Question about Kodak EasyShare DX7440 Digital Camera
No pictures when SD disk is out of camera
I can take pictures on the SD disk but when I take it out the pictures are not there. It says no images found. Also when I turn on the camera without a disk in it the message Memory card requires formatting That is with no memory care in it. It will not let me cancel out of that screen. It goes away if I put a disk in. Help I have pictures I cant do anything with.
  • 215 Answers
Before you do anything else find a friend who's camera takes the same memory card and try it in their camera. If it doesn't work there try cleaning the contacts gently with a pencil eraser (make sure you remove any rubber pieces left behind) There is a locking mechanism on the side of the SD card. Make sure this isn't locked. If everything still fails it looks like you could have a faulty SD card. Borrow one to try to see if the fault in the camera disappears. This camera has 32 MB of internal memory. Are you sure your pictures aren't being stored there. Read your manual and you can find out how to transfer them to the SD card once you've proved the card is working. Also check your SD card in a card reader and if there's still any problems pop it back into the camera and format it. BMW
Posted on Jul 02, 2006
I have a Nikon D5300. I can see the photo count number increasing, but I cannot view the images and they are not going on the SD card. Where are they? The SD card is not full.
many small Nikon cameras have memory to store images ON THE CAMERA. If you have a memory card installed that the CAMERA CAN READ it will put images on the card. if the memory card is corrupted the camera will not use it.
First Backup all IMAGES on Memory Card to COMPUTER make sure you saved ALL images. This is IMPORTANT.
After you SAVED all images you PUT Memory card back in camera and FORMAT it (Format is in TOOL Menu that looks like a wrench)
Now if you can take an images and it saves to memory card you are done. To see if they go to MEMORY CARD. Turn off camera and remove MEMORY CARD and Check.
If it STILL does not work you may have a defective memory card.
Feb 23, 2017 | Nikon Cameras
How do i get internal pictures off my panasonic Lumix DMC-LZ3
If you take the memory card out of the camera, you can view the internal pictures one by one, and delete them, or transfer them to you computer through the cable...they will show up as another drive in Computer, or My Computer, depending on which version of Windows you are running.
Good luck, and hope this helps.
May 03, 2011 | Cameras
Can't put pictures on the camera
you can do something
1.take picture in camera .
2.copy the of the picture .
3.go to the picture you want to put in camera .
4.past the name on the picture.
5.change the dimensions of the picture to 3264x2448 or 2448x3264
6.then put the picture in camera (sd card)
its work with me
Jul 26, 2009 | Fuji FinePix J10 Digital Camera
Lost images
plug your SD memory card directly into the computer your photos should still be on them unless your daughter chose the option to delete the originals.  There is no hard drive in the camera.
Apr 01, 2009 | Canon PowerShot SX10 IS Digital Camera
Copy images from pc to Lumix TZ5 SD memory card?
yes i m sure it would work if you use a card reader instead of using the camera directly connected.. in that case your memory card will just work as the usb hard drive and you can load anything into it..
Dec 27, 2008 | Panasonic Lumix DMC-TZ50 Digital Camera
I have a canon powershot digital elph. I recently got back from a trip and took my SD card and put it into my laptop and viewed the pictures on my computer. Then I copied and pasted the pictures from my...
Sounds like you are not tackling this the right way.
The proper way is to connect your camera using a USB to mini-D connector direct to the laptop. Use the Import facility to transfer the images to a folder.
Failing that, you don't Copy and Paste, you Right Click Drag.
Insert the SD Card into the laptop slot or a Card Reader to USB. Open File Explorer. Click on the SD card at the bottom of the left hand pane. Highlight the images you want in the right pane, either individually, or multiple (hold down CTRL key, click each one, or hold down SHIFT key, click beginning of block and then end of block of images). Now the clever stuff, Right Click and Drag the images to the folder on the left of the two panes, release the Right Click and choose Copy Here, or Move Here.
I would transfer all the images to your laptop, Format the SD Card in the Camera, and then transfer any images back to the camera if you need, but really, the SD card should be for capturing the images and the computer hard drive for storage, plus backups to Memory Sticks or External Hard Drive.
You can also try using Windows to Repair the Drive (SD Card). Right Click on the SD Card, Properties, Tools, Check for Errors.
Mar 27, 2017 | Cameras
How to use a minolta dimage g500 camera
Do you mean the memory card in your camera or do you mean another device?
First check that your memory card works in another device. There is a lock button on the SD card that needs to be unlocked.
Second, check that your camera settings have the SD card option selected. You can select the destination of your images.
Nov 03, 2007 | Konica Minolta DiMAGE G500 Digital Camera
Where does Lumix® digital camera store the pictures I take?
Unlike 35mm cameras that store images on film, Lumix® Digital Cameras store images on SD Memory Cards, which make sharing and storing your pictures easy and convenient. You simply insert an SD Memory Card into the camera, take pictures until the card is full, and then you can transfer the pictures onto a compatible PC. Once you saved all your pictures, you can erase the card and start all over again.
Aug 30, 2005 | Panasonic Lumix DMC-FX2 Digital Camera
Aug 30, 2005 | Panasonic Lumix DMC-FX1 Digital Camera
Aug 30, 2005 | Panasonic Lumix DMC-F7 Digital Camera
Kodak EasyShare DX7440 Digital Camera Logo
83 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
