Question about Kyocera KM-1510 Copier
Dark line across copies
Hi everyone
I have a Kyocera KM 1510 and have started to get a back stripe acoss all copies. I've been told it's probably the drum. Is this correct or could it be something else
  • paulypudding Sep 22, 2008
    I havent tried it yet but will at the weekend. Thanks for your help
    An user who is expert in 3 categories / brands.
  • Kyocera Master
  • 1,362 Answers
1-remove drum and turn upside down, is there a black ring on the shiny cylinder, yes, replace
2-remove drum and clean inside of machine look for strip of light, clean for toner
3-if cpying from an automatic feeder, and it does it from there ONLY then lift ADF and clean the small strip of glass.
Posted on Sep 15, 2008
My kyocera km 8030 prints with dark lines
assalamoalikum dear you chek LD UNET and clean
ld unet
Jun 30, 2015 | Kyocera Office Equipment & Supplies
My kyocera km-20- 30 have a problem. when i make copies it appears two dark line in the bottom and on the top of the paper
It seems the problem of Spacer. in your Ink Unit. In INK Unit there are two black bearing (called spacer) are used at the both end of INK Unit. Try to replace those spacers. or send me the print out of your machine.
Jan 19, 2011 | Copystar CS-1510 Copier
Our copies and starting to come out dirty and
Dark copies in that machine means the drum it's getting old. If adjusting the exposure to light makes the copies better, then the drum is the culprit.
Apr 28, 2010 | Kyocera KM-1510 Copier
Kyocera KM-1510 when i turn it on the code C-620 appears and will not function,how can i fix it?
Hello sir; You need to do a reset procedure;
press these keys in order and keep hold them down, "stop/reset" "start" "left copy density", press "stop/reset"key again, then enter U163 press "start" twice to clear.
Sep 17, 2009 | Kyocera KM-1510 Copier
Please Help Kyocera KM-1510 Grayscale Copier & Minolta D251 C0F32
check the exp.lamp . it mzay be blinking at the time of scanning the original.
Feb 17, 2009 | Kyocera KM-1510 Copier
this is a fuser error meaning that the fuser has overheated. In most cases the thermal fuse or thermostat blows and will need replacing. especially if you get the 630 code, and switch the machine of and back on and get a 610 code.
Oct 13, 2008 | Kyocera KM-1510 Copier
I have problem while copying with my kyocera mita km-1635
If its on the rear side of the page would most likely to be the transfer unit. What model is the machine?
Thanks Jason
Aug 17, 2008 | Kyocera KM-1510 Copier
Km-1510 .. AP error code
AP = Adding Powder (toner) it's not an error
it's adding toner from the container into the developer unit while displaying AP. when there is enough toner in the container the AP will disappear and copies can be made when there is not enough toner in the container the toner empty light will come on.
Oct 22, 2007 | Kyocera KM-1510 Copier
Kyocera KM-1510 Copier Logo
185 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
