Question about EliteGroup Slot 1 P6BX2-A (147010300187) Motherboard
Computer booting problem
Hi sir, my computer didn't boot whenever i turn it on,and there is no beeping error. what should be the problem of that?
Check your power supply.
Posted on Sep 14, 2008
Acer 5742g Beep at boot up
I have a problem that looks like this one.
At boot up, after the POST, each time the HDD led blinks, the laptop produces a loud "beep", and refuses to boot, as if this phenomenon prevented the HDD to be read.
If I press the power button, it stops beeping. When I release it, it starts beeping again.
If I press F8 at the beginning and then ask for a normal boot, It boots normally. Anyway, in windows, I have some strange activity, like I would continually pressing Alt+Tab. If I press Esc, it stops immediately and then all seems to work fine.
Any clue?
Jul 26, 2012 | Acer Aspire 5742G
I have a brand new SAM4S ER-180 cash register. If I plug in the power it immediately goes to error mode & beeps at me. The LED screen is reading E Lo0000 or E Lo0.00. I have tried everything & dont...
A beeb normally means defective (hardware failure) DOA. Go back to your store for a warranty replacement.
Does it start without the scanner?
http://tinyurl.com/69hd8kf
Does computer beep when you turn it on? Information on beep codes bleeps on booting, boot codes led flashing flashes 1 2 3 4 5 once twice three times on and off times on boot. power on self test fail, boot failure.
Quick help guides and LED flashing errors codes search for error codes using your
Service manual.
Maybe more info here
http://www.goodson.com.au/service/FrmService.htm
Feb 13, 2011 | Computers & Internet
When i turn my computer on it has a long beep sound and then another long beep and wont quit... please help
Check your MEMORY MODULES . Try removing them, cleaning them with rubbing alcohol and the reinstalling them. Re-boot. That should work, ok?
Oct 18, 2010 | Acer Computers & Internet
HP pavillion DV 2000 cant boot and with 1 long 2 short beep
I found some info on a forum, it says the 1 long and 2 short beeps is a problem with the graphics chip. You may need a replacement motherboard.
Check this post out
http://www.computing.net/answers/hardware/1-long-2-short-beeps-hp-laptop-/52894.html
Aug 16, 2010 | HP Pavilion dv6000z Notebook
Will not boot. good power, all fans, hdd,video, and initial system beep,power up, but does not show boot screen, almost like its not initializing bios.
Dear Sir
Prees your Key-Bord Delete/f2 key
Advance Option And Frist drive In cd - dvd Rom /
Boot Option And Frist drive In cd - dvd Rom /
Enjoy Not Message
Aug 17, 2009 | Foxconn G9657MA-8KS2H Motherboard
Computer turns off then on after first boot
2 beeps is memory issues.  Either your RAM is bad or the Video card is bad.  If you are getting the BSOD, blue screen of death, then I would take out all your RAM and start it up with a single stick, so you can find out what stick is bad.  If you only have 1 stick, replace it.  I say to do the memory first, because it is the cheaper fix.
Mar 12, 2009 | Soyo P4VTE (SY-P4VTE) Motherboard
Boot failure
samuel,
if you don't here ok beep or any error beep:
  1. First check out speaker is connected properly to motherboard.
  2. Remove all component from motherboard like HDD,FDD, RAM etc..
  3. Just put only processor to your board and power-up
  4. There must be a long beep for missing RAM, if not means you have problem in Motherboard or CPU. Try out another board and another CPU to find out which one is faulty.
  5. If you got missing RAM beep, then power-off and add RAM. Then power-up there must be ok beep (only one beep) or missing RAM beep. If missing RAM beep, then your RAM might be faulty try to clean the connection point with pencil earaser and try out again. If no success then try with another RAM.
I think this will help you.
Please post your feed-back. Or ask me if any question.....
Gud luck
Iqbal
Apr 21, 2008 | Computers & Internet
Asus P4pE not booting.
The beeps you hear are probably BIOS error beep codes. Through a series of long and short beeps the BIOS communicates what type of error is occurring during the initial stages of the start up process. If you can tell me the manufacturer and model number of the board AND the sequence and length of the beeps I can point you in the direction to go.
Dec 13, 2006 | ASUS P4PE Motherboard
EliteGroup Slot 1 P6BX2-A (147010300187) Motherboard Logo
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
