting dealing with the "CO line", "phone line" etc.. try changing it. I am surprised another phone in the loop will help the ring signal at all. I would think it could only weaken it. Try plugging your phone in question directly into the cable line instead of having the whole house connected. The ring signal may be trying to power too many devices or weakened by something connected to the network. Other than that, you are dealing with the ring signal generated by the equipment and I'm sure it's not adjustable.
Jun 26, 2007 | GE 21028GE3 Cordless Phone
Lands Phones Logo
268 people viewed this question
Top Vodavi Lands Phones Experts
Oloyede Monsuru
ray gallant
vince
Are you a Vodavi Lands Phone Expert? Answer questions, earn points and help others
