Tricity Bendix AW1000W Front Load Washer
Problem for Tricity Bendix AW1000W Front Load Washer
Washing machine makes beeping noise
By dru76 on May 30, 2006
I use a front loading trixity bendix aw100 w its suddenly started giving me a beeping code that means the door is open when its not it won't allow me to programme the washer in anyway even though I've tried cleaning everything out and making sure the door is fully closed. ANy ideas whats wrong?
Solution #1
posted on Jun 04, 2006
Somewhat Helpful)
dovi
Rank: Guru
Rating: 88%, 2495 votes
It sound like a lid switch problem .A defective lid switch will notice of an open door when actually door is physically closed, and will prevent washer's spining and function at all. The switch located inside the machine near the door frame. You should open the top panel (open 2 screws and then slide it out) and you will have an access to it . You can test it by multi-meter (it is an on/off switch). In case of a deffective switch, it should be replaced.
Be aware that you should remove machine's power cable before starting your test !!!!
Good luck !!!
Was this helpful?
Yes
No
Popular Solutions for Tricity Bendix AW1000W Front
Questions and Unsolved Problems for Tricity Bendix AW1000W Front
Do you recommend Tricity Bendix AW1000W Front Load Washer?
Answer
Answer
Hi, My machine stopped due to a power cut. When I tried to turn it on again the light comes on but... (More)
Answer
hi, my mechine( TRICITY BENDIX WASHING MACHINE WHITE) is not getting power?
Answer
the washing machine is only dispelling the water and is not working on any cycle
Answer
ive just bought a dyson hoover belt my daughter put it on but its making a really loud noise now the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Tricity Bendix AW1000W Front...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14885
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
