Question about PC Chips M925G (M925G V9.1B) Motherboard
I cant find a wireless point for my laptop....
    Problem Solver:
  • 38 Answers
You are going to need a wireless box to do this!
Posted on Sep 14, 2008
Hi, i cant connect my new acer laptop to internet, using wireless
you need to be near a wireless router or wireless access point to connect. also need the wep or wpa(?) security code as well. you need to know if you wireless "b" or "g" or the new "n".
Aug 25, 2011 | Acer Aspire 5742Z-4200 Notebook
I need to locate the default IP to my Linksys WAP200. The default has been changed and the owner cant remember what it was changed to. The owner cant afford to lose the configuration settings.
Plug a laptop into just the linksys. Make sure nothing else is connected. Then on the laptop go to start -> run and type cmd. In the black box type ipconfig. This should show you the ip settings on the laptop. There should be one with a default gateway filled in. This will be the lynksys's IP address.
May 31, 2011 | Linksys WAP200 (LS-WAP200) 802.11b/g...
Cant connect 3 laptops to the dlink dir 615
reset ur router and remove the dhcp limitations
Dec 26, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
Wireless not working
I assume it's a laptop/notebook.
If so then there is a switch near the light that is on when the adapter is on. It will be a very small slide switch, on the front or side edge. Simply find it and slide to on. Or if it's already on then try pressing the fn key and f8 together, as this sometimes is a second wireless switch.
I hope this helps
May 09, 2009 | Computers & Internet
Hp Pavilion dv6929nr not connected with D-link DI-624
There are a number of factors that can cause the signal of your access point to deteriorate and the performance of your network to fall under par. Practically any appliance that operates on the same frequency level (2.4 GHz) as 802.11b or 802.11g can cause interference with your wireless network. Be sure to keep cordless phones, microwaves and other electrical equipment at least 1m away from the access point. Try changing channels on the access point and test it out on one of the clients. To change the radio channel on the access point login to the configuration (usually a web based interface) and go to the Wireless Settings (will vary depending on vendor) section, select a different channel and save settings. On the client, go to Device Manager, right click your wireless network adapter and go to Properties. In the advanced tab select the Channel Property and change the Value to the same number as the one you chose on the Access Point. Disable and then re-enable the wireless connection. Also you can try by select the speed manually 802.11b or 11Mbps on your laptop wireless properties.
Mar 21, 2009 | HP Computers & Internet
Lexmark N2050 wireless adapter for X3500-4500 series printer
i cant tell you too much because i dnt know too much about your situation but try completely resseting everything and try sending something again
if its allwireless c if you can pick up the wireless points if you cant there's your problem
Dec 29, 2008 | Lexmark N2050 for X3350 (14T0300) Wireless...
Wireless router says its working laptop says no its not
Your sister was accessing the wireless access point at school which is connected to the Internet/WEB access via a router and the school's broadband service provider.
For you to access the Internet using your wireless adapter on your laptop, you need your own wireless access point and connect it to a broadband ADSL or cable modem and then connect it to an Internet Service Provider. Some Internet Service Providers (cable and ADSL) can supply a combined modem/router/wireless Access point.
If you already have a broadband modem all you need is a wireless access point/router. You only need to configure the wireless access point and your wireless adapter so they will communicate with each other. Folow the instructions in the manuals.
Dec 07, 2008 | NetGear WGR614 Wireless Router
Lost CD
What is the make and model number of the product please?
Oct 30, 2008 | Microsoft Broadband MN-610 Wireless...
Ei system laptop
just check the ypur wireless Lancard is enabled,
commands---------my network place----right click---properties---wireless lan card----enbale.
Dec 29, 2007 | Computers & Internet
Cant find access point
do you have anything else on your wireless router using the wireless?....Does a laptop with a wireless card hook to your wireless setup and surf the net?...
Dec 29, 2007 | Sony Playstation 3 (PS3) Console
PC Chips M925G (M925G V9.1B) Motherboard Logo
Top PC Chips Computers & Internet Experts
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
