I have a KAC721 amp.which has been working fine.Suddenly rear 2 speakers are trying to explode,screeching and loud popping sounds.Connections appear to be good,as is the earth. Any assist would be appreciated.Regards,John. bettjohn@bigpond.com
---okay now,,,,problem solved,,,,,worn insulation on speaker wires hidden behind interior trim..Thanks anyway all concerned. John.
Posted on Sep 15, 2008
Speakers "pop" on and off but no sound while its on. i turn everything on and i hear it, then nothing, and hear it when i shut it off. the amp was working fine and one time i got in the truck and they...
you could have a shorted speaker I would disconnect all speakers and test them 1 at a time to see if you can get the amp to make some sound before I did anything.
Aug 07, 2013 | Power Acoustik Car Audio & Video
Myryad ma120 power amp,loud pop when switched off
Sounds like a Electrolytic capacitor has failed. Search backwards from the speaker connections inside the unit to the main PC board. Replace the first ones that you come accross that are linked with the speakers.
Dec 15, 2012 | Myryad Z Series Z160 Amplifier
I will be watching either satellite or movies through my PS3 and the sound will suddenly go out. I"ll get a loud humming sound or static coming through the speakers. After i shut off the reciever...
hi,
may be there was some loose contact in ur receivers rear connections.thts why it produce the loud hum. use good quality inter connects. check is the all connectors are properly inserted or not.
ok
Dec 23, 2010 | Denon AVR-1508 Receiver
My rear and center speakers suddenly quit working. No sound
try a different source. if there is output on all speakers in test mode, then the amps are good but the source or source switching may have a problem.
Mar 01, 2010 | Audio Players & Recorders
LCD HDTV turns off, displays lines & static w/ loud noises
check in your manual and follow instructions on updating the software. you download the file to computer then move it to a memory stick (USB), then simply insert it into the tv
Mar 01, 2010 | Televison & Video
Kustom Profile One 100w PA -loud bang!
i have three of these in my amp repair shop. one of them does exactly this. as well, the other two are suspect to the same issue. i believe it is low quality leaky or shorting caps. are you using the xlr inputs or 1/4 inch inputs? so far, these are working good thru the 1/4 inch jacks, but the xlr inputs are squeely with feedback and i get that loud bang/pop from one of them. kustom wants me (my shop) to be an authorized repair station for them. i want to be able to resolve these three amps before i accept. if they are a nightmare to deal with, then i will tell them no way.
i will post back with in the next week with more results and hopefully i will have precise solution with parts and procedures.
yost amplifier repair
yostamplifier.com
Oct 06, 2009 | Audio Players & Recorders
LOgitech x230 - problems with sound
If the sound only happens when sound is being played through them I would check the shielding on your connections to your sound card. Make sure that any protective coverings are in place and that the connections are tight.
If it happens at random times even when sound is not being played through them I would see if you are picking up interference such as a close cell phone, fan, ham radio operator, etc.
Dec 18, 2008 | Logitech X-230 Computer Speakers
Nad c370 problem....
Hi arda5
Did you try swapping speaker connections left for right on the back of the amp to isolate the problem. If the fault stays with the speaker, then that is where your problem is. Try this and get back to me here with the results.
regards
robotek
Jun 13, 2008 | NAD C370 2-Channel Amplifier
Logitech Z-2300 speakers
maybe the first step could be checking the subwoofer's fuse.it is located over the power supply connector.
Jan 12, 2008 | Logitech Z-2300 Computer Speakers
95 people viewed this question
 Grubhead
Grubhead
