Panasonic NN-S541 .... comes on, runs for about 3-4 seconds and then shuts off. Doesn't matter what cycle I choose, I get same results. I do hear some "strange" noises (clicking??) coming from the right-side middle to rear of the oven the short time it's running. Also, I get a VERY faint odor akin to electrical smell. It is so very faint as to make me wonder if I'm imagining ... it's that miniscule. I only paid $100 for it new, so I'm not wanting to take it to a repair shop ... thought there might be something I can handle. If not, I'll buy a new one. Thanks!
Yeppers! Runs about 3-5 seconds and quits. In the meantime, it makes a wierd noise like it's shorting out and a bad smell ( not real strong ). Guess it's time for a new one.
Comment by Guest, posted on Jun 18, 2008
Starts, runs 3-5mins, no heat, then stops. Losing power for approx. 5 mins, then turns back on.
Comment by Guest, posted on Apr 30, 2008
The Mwave starts and stops within 2--3 seconds. If there are strange sounds you know that it will complete the heating else you can try as long as you want and it will not work.
It started doing that immediately after we bought the 2.5 GhZ panasonic phone.
Sadly, this model uses an inverter to produce high voltage instead of a transformer.
While an inverter (switched-mode power supply) is more efficient from a power consumption standpoint, it is more complex, thus more statistically prone to fail.
Even worse, the machine-soldered connections in a microwave inverter are often too weak, so they eventually fail - often catastrophically. (Thus the clicking and the odor, which is thinned out by the cooling fan).
Manufacturers generally do not encourage or assist technicians to repair microwave inverters. They offer the inverter as a whole assembly, and they are not cheap!
Personally, I would never consider getting an inverter-powered microwave repaired unless it were under warranty or a very expensive over-the-range type.
Was this solution helpful? Show your Appreciation by rating it:
The same thing happend, twice, to my Panasonic model #NN S654WF. It runs for approx. 3 seconds then quits. No smells or other with this one, just the 3 seconds and cuts out issue.
Unfortunately I a have a 10 year warranty on this thing, so I will have to put up with the 9 week turn around at the repair shop for them to order the same part and install it. It's a $21.43 kit part. Panasonic Part Number: F690L8F00AP for this model says it is a 1.2 CFT INV/FAN KIT (A).
I know this is a year-old post, but someone who might be experiencing a similar issue might order the inv/fan kit for their model and install it faster and cheaper than a busy shop might?
Show your appreciation by commenting on Microwave Problems:
Solution #3
posted on Apr 08, 2007
Guest
Rank: Apprentice Rating: 0%, 0 votes
Inverter type oven uses IGBT transistors and these are very sensitive devices and prone to failure.This may be the cause. New circuit board will cost around 100 bucks with trade in your old board.
It could be as simple as the cooling fan is stuck and it's shutting the oven off as a safety measure. Unplug the unit, remove the cover and see if the fan rotates easily by hand. If it does, look around for anything which looks burnt. I have one on the bench at the moment which suffered a burnt out microswitch on the door safety mechanism but it really caused a smell.
If the fan doesn't rotate freely use a little wd40 (penetrating oil)and keep turning the fan until it's free. Then a little drop of machine oil and away you go.
If that fails I'll repeat previous advice "Buy a new one"
BMW
PS microwave ovens can give off all sorts of funny smells depending on what's been cooked in it before :-)
