Question about Orion1934 19" TV
Black screen my tv just has a black screen i was watching cable (which works on all other tvs in the house) and it went black, i can still change the channels though it stays on the black screen and DVD's work just fine, what might be the problem?
  • burr9965 Sep 14, 2008
    no i mean no picture, no sound, just a black screen with the number in the corner, but AUX works fine with DVD's, great picture, great sound, just the cable tv is being weird on this tv only, all others in the house work
    Scholar:
  • 173 Answers
You mean no picture just sound?
lost high voltage...... check Horizontal output transitor and flyback.
Posted on Sep 14, 2008
How do i connect many devices (sky box X 2, bt box, etc) to 4 tvs in public house
You will only be allowed to watch 1 channel at a time if you have one box and use coax cable. If you have WI-FI using a sling box and roku (apple TV) adapters you can change the channel at each location but you still will only be able to watch one channel but you could watch the channels available on Roku. Best solution,and also the most expensive , is to have a cable box at each loaction.
Oct 17, 2014 | Televison & Video
Interment or no volume on certain channels.
make sure set not set to sap mode as this can blank audio on certain channels
Sep 03, 2012 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
37" LG flat screen is
With the onset of more and more TVs being hooked up to cable, TV manufacturers didn't need to make the tuners as sensitive because the signal from the Cable Co. was much stronger than the over the air signal. If the other TVs are older they may be just sensitive enough to lock onto the channel signals. You could ask your cable provider to check your available signal in the house to see if there is the proper amount of signal. Some channels can inherently be stronger and when "block converted" (put where the cable company wants the channels) all come thru but some are a bit clearer.
Aug 28, 2011 | LG 42LG30 42 in. LCD HDTV
Screen started to go black while watching the tv.
yes, by canging the bulb. it proboly went out while the television was already dead. you can try but i would hire a proffesional. it may cost 100$ or more.
Oct 11, 2009 | Philips 47PFL3603D LCD TV
Hi! I was watching my TV - Samsung LN-S4092D - and the picture went to black with a few very light horizontal lines for about 30secs. After that it went to complete black. I thought it might just be that...
Hi Bob. The first Board to cause this problen is the Main bd. The next bd to cause this is the T-Con bd which is mounted on the Panel. Since you saw horizontal lines and that you have text on the screen and are missing audio from the tv means that the Main bd has gone bad. Have a trained Samsung tech service your tv. Call 1-8020-Samsung as they can direct you to a Qualified tech in your area.
Jul 05, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Get closed captions on some channels, but not all, even though it is CC
RCA have choices for different methods of CC in user CC menu. Labelled T1, T2, etc. . Different selections are for different types of close caption. Tune to a signal (on your other TV) that has closed caption working.
Tune your RCA to the same signal. Change the T1,T2, etc settings until the closed caption for your signal appears.
If this doesn't work, try connecting analog video or VHF channel 3 (or other specified channel) to the TV. check CC. When TV stations, sat channels, sat receivers, cable boxes etc, convert analog video signals to HD, problems can result. Some equipment causes RCA TVs to do unexpected things with sound and closed caption.
If you use RF or video output, old analog video may look better on CH3 or video than on HD input and the CC will work more consistently. Watch HD signals on HD input, Analog signals on Video in or through the TV tuner . Many HD channels and programs are converted analog video and look poor on TV HD inputs.
easyab
Nov 03, 2008 | JVC AV-48WP30 48" Rear Projection...
Black box appears on tv screen
Check to see that you don't have any channel locks or parental parental permission measures deployed. If so remove them, this includes V-Chip, and Parental lock out on the remote, and check your TVs menu items. What channel are being affected by this problem? Give channel number and channel type.
Thank you,
Shuttle83
Aug 17, 2008 | Orion1934 19" TV
Westinghouse Green Screen
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Jun 10, 2008 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Frozen on a menu screen
Just fixed ours with the same problem. You need to hit the volume buttons on the remote during the time the screen goes black but BEFORE it gives you the "Connect cables" message.It should trick the TV into giving you a blank channel.
Sanyo TVs are made notoriously cheap, and have little glitches like this. Best of luck, space cowboy.
Oct 13, 2007 | Sanyo HT27546 TV
Pls more info; what do you mean tv on, picture froze? you are watching on tv chanel, do you use cable? I can help you but need more details.
Aug 29, 2007 | JVC AV-32D305 32" TV
Orion1934 19" TV Logo
312 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
