Question about Canon Office Equipment & Supplies
I have a Selphy CP510 printer which has stopped working. I have tried printing from both my computers; I have reinstalled the printer-driver on both my computers - nothing seems to work. The operating systems tell me that the printer is connected and ready - but when I send the print instruction, nothing happens. When I first turn on the printer, all the normal whirrs, clicks and noises occur. I have tried putting in a new ink cartridge - still nothing happens. Help, please!
  • 5 more comments
  • NoelMacara Sep 14, 2008
    Thanks, Wiz - but this does not work. I have already done all that (except that my operating system invites me to 'use system online' rather than to set it up. My test page is, of course, a photograph.
    I should also have said in my original post that the printer dialogue informs me that the document is printing; and that the manual tells me that the on/off button (backlit in green) will flash when it is printing - it is not flashing.
    Dear mohammed387,
    I think you have responded to the wrong post. I mentioned no other printers, nor did my reinstallation of the driver quit. Thanks, anyway.
    Dear leethedeuce,
    I have had the printer for about two years. I have not used it for several months; while it has been idle it has been wearing its protective "dust cap".
    One of my computers is running Windows XP Professional V5.1 Build 2600 Service Pack 3; the other is running Vista Home Basic V6.0 Build 6001 Service Pack 1.
    Thank you. (NM)
    Dear all, I have now tried something that I had not attempted previously: printing directly from the camera. Guess what? It works! So if there is anything wrong with the printer, it is only where it connects to the computer. Instead of printing from ZoomBrowserEx (the program which came with the camera and printer) I have tried printing from the Microsoft Phot Editor and that even went so far as to tell me that my photograph had printed successfully! (it hadn't, it was still in the print queue).
  • NoelMacara Sep 15, 2008
    Dear Pattods,
    Dear Pattods,
    Thank you for your suggestions; unfortunately, I have tried them all. I have tried two different USB cables without success, and I have tried printing from three different programs - also without success. The printer and the computer are definitely communicating, as the printer dialogue reports that the printer is online and that the photograph is printing.
    This morning, after yesterday's discovery that I can print photographs that come directly from the camera, I went in to town and bought a male-male USB cable to connect the computer to the same USB connector in the side of the printer that the camera connects to. But that doesn't work at all. The computer does not even detect the printer at the other end of that cable. Pity, 'cos I thought I was being clever.
    Genius:
  • 2,035 Answers
Change the USB cable and then try to print...
Posted on Sep 15, 2008
  • Anand Kumar
    Anand Kumar Sep 16, 2008
    This is due the problem with usb port on the printer it could be defective please get it changed in local printer service center....
    Good luck...
    Genius:
  • 1,665 Answers
Its power supply may be faulty. Better take it to an authorized service station to troubleshoot it's problem.
Posted on Sep 14, 2008
    Novelist:
  • 116 Answers
It sounds like a bad USB connector bud. The USB connectors can go bad. Try a new cable, and see if the printer reacts to printing then. I've seen a lot of USB cables wear their connectors out over time.
Also, reinstall the drivers of course, and try printing from a couple different programs. See if it's just a certain program possibly.
I hope this helps a little bud.
    President:
  • 1,952 Answers
I would suggest that if the installer quit you most likely don't have the driver installed. I downloaded the v4.40 from the Canon web site and it ran fine on my MacBook Pro. And those other printers you mention are the GIMP printers included with OS X, not the result of the installer. I think you need to determine why the installer is failing. If it works, then the printer should add the moment you connect the USB.
download softwsre in tis link
http://alpha02u.c-wss.com/inc/ApplServlet?SV=WWUCA900
  • 4,472 Answers
How long have you owned the camera and how long have you been experiencing this problem? Once I have more information I can assist you further.
Thanks,
Lee
  • Lee A.
    Lee A. Sep 14, 2008
    Also what operating system are you using?
    Thanks,
    Lee
  • Canon Master
  • 6,487 Answers
Try to go to control panel and printer and faxes, and look for your printer there if its there just right click on it then click on setup printer Online , then after that try to do a test print if still not printing power off the printer for 5 minutes and try it again,,
Hope that helps......
  • Mark Gil
    Mark Gil Sep 14, 2008
    If that's the case make sure Pause printing is off or disable on the printer properties that might also cause this problem....
  • Mark Gil
    Did you check the pause printing if its enable or ON on your printer properties? because it only means that the printer is fine and its only a settings of the printer that is causing this problem...
Canon selphy cp510 printing spuneti
Typically the paper pickup rollers need to be cleaned or replaced.
Pickup mechanism may be damaged as well.
If you attempt to clean use 100% isopropyl alcohol with caution.
Nov 22, 2013 | Canon Selphy CP510 Thermal Photo Printer
Canon Selphy C510 connected and has driver but does not print from computer file. Prints fine direct from camera......
copy all the files to the computer then unplug your camera. It will print your files from the computer. Dont forget to check your printing settings.
May 02, 2010 | Canon Selphy CP510 Thermal Photo Printer
I have a Canon Selphy CP510 printer. I have honestly not used it in a few months. I just got back from vacation and wanted to print my photos. I send the pictures from my computer to the printer. It...
If the rollers are working, but its not pulling the paper in, I would suggest, as suggested in another thread, to 'rough up' the rollers in an attempt to give them better grip and maybe a bit more circumference.
May 28, 2009 | Canon Selphy CP510 Thermal Photo Printer
Selphy 510 won't print from computer, print ok from camera ...
Did you download and install the proper Vista driver from Canon's website? If not, I would suggest that. If you have, then try opening the device manager and look for the printer. Reinstall the driver and just direct it to look in the proper folder for it.
Apr 07, 2009 | Canon Selphy CP510 Thermal Photo Printer
Canon Selphy 510
Hi! I have same problem. I opened cover (4 deep screws at the bottom) and found small plastic gear was separated from stepping motor shaft. I fixed it on shaft and my printer started work again. Today I will try to fix same problem on another CP510. I think same reason. Try to do it. Simple. vadim.y.astakhov@gmail.com
Feb 29, 2008 | Canon Selphy CP510 Thermal Photo Printer
Printing marks
I had issues like this, and changed to thinner paper. That solved my problem
Jan 01, 2008 | Canon Selphy CP510 Thermal Photo Printer
Printer won't print on my MacBook
had the exact same problem and was ready to trash printer.  Then I played around with the print settings.  Set picture size to postcard and magically it printed.  Try it
Nov 09, 2007 | Canon Selphy CP510 Thermal Photo Printer
Canon selphy cp510
pull open the blue flap at the front, cartridge goes in there.
Jun 13, 2007 | Canon Selphy CP510 Thermal Photo Printer
44 people viewed this question
old marine
old marine
