Question about Sony KP-65WV700 65" Rear Projection HDTV
Kp-65wv700 After turning on my sony kp-65wv700 the screen turns green, then after 2 seconds, it's black as in no picture, but still has sound.
  • Mike MCentee Jan 17, 2009
    does anyone know the part number for this tube? when I turn mine on it goes from a bright green to a blank screen, good volume, but also lost all othe video inputs prior to this happening (all except for the input for my ViosTV
  • Sony Master
  • 5,138 Answers
You need to adjust Green screen drive control your green tube could be shorting out.
Posted on Sep 14, 2008
Green and blue faded
Some of these had bad picture tubes--(model indicated here uses 3 tubes)
Simple test is go to a black and white channel and turn color to zero= is the screen black and white or some other color?
Also go to a unused video input and look at screen=all you should see is black screen with the input number in green= any other color and something may just need to be adjusted.
Apr 15, 2012 | Sony KP-65WV700 65" Rear Projection HDTV
I get curved red lines and then screen goes completely red and no sound
This is symptom of defective red picture tube in TV that needs to be replaced.
Let me know if you want to replace it by yourself to provide you part number info or call tv tech to do the job.
Nov 30, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
Kp-65wv700 7 blinks
hello High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Nov 10, 2009 | Sony KP-65WS500 65" Rear Projection...
Sony kp65vw700 problem with green screen and then
Most likely a shorted Green CRT of which they are no longer available.
Oct 24, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
KP-65WV700 Red and Green Lamps fade out after about 15 seconds
If you know how to adjust G2 (screen) volt adjustment then increase a little bit screen volts of red and green lamp.
Mar 15, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
SONY TV MODEL # KP-65WV700 SER.# 9002706
Blue Gun is right side of TV if you look in TV from back side. Part number is as follows..
8-733-663-25 {CRT 07MVC62(B)-L} [KP-65WV700 ONLY]
Mar 13, 2009 | Sony Televison & Video
Het Big AOT-
Sounds like the screen drivers for the blue and green projection CRTs sre possibly going south, or it could possibly be the CRTs(picture tubes) themselves going bad, although it would be highly unlikely for two tubes to go south at the same time. My money would be on the control circuits (screen drivers).
The easiest way to troubleshoot this problem would be to obtain a can of circuit cooler from an electronics supply house and determine the area on the motherboard where the screen drivers reside; then turn on the set and let it heat up until the problem occurs, and then carefully spray (one at a time) the components in the screen drivers area. When you hit the faulty component (probably a chip), the problem should clear --- until that part heats up to failure point again.
Determine the part #, obtain a replacement part, replace it and hopefuly the problem will be solved.
The last time I encountered a similar problem in the real world, it turned out to be a cracked circuit board, and all of the intermittently broken circuit lands had to be bridged by resoldering over the cracked area... a tedious and time consuming process.
If the set is still covered under warranty, let Sony fix it... any attempts by you could void the warranty!
Hope this helps and good luck! Keep us posted as to your results...
Jun 14, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Blue Screen
You have a bad blue picture tube. If you replace it the red and green will be weak and probably go sooner than you think. Everytime I had to replace a tube in a sony projo tv i had to replace all 3 picture tubes at the same time. It's very expensive if you don't have any type of warranty coverage.
Feb 10, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Sony KP-51HW40 No Picture, only sound
to thus problem its very simple .! try to resolder at the back of the picture tube board.
Nov 26, 2006 | Sony KP-53V75 53" Rear Projection...
I have the 51" rear projection (kp-51ws520) and problems...
The same problem?? Sounds like a green crt driver is defective or the green crt is bad.
Aug 14, 2006 | Sony KP-51WS500 51" Rear Projection...
Sony KP-65WV700 65" Rear Projection HDTV Logo
150 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
