My computer picked up a missing dll error. Our IT guy tried to wor around it in safe mode but wound up reinstalling XP which now my programs aren't registered any more. Is there some way to recovery the old system parameters to where is was before? I have tried through windows to recover to a restore point but none listed before the reinstall... Help
  • 75 Answers
If you already reinstalled xp, try to use "restoreit" program:
http://www.softpedia.com/get/System/Back-Up-and-Recovery/RestoreIT-Pro.shtml
this will help you recover everything back to normal
Posted on Sep 14, 2008
Fix kernel dell xp
There are several different ways that kernel.dll errors can show up on your computer. Here are some of the more common ways that you might see kernel.dll errors:
  • "Kernel.dll Not Found"
  • "This application failed to start because kernel.dll was not found. Re-installing the application may fix this problem."
  • "Cannot find [PATH]\kernel.dll"
  • "The file kernel.dll is missing."
  • "Cannot start [APPLICATION]. A required component is missing: kernel.dll. Please install [APPLICATION] again."
Kernel.dll error messages might appear while using or installing certain programs, when Windows starts or shuts down, or maybe even during a Windows installation.
The context of the kernel.dll error is an important piece of information that will be helpful while solving the problem.
Cause of Kernell.dll Errors
Kernel.dll errors are caused by situations that lead to the removal or corruption of the kernel DLL file.
In some cases, kernel.dll errors could indicate a registry problem, a virus or malware issue or even a hardware failure.
How to Fix Kernel.dll Errors
Important: Do not download kernel.dll from a "DLL download" website. There are many reasons why downloading a DLL file is a bad idea. If you need a copy of kernel.dll, it's best to obtain it from its original, legitimate source.
Note: Start Windows in Safe Mode to complete any of the following steps if you're unable to access Windows normally due to the kernel.dll error.
  1. Restore kernel.dll from the Recycle Bin. The easiest possible cause of a "missing" kernel.dll file is that you've mistakenly deleted it.
    If you suspect that you've accidentally deleted kernel.dll but you've already emptied the Recycle Bin, you may be able to recover kernel.dll with a free file recovery program.
    Important: Recovering a deleted copy of kernel.dll with a file recovery program is a smart idea only if you're confident you've deleted the file yourself and that it was working properly before you did that.
  2. Run a virus/malware scan of your entire system. Some kernel.dll errors could be related to a virus or other malware infection on your computer that has damaged the DLL file. It's even possible that the kernel.dll error you're seeing is related to a hostile program that's masquerading as the file.
  3. Use System Restore to undo recent system changes. If you suspect that the kernel.dll error was caused by a change made to an important file or configuration, a System Restore could solve the problem.
  4. Reinstall the program that uses the kernel.dll file. If the kernel.dll DLL error occurs when you use a particular program, reinstalling the program should replace the file.
    Important: Try your best to complete this step. Reinstalling the program that provides the kernel.dll file, if possible, is a likely solution to this DLL error.
  5. Update the drivers for hardware devices that might be related to kernel.dll. If, for example, you're receiving a "The file kernel.dll is missing" error when you play a 3D video game, try updating the drivers for your video card.
    Note: The kernel.dll file may or may not be related to video cards - this was just an example. The key here is to pay very close attention to the context of the error and troubleshoot accordingly.
  6. Roll back a driver to a previously installed version if kernel.dll errors began after updating a particular hardware device's driver.
  7. Run the sfc /scannow System File Checker command to replace a missing or corrupt copy of the kernel.dll file. If this DLL file is provided my Microsoft, the System File Checker tool should restore it.
  8. Install any available Windows updates. Many service packs and other patches replace or update some of the hundreds of Microsoft distributed DLL files on your computer. The kernel.dll file could be included in one of those updates.
  9. Test your memory and then test your hard drive. I've left the majority of hardware troubleshooting to the last step, but your computer's memory and hard drive are easy to test and are the most likely components that might cause kernel.dll errors as they fail.
    If the hardware fails any of your tests, replace the memory or replace the hard drive as soon as possible.
  10. Repair your installation of Windows. If the individual kernel.dll file troubleshooting advice above is unsuccessful, performing a startup repair or repair installation should restore all Windows DLL files to their working versions.
  11. Use a free registry cleaner to repair kernel.dll related issues in the registry. A free registry cleaner program may be able to help by removing invalid kernel.dll registry entries that might be causing the DLL error.
    Important: I rarely recommend the use of registry cleaners. I've included the option here as a "last resort" attempt before the destructive step coming up next.
  12. Perform a clean installation of Windows. A clean install of Windows will erase everything from the hard drive and install a fresh copy of Windows. If none of the steps above correct the kernel.dll error, this should be your next course of action.
    Important: All the information on your hard drive will be erased during a clean install. Make sure you've made the best attempt possible to fix the kernel.dll error using a troubleshooting step prior to this one.
  13. Troubleshoot for a hardware problem if any kernel.dll errors persist. After a clean install of Windows, your DLL problem can only be hardware related.
Applies To
The kernel.dll error message could apply to any program or system that might utilize the file on any of Microsoft's operating systems including Windows 8, Windows 7, Windows Vista, Windows XP, and Windows 2000.
Sep 12, 2013 | Microsoft Windows XP Professional for PC
Trying to reinstall xp sp3 but it gets stuck on kernel ****** dll
Dll errors occur due to various reasons incomplete installation or removal of a program, missing, corrupt, or incorrect .dll file paths, and more.
Failure to fix these errors can result with severe PC problems
If you can't run the chdksk utility in normal mode try it in safe mode
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
you should have no input while chkdsk utility is in progress any input might further damage your computer or
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file.
Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
hope this helps
Oct 17, 2012 | Dell Dimension 2400 PC Desktop
Mss32.dll missing on my pc
There are several different ways that mss32.dll errors can show up on your computer. Here are some of the more common ways that you might see mss32.dll errors:
  • "Mss32.dll Not Found"
  • "This application failed to start because mss32.dll was not found. Re-installing the application may fix this problem."
  • "Cannot find [PATH]\mss32.dll"
  • "The file mss32.dll is missing."
  • "Cannot start [APPLICATION]. A required component is missing: mss32.dll. Please install [APPLICATION] again."
Mss32.dll error messages might appear while using or installing certain programs, when Windows starts or shuts down, or maybe even during a Windows installation.
The context of the mss32.dll error is an important piece of information that will be helpful while solving the problem.
Cause of Mss32.dll Errors Mss32.dll errors are caused by situations that lead to the removal or corruption of the mss32.dll file.
In some cases, mss32.dll errors could indicate a registry problem, a virus or malware issue or even a hardware failure.
How to Fix Mss32.dll Errors Important: Do not download mss32.dll from a "DLL download" website. There are many reasons why downloading a DLL file is a bad idea. If you need a copy of mss32.dll, it's best to obtain it from its original, legitimate source. Note: Start Windows in Safe Mode to complete any of the following steps if you're unable to access Windows normally due to the mss32.dll error.
  1. Restore mss32.dll from the Recycle Bin: The easiest possible cause of a "missing" mss32.dll file is that you've mistakenly deleted it.
    If you suspect that you've accidentally deleted mss32.dll but you've already emptied the Recycle Bin, you may be able to recover mss32.dll with a free file recovery program.
    Important:Recovering a deleted copy of mss32.dll with a file recovery program is a smart idea only if you're confident you've deleted the file yourself and that it was working properly before you did that.
  2. Run a virus/malware scan of your entire system: Some mss32.dll errors could be related to a virus or other malware infection on your computer that has damaged the DLL file. It's even possible that the mss32.dll error you're seeing is related to a hostile program that's masquerading as the file.
  3. Use System Restore to undo recent system changes: If you suspect that the mss32.dll error was caused by a change made to an important file or configuration, a System Restore could solve the problem.
  4. Reinstall the program that uses the mss32.dll file: If the mss32.dll DLL error occurs when you use a particular program, reinstalling the program should replace the file.
    Important: Try your best to complete this step. Reinstalling the program that provides the mss32.dll file, if possible, is a likely solution to this DLL error.
  5. Update the drivers for hardware devices that might be related to mss32.dll. If, for example, you're receiving a "The file mss32.dll is missing" error when you play a 3D video game, try updating the drivers for your video card.
    Note: The mss32.dll file may or may not be related to video cards - this was just an example. The key here is to pay very close attention to the context of the error and troubleshoot accordingly.
  6. Roll back a driver to a previously installed version: if mss32.dll errors began after updating a particular hardware device's driver.
  7. Run the sfc /scannow System File Checker command: to replace a missing or corrupt copy of the mss32.dll file. If this DLL file is provided my Microsoft, the System File Checker tool should restore it.
  8. Install any available Windows updates: Many service packs and other patches replace or update some of the hundreds of Microsoft distributed DLL files on your computer. The mss32.dll file could be included in one of those updates.
  9. Test your memory and then test your hard drive: I've left the majority of hardware troubleshooting to the last step, but your computer's memory and hard drive are easy to test and are the most likely components that might cause mss32.dll errors as they fail.
    Note: If the hardware fails any of your tests, replace the memory or replace the hard drive as soon as possible.
  10. Repair your installation of Windows: If the individual mss32.dll file troubleshooting advice above is unsuccessful, performing a startup repair or repair installation should restore all Windows DLL files to their working versions.
  11. Use a free registry cleaner to repair mss32.dll related issues in the registry. A free registry cleaner program may be able to help by removing invalid mss32.dll registry entries that might be causing the DLL error.
  12. Perform a clean installation of Windows: A clean install of Windows will erase everything from thehard driveand install a fresh copy of Windows. If none of the steps above correct the mss32.dll error, this should be your next course of action.
    Important: All the information on your hard drive will be erased during a clean install. Make sure you've made the best attempt possible to fix the mss32.dll error using a troubleshooting step prior to this one.
  13. Troubleshoot for a hardware problem if any mss32.dll errors persist. After a clean install of Windows, your DLL problem can only be hardware related.
Applies To The mss32.dll error message could apply to any program or system that might utilize the file on any of Microsoft's operating systems including Windows 7, Windows Vista, Windows XP, and Windows 2000.
Still Having Mss32.dll Issues? Let a community of computer support enthusiasts help out! Post the details of your mss32.dll issue in the PC Support Forum. Be sure to let us know the exact mss32.dll error message that you're seeing and what steps, if any, you've already taken to fix the problem.
May 28, 2012 | MSI 645 Combo-L Motherboard
I own an ACER ASPIRE 5732Z-443G32Mn, my problem is with the webcam which is not working. When I'm trying to open the cam the following message is shown on the screen, " The program can't start...
Hi
Just reinstall your webcam driver to fix the missing DLL FILE.
Or go to this link http://www.dll-files.com/.
If still the same, the only solution is to reinstall the operating system and reinstall again the webcam driver which might be corrupted with the windows registry file.
Regards
Jul 08, 2011 | Acer Aspire 5610-4648 Notebook
When trying to scan, my scanner software program comes up with "twain_32.dll" not found. My HP PSC 1350 Printer/Scanner has always worked before.
http://www.fix-all-dll-errors.com/twain_32.dll/
Just visit this site...this will help in case of missing or downloading dll's , also if dll's are corrupted or errors in dll's..!
I also registered few dll's from this site...worked in my case. :)
Dec 24, 2010 | HP PSC 1350 All-In-One Thermal Printer
Hello i have a ati radeon 9250 and windows 7 it havent driver for windows 7 therefor i installed driver for windows xp in windows 7 all work good but in shutdown or restart i have blue screen...
The way to fix ATI2DVAG.dll errors is to first restart your PC into "Safe Mode With Networking". This will basically allow your PC to boot up without all the drivers and software which can cause it to crash. To do this, you should first restart your PC and then press F8 continually before Windows loads. After that, you should then select "Safe Mode With Networking" to boot your PC into that mode. When in safe mode, you should download a new version of the ATI Graphics Driver from the Internet, which should fix most of the problems you've been having with it. This can be done by downloading the driver from the ATI website and then re-installing it in Windows.
After updating the driver, try your PC in "normal mode" again to test to see if the problem has been fixed. If you find it hasn't fixed the issue, you should then go back into safe mode an manually replace the ATI2Dvag.dll error on your PC with a fresh copy of the file from the Internet. On top of that, you should also clear out the "registry database" of your PC with a registry cleaner. The registry database is a central storage facility for Windows, which basically keeps all the settings and options that Windows needs to use to run inside. This part of your system is very important and used to load up many different DLL files. To ensure no registry errors are causing problems on your system, you should download a registry cleaner program from the Internet, install it and then let it fix the errors your PC has.
You can fix ATI2Dvag.dll errors on your PC by using the tutorial and tools on our website. You can Click Here to fix ATI2Dvag.dll errors on your PC.
OR
Do not download ati2dvag.dll from a "DLL download" website. There are many reasons why downloading a DLL file is a bad idea. If you need a copy of ati2dvag.dll, it's best to obtain it from its original, legitimate source.
Note: Start Windows in Safe Mode to complete any of the following steps if you're unable to access Windows normally due to the ati2dvag.dll error.
Restore ati2dvag.dll from the Recycle Bin. The easiest possible cause of a "missing" ati2dvag.dll file is that you've mistakenly deleted it.
If you suspect that you've accidentally deleted ati2dvag.dll but you've already emptied the Recycle Bin, you may be able to recover ati2dvag.dll with a free file recovery program.
Important: Recovering a deleted copy of ati2dvag.dll with a file recovery program is a smart idea only if you're confident you've deleted the file yourself and that it was working properly before you did that.
Run a virus/malware scan of your entire system. Some ati2dvag.dll errors could be related to a virus or other malware infection on your computer that has damaged the DLL file. It's even possible that the ati2dvag.dll error you're seeing is related to a hostile program that's masquerading as the file.
Use System Restore to undo recent system changes. If you suspect that the ati2dvag.dll error was caused by a change made to an important file or configuration, a System Restore could solve the problem.
Reinstall the program that uses the ati2dvag.dll file. If the ati2dvag.dll DLL error occurs when you use a particular program, reinstalling the program should replace the file.
Important: Try your best to complete this step. Reinstalling the program that provides the ati2dvag.dll file, if possible, is a likely solution to this DLL error.
Update the drivers for hardware devices that might be related to ati2dvag.dll. If, for example, you're receiving a "The file ati2dvag.dll is missing" error when you play a 3D video game, try updating the drivers for your video card.
Note: The ati2dvag.dll file may or may not be related to video cards - this was just an example. The key here is to pay very close attention to the context of the error and troubleshoot accordingly.
Roll back a driver to a previously installed version if ati2dvag.dll errors began after updating a particular hardware device's driver.
Run the sfc /scannow System File Checker command to replace a missing or corrupt copy of the ati2dvag.dll file. If this DLL file is provided my Microsoft, the System File Checker tool should restore it.
Install any available Windows updates. Many service packs and other patches replace or update some of the hundreds of Microsoft distributed DLL files on your computer. The ati2dvag.dll file could be included in one of those updates.
Test your memory and then test your hard drive. I've left the majority of hardware troubleshooting to the last step, but your computer's memory and hard drive are easy to test and are the most likely components that might cause ati2dvag.dll errors as they fail.
Repair your installation of Windows. If the individual ati2dvag.dll file troubleshooting advice above is unsuccessful, performing a startup repair or repair installation should restore all Windows DLL files to their working versions.
Use a free registry cleaner to repair ati2dvag.dll related issues in the registry. A free registry cleaner program may be able to help by removing invalid ati2dvag.dll registry entries that might be causing the DLL error.
Perform a clean installation of Windows. A clean install of Windows will erase everything from the hard drive and install a fresh copy of Windows. If none of the steps above correct the ati2dvag.dll error, this should be your next course of action.
Important: All the information on your hard drive will be erased during a clean install. Make sure you've made the best attempt possible to fix the ati2dvag.dll error using a troubleshooting step prior to this one.
Troubleshoot for a hardware problem if any ati2dvag.dll errors persist. After a clean install of Windows, your DLL problem can only be hardware related.
Good luck
If this helps you resolve your problem, please
consider giving me a good rating and a quick
"thanks" or "good job".It will help me as well.
Thank you.
Oct 28, 2010 | ATI Computers & Internet
Run my new anti virus which picked up a problem on somthing called OLEPR032.DLL and gave me the option to delete it which I did (God do I regret doing that). How I keep have a pop up saying that this is...
Open up the help in XP and type do a search for System Restore Wizard.
Follow the instructions and it will give you a choice to restore your system to the way it was at an earlier date. Choose a date from before the problem started. Any programs you have installed since then will need reinstalling but you won't loose any data.
It may also restore the virus in the dll but you can find another way to fix that apart from deleting the file.
If that does not work you can boot from your XP cd and choose the REPAIR option.
I hope this helps
Sep 13, 2009 | Microsoft Windows XP Home Edition
I can not install OfficeSuite. I have Windows Vista home Premium. I had downloaded updates all afternoon and it still shows error 1719 Window installer not correctly installed. Help!
Download:Windows Vista Service Pack 1
I tried personally in WIN-XP worked same applies to Vista.
Error Message:
Error 1719. The Windows Installer Service could not be accessed. You may be running in safe mode or Windows Installer may not be correctly installed. Translation:
This message might appear when you’re trying to add or remove a program that installs via a Windows Installer MSI (Microsoft Software Installation) package file. The Windows Installer Service is the standard method for installing and uninstalling software on Windows XP. It keeps track of all of the components that need to be installed for a particular program to run and ensures that any files that are shared by programs are not removed when one of those programs is uninstalled. The Error 1719 is an indication that some Windows Installer Service files are missing or have become damaged. Solution:
The first thing to try is re-registering Windows Installer in the Windows registry. Make sure that no other programs are running and then click Start, Run, type msiexec /unregister in the Open field, and click OK. Next, click Start, Run, type misexec /regserver in the Open field, and click OK. Restart your computer and try installing or uninstalling again.
If you’re still getting the error message, the next step is to try reinstalling the Windows Installer files. In order to do this, you’ll first need to rename the existing files.
First, click Start, Run, and type msiexec /unregister in the Open field, and click OK.
In My Computer, click Search and locate the following three files: msi.dll, msiexec.exe, and msihnd.dll. They are hidden files so you’ll need to select Search Hidden Files And Folders under More Advanced Options. When you’ve found the files, rename them, by removing the .dll and .exe extensions and replacing them with an .old extension(for example msi.dll becomes msi.old).
Once you’ve renamed the files, WinXP will automatically replace them with a new copy from the dllcache (a hidden folder where copies of important system files are kept in case you mistakenly delete or rename critical system files). Restart your computer and try to install or uninstall the program again.
Finally, if neither of the above processes corrects the problem, boot into Safe Mode, and go through the above steps again, first re-registering and then reinstalling.
or
Go through the following links:
http://www.vistax64.com/vista-general/45784-windows-vista-error-1719-help-3.html
Hope this will be helpfull
Please rate me...
Thanks & Regards.
Nandu
Sep 02, 2008 | Computers & Internet
Windows Xp Problem
if yu have a copy of win xp cd. what u do is insert it in yr cd rom drive then make sure yr first boot device is cd rom. now restat yr computer to boot from cd rom just as if u want to reinstall a new xp os but this time yu will chose the option "repair" on the second blue screen that will come out.
try this and all deleted files will be replaced..
NB: before yu start this process make sure yu back up yr important files to a diff drive say d: or possibly external drives incase things go wrong.
thank u
May 30, 2008 | Microsoft Windows XP Professional
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
