Question about Dell 725 InkJet Printer
Laptop doesn't recognise printer
The printer was working on desktop comp (xp), but laptop (business vista) won't recognise dell 725 - I have drivers and utilities CD ???
Thanks.
  • pow210 Sep 14, 2008
    This is what happened ; "the folder you specified doesn't contain a compatible software driver for your device. If the foldercontains a driver, make sure it is designed to work with Windows for 32 - bit systems."
    Cheers.
    Have tried to download three times and always comes up; Auto Diagnostics -error.
    Cheers
  • Dell Master
  • 19,396 Answers
Follow instructions below,
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Install printer drivers from CD or from download.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note some peinter does not work on Vista
Posted on Sep 14, 2008
  • Ginko
    Ginko Sep 14, 2008
    You need to start a driver installer. If you cannot start the driver from cd, then download the driver.
    Here is the link.
    Note that some printer does not work on Vista.
    Click here: DRIVERS & DOWNLOADS -- Lexmark
SOURCE:
I have a Desktop comp. DELL_Dimension E520. I
You should download the drivers BEFORE you change the OS and maybe put them on a flash drive or burn them to a CD.
You can get them direct from the DELL site.
It maybe that your XP disc does not recognise a SATA drive and for that reason you should use the F6 option whilst booting from the XP setup disk and point it to the CD or flash drive.
From then on you should be able to format the disck.
Some of the dells are a little tricky that way.
You may also have to change the bios option as for sata type
I have had to do this on a few dell laptops.to down grade from vista to XP
May 28, 2010 | Dell Dimension E520 PC Desktop
I have had this printer for about 2 years or so. It used to work. Now it gets frozen on the USB printer port page when I try to print. So I went to the dell printer driver page and downloaded the printer...
no need new printer first uninstall old printer drivers from computer then check your printer model number and download exact driver again then install.
Jul 13, 2009 | Dell 725 InkJet Printer
Im trying to install an old printer on a new vista comp w/o disks
Windows Vista" is your operating system.
I would start by uninstalling (undoing) any of the printer software that you have installed, and try again. It sounds like at this point that you may have bits and pieces of both 'XP' and 'Vista' drivers installed.
Your link is pointing to the right page at Dell, just select the "driver" under the windows Vista tab.
I'm not sure how that software will be packaged, But I assume that it is self installing once you download it. You just click on it to start the installation. Usually you will leave you USB cable to the printer unplugged until after the installation, and then you are prompted to plug it in.
I'm not sure if this will help, but it's difficult to know exactly what you have done to this point.
Jun 22, 2009 | Dell 942 All-In-One InkJet Printer
Most wanted
try disabling firewall and antivirus softwares.restart your comp and then try.it`s also noticed that vista doesn`t work without security so you have to try enabling security on vista and as well as on xp.
May 30, 2009 | Dell Studio XPS 16 Notebook
Printer (922) won't install on new laptop
If your laptop is running Vista and your old desktop was running XP and the disk you got with your printer had drivers that worked with XP and Vista is not listed on them, it would be a case of incompatibility. You would need to go to the Dell website to download updated drivers for Vista if they are not of the standard Vista driver package. (The driver model changed between XP and Vista making XP drivers incompatible with Vista.)
May 27, 2009 | Dell 922 All-In-One InkJet Printer
Dell 725 USB printer says catridge not present when it is
i think you will have to take the printer to the service center as it needs servicing, there might be a problem with the cartridge holder
May 03, 2009 | Dell 725 InkJet Printer
Unable to install dell 725 printer onto a dell vista laptop
Download Dell 725 Inkjet Printer driver and try to install.
Drivers and Downloads
Regards
Chittaranjan
Nov 22, 2008 | Dell 725 InkJet Printer
Camera stopped bing recognised
sure..sounds like you may need to reinstall drivers for both the webcam and printer..sometimes those drivers will go corrupt when there's a power glitch.
get the printer drivers here
Mar 04, 2008 | Computers & Internet
Use with vista and XP
yes you need to download windows vista printer driver for dell 922 on the laptop for your desktop leave it as it is.
Get on web and search printer drivers for dell 922 windows vista install on laptop and youre done
Nov 29, 2007 | Dell 922 All-In-One InkJet Printer
Dell 725 InkJet Printer Logo
176 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
