Question about EliteGroup Slot 1 P6BX2-A (147010300187) Motherboard
Motherboard problem my computer did not boot and there is no beeping error.. what should i do about it?
  • Steven Brown May 11, 2010
    1. Is the motherboard under warrenty ?
Your memory module is dead... you should buy a new one...
Posted on Apr 18, 2009
Emaxxtech com
how many beeps ? there are various error codes depending on what beeps you are getting .
look at the motherboard manual that should indicate a component it could be any of the componants
Aug 25, 2014 | Computers & Internet
Dell Inspiron N5010 4 beep error
This may help. The 4 beep code error in Dell Inspiron N5010 mean Memory read / write failure. Try draining the residual charge and check if you are able to boot. Here are the steps:
  • Disconnect any external peripherals (flash drives, printers, external hard drives) from the computer including the battery and AC Adapter.
  • Press and hold the power button for 20 seconds.
  • Reconnect the battery and the AC Adapter. Try to restart the computer and check.
Please make sure that the memory modules are firmly reseated and there is no dust accumulated on the memory slot on motherboard.
May 20, 2014 | Dell Inspiron Computers & Internet
I am running Unix Tru64 5.0 on Compaq Alphastation XP1000. The computer does not boot and does not display anything and does not beep. The power supply works and some LEDs are on on the logic board and the...
Hi.first pull-out your motherboard in the CPU case then power on without memory only processor installed.if you hear continuous beeping your motherboard is working good.
try this beep code means.
No beep means short,no power,bad CPU,loose peripherals.
One beep means everything is normal running motherboard.
Two beep means CMOS error IC.
One long beep,one short beep means motherboard problem.
One long beep,two short beeps means video card problem.
Three long beeps means keyboard error.
Repeated long beeps means memory error.
Continuous hi-lo beeps means CPU overheating.
Hope can help you.
Jun 18, 2011 | Compaq AlphaStation XP1000 PC Desktop
Long beeps not booting up
problem....the beeps are beep beep beep beep..........contiues...........plus the computer will then not recieve signal????
May 25, 2011 | MSI K9VGM-V Motherboard
Abit av8 bios post codes 8.3 - 8.6 - 9.c What is failing on boot ? I get one long beep followed by 4 short beeps. I have swapped video cards and reflashed the bios with no help. If I reboot 2 or 3...
I still did not find beep code that match your problem..
Anyways here are the common beep codes for your motherboard.. it might help you too.
1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem.
2. 1beep - board is working fine.
3. One long beep then it shuts down - cpu problem, your processor is not working or missing.
4. 1short beep - system boots normally
5. 2short beeps - CMOS setting error.
6. 1long 1short beep - dram error
7. 1long 2 short beep - video card or monitor not connected
8. 1long 3 short beep - keyboard error.
9. 1long 9short beep - ROM error
10. Long beep - memory card is missing or not connected
11. Short beep - power supply error
12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
Hope this gave you an idea of your problem..
Much appreciated if you rate this help..thanks..
May 23, 2010 | Abit AV8-3rd Eye Motherboard
I am getting three short beeps while booting
The beep codes below may help you identify the possible computer problems. However,
they are only for reference purposes. The situations might differ from case to case.
gAMI BIOS Beep Codes
*Computer gives 1 short beep when system boots successfully.
*Except for beep code 8, these codes are always fatal.
1 beep Refresh failure
2 beeps Parity error
3 beeps Base 64K memory failure
4 beeps Timer not operational
5 beeps Processor error
6 beeps 8042 - gate A20 failure
7 beeps Processor exception interrupt error
8 beeps Display memory read/write failure
9 beeps ROM checksum error
10 beeps CMOS shutdown register read/write error
11 beeps Cache memory bad
g AWARD BIOS Beep Codes
1 short: System boots successfully
2 short: CMOS setting error
1 long 1 short: DRAM or M/B error
1 long 2 short: Monitor or display card error
1 long 3 short: Keyboard error
1 long 9 short: BIOS ROM error
Continuous long beeps: DRAM error
Continuous short beeps: Power error
Nov 03, 2009 | Gigabyte GA-7VKML Motherboard
When i press the on switch the computer light turn red color and have a beep sound.
1 or 2 beeps is normal when turning on, for most mobo's. Check the motherboard owners manual for beep errors, for example 3 beeps might be a graphics card error, 4 keyboard error, or CPU or memory. it's in the manual for the specific motherboard. You can get it from the manufacturer's website. I can not supply a link to get you the online manual because you didn't specify what kind of motherboard you are using. Does it still boot? Do you see the BIOS on screen? Any error messages? When you press the power button your computer normally should beep once or twice and then performs a POST... Power-On-Self-Test. and this is when you get any error beeps. It could be something simple like forgot to hook up the monitor, to CPU or memory is loose, or memory is not compatible if you upgraded the memory.
Oct 20, 2009 | HP (350030-001) for Compaq dc7100...
My serial and password will not register my dvdxcopy
Check
Click on underlined items for further information
1 Beep
If the PC boots properly, then this beep is normal. It is an audio cue that the PC has passed the POST and started to boot.
  • (AMI) Memory problem
  • (AWARD) Memory problem
2 Beeps
3 Beeps
  • (AMI) Memory or motherboard problem
  • (AWARD) Video problem
  • (IBM) Keyboard problem
4 Beeps
  • (AMI) System timer failure
  • (AWARD) Video Problem
5 Beeps
  • (AMI) CPU or motherboard problem
6 Beeps
  • (AMI) Keyboard or motherboard problem
7 Beeps
8 Beeps
  • (AMI) Video card or video memory problem
9 Beeps
  • (AMI) Motherboard problem
10 Beeps
11 Beeps
  • (AMI) Cache memory error
Continuous Beeping
  • (AMI) Memory or Video Problem
  • (AWARD) Memory or Video Problem
  • (IBM) Power problem or loose card
Oct 28, 2007 | 321studios DVD X Copy Platinum (200000)...
SOLTEK SL-65K2-CT Motherboard
The beep pattern is a beep code and is how the motherboard communicates errors during the early booting process otherwise known as the POST (Power On Self-Test). List restart the computer and listen for the pattern of short and long beeps. Soltek does not list the beep codes in their manual, instead they refer to Phoenix who manufacturers the AwardBIOS on your motherboard. There are only two POST beep codes; a single long beep followed by two short beeps (Video error) and anything else. Apparently anything else you hear *probably* refers to RAM problems. Since you?ve already tested both one of the remaining options is to install a *POST* card (about $30 to $50), boot the PC and read the hexadecimal error code for a more detailed clue to what failed. If you ask around you might find someone who has one and may be willing to loan it to you. Another option is to write off the motherboard since the cost of the test equipment it about 1/3 the cost of a new board. Let us know if you have any other questions and please don?t forget to rate the posing.
Jan 06, 2007 | Soltek SL-65KV2-T Motherboard
EliteGroup Slot 1 P6BX2-A (147010300187) Motherboard Logo
35 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
