Question about HP Photosmart C6100 All-In-One Printer
Ink system failure
I have an ink system failure
OXC18a0201 what do i do to fix it
I have new ink cartriges .
This hapened when I changed the Cyan ink
james
  • 2 more comments
  • sarahgesa Sep 17, 2008
    I have the same problem. I've tried 3 new cyan cartridges but the replace cyan cartridges message is still on and the printer won't print.
  • gtingen Oct 11, 2008
    Same problem. Same error message. It occurred when my wife changed the cartridges. Any help will be apprecitated.
  • Anonymous Nov 01, 2008
    I have the same problem. Just printing up a storm and it stopped. No indicator that it needs a new cartridge or anything. This isn't in the manual!!
  • Tom Krieg Nov 12, 2008
    Printer working fine this morning then received the same message.  Shut down the machine, removed the power cord, removed the cartridges, waited two minutes (per HP site) and then replaced cartridges, replaced the power cord and push on switch.  The problem continues.....need help
  • 679 Answers
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Posted on Feb 03, 2009
After changing an ink cartrige an error message read Ink System failure. Error Oxc18a0201 It tells me to turn off printer and turn back on using printer off button.
Ink system failures are a frequent issue. If turning the unit on and off doesn't help, try doing a reset. With the unit on, disconnect the USB cable from the back of the printer (and from the computer - not always required but it does help sometimes). Then remove the ink cartridges. When the screen shows Insert Cartridges, disconnect the power cord from the back of the printer. Unplugging the cord from the outlet may help. Wait 60 seconds and then plug in the power cord (first to the wall and then the unit). Turn on the printer if it doesn't turn on when the power cord is reconnected. Then reinsert the ink cartridges and close all doors on the product. Print a calibration page and scan the page if needed to complete the calilbration if prompted to print one. Reconnect the USB cord to both the computer and then the printer.
If this doesn't help, the printer needs service. If it is out of warranty, decide if the unit is worth the minimum $50 charge just to diagnose the problem and the cost to get the unit to a service center.
I hope this helps.
Jan 23, 2011 | HP Photosmart C8180 All-in-One InkJet...
I have a HP 8250 printer....wont print. I get the following messaage. INK SYSTEM FAILURE The ink system has failed and can no longer print. Refer to printer documentation. ERROR Oxc18a0201. Turn...
Best simple fix is to take out entire program thru Control panel>add/remove and restart the computer and then reinstall it. Should take only 15 minutes.
Jan 03, 2011 | Office Equipment & Supplies
Cyan ink cartage does not work in epson t11 plz tell me what can i do. lllllll;htgg;lp gkjhjjhkljkljkljiokggyu0ijhgjhpjnp[to[otto
Jast push some ink through the print head plastic pipe.Take a seringe of full ink, put off all the ink cartrige, then set the seringe front hole on the cyan black pipe (that are usually set in side the cartrige). Then push cyan ink into the pipe.
After that, I think your printer would work again.
Thank you
shohagtush
Oct 27, 2010 | Epson Office Equipment & Supplies
Cyan ink discharge at the back of the ink crtrige.
The leak is from the cyan ink cartridge or from the connections in the ink tube system. Replace the ink cartridge first. If that does not fix the problem, replace the ink tube system.
Jan 13, 2010 | HP DesignJet 1050c InkJet Printer
Error: OXc18a0201
The ink system failure message has a chance to be fixed or it may be a permanent issue. It can be pointing toward a firmware failure in the printer and if that is the case the following steps should fix it. Press and hold the ?*? key. Press the ?#? key and release both keys. Display should say ?Enter Special Key Combo? Press and release in sequence the "1?, ?2? and ?3? buttons. Display should say ?Support? and display the FW rev (something like R0631R) Mine reads R0631M . Press and release the right arrow button until the display says ?System Configuration Menu?. Press and release the ?OK? button. Display should say ?Hardware failure status?. If not there already, Arrow Key over to ?Hardware failure status?, Press and release the ?OK? button. Display should say ?Hardware failure status: Clear. Press OK to clear?. Press and release the ?OK? Button. Message changes to ?Hardware failure status Cleared. Press Cancel to continue?. Press and release the ?CANCEL? button as many times as necessary, so that, either the ?Welcome to Photosmart Express? screen appears, or, the ?Ink System Failure? screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer. Turn the unit on. The printer may display message ?USE POWER BUTTON TO SHUTDOWN THE PRINTER? followed by ?PRESS OK TO CONTINUE?. Press OK. The Printer will start the ?ONE TIME INK INITIALIZATION PROCESS?. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
Sep 24, 2009 | HP Photosmart C6180 All-In-One InkJet...
After cyan ran out, installed new cartrige. Printer produced everything colored blue as red. Purchased new cyan cartrige and the problem recurred.
The problem seems from your new cyan cartridge.
It doesnt print cyan ink.
Try to clean print head and test print for each color
from the utility menu
Sep 09, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Epson rx595 changed to cartriges everthing fine
Try cleaninig the ink before reinstalling it again,if problem pesist,clean the surface contact on the printer and put back the ink,if pops up again,replace the ink.
Jul 13, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Ink system failure
well nothing to say but!!! go get a new one!!!!
Jul 12, 2008 | HP Photosmart 3210 Printer
HELP!!! Phaser 8500 Error 09.035.43:28534
That is a cyan ( blue) ink stick count failure.
Look in your ink loader. First just try opening and closing the lid.
Then look for gaps in the cyan sticks. Most likely one is broken, cracked or otherwise jamed in the slot.
If you have to remove them, take a screw and screw it into the ink stick then slide it up the chute and out, then reload.
Hopefully someone didnt try to add or cut up a stick from a differerent phaser.
Thats your problem. Just a stuck cyan ink stick.
Mar 24, 2008 | Xerox Phaser 8500/DN Printer
Printing
man i had the same problem cost and arm and a leg change all new ink never work again call epson they told me the printer was broken they send me a new one got stiff with ink cartrige they told me to trow the old one in garbage now when cartrige emty i buy another printer call them hope they send you a new one you deserve one cheers
Jan 19, 2008 | Epson Stylus CX3810 All-In-One InkJet...
HP Photosmart C6100 All-In-One Printer Logo
450 people viewed this question
Ben Johnson
