Question about Vivitar ViviCam 35 Digital Camera
Delete how do i delete photos from camara and memory card for my Vivitat 5355 camara
    President:
  • 1,952 Answers
Upload into ur pc and delete from tat
Posted on Sep 14, 2008
  • mohammed marika thambi
    mohammed marika thambi Sep 14, 2008
    One problem remains unsolved:
    How do you empty out the camera, e.g. dlete pics off it.
    Taking out the batteries will not work.
    You
    also can not switch to the delete mode (as the instructions say)
    because it keeps flashing between Lo (LoRes) and occasionally HR
    (HiRes) and can not be switched to any other modes.
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
I lost my Polaroid model 5355 Camera software disc, where can I download the required material?
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Jun 09, 2012 | Polaroid PDC 5355 Digital Camera
We can't recover photos on the camera...somehow the format application was pressed and the photos have disappeared....in the bottom corner of the screen its show the number of photos are still on the...
I had success with this tutorial
How to recover deleted photos from Camera
You'd better remove the memory card from camera, and connect the memory card to computer with a card reader, and then follow above tutorial to perform photo recovery.
Jan 04, 2011 | Vivitar ViviCam 5355 Digital Camera
Fault by i have deleted some photo from my caannon Digital Camara. Can i retrieve the deleted photo ?
First take the memory card out of the camera. Pictures that have been deleted are probably still there, but will be overwritten if you take any more pictures on top of them.
Your camera is not able to undelete pictures, but there are programs for doing this on a computer. You can put the memory card into a card reader attached to a computer, and use an undelete program to recover the deleted files. Undelete programs are available for free download from the internet, try at www.download.com.
If the pictures are very important to you, you might want to seek help from an experienced person.
Nov 13, 2010 | Cannon Cameras
Vivitat 5388 reading instructions and researching set up i think i hit the format button when i looked back to see pictures it said no image help did i erase them?
Yes you did.If you haven't done anything with the card since then, you might have a chance to recover at least some of the pictures. Do a Google search for "format recovery software" and find a program for your computer and operating system. Take the memory card from the camera and put it into a card reader attached to your computer and run the recovery program.
May 26, 2009 | Vivitar ViviCam 5355 Digital Camera
I accidentally deleted pictures from my Vivitar 5355. Is there any way to recover them?
Yes, you can recover deleted pictures from camera. Take out the memory card from camera, and then connect the memory card to computer with a card reader, and then download this camera recovery software called asoftech photo recovery
http://www.softpedia.com/get/System/Back-Up-and-Recovery/Asoftech-Photo-Recovery.shtml
Dec 15, 2008 | Vivitar ViviCam 5355 Digital Camera
Digital camara and memory card
Basically picture files in memory card have corrupt data that's why computer doesn't recognize it.
HP recommends following action...
Close the HP Image Zone or HP Photosmart Software, disconnect the camera from the computer, and reset the camera. (can see this at HP Support)
2nd option is to find some memory card data recovery software on internet and use it to correct data files in memory card.
Thank you.
Oct 03, 2008 | HP Cameras
Camara won t delete photos
Is your memory card locked? It won't let you delete pictures if it is. Check the little switch on the side of the memory card and move it in the opposite direction and then see what happens. Good Luck.
Apr 09, 2008 | Pentax Optio S50 Digital Camera
Olympus SP-320 memory full when 1GB xD picure card in camara
If you download the photos that are on the internal memory to your computer, the next time you take photos it should go to the memory card that is loaded. It worked for me, so I hope that helps
Mar 23, 2008 | Olympus SP-320 Digital Camera
Deleting from memory card
1. Set camera to playback mode and turn on.
2. Push "W" on zoom button (zoom out). (this will show you the index card)
3. Press the delete button (garbage can button)
4. Choose the top option "All In This Folder"
5. Confirm choice.
Nov 25, 2007 | Vivitar ViviCam 35 Digital Camera
Vivitar ViviCam 35 Digital Camera Logo
44 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
