Question about InFocus ScreenPlay 5700 Multimedia Projector
No green light none starting - InFocus ScreenPlay 5700 Multimedia Projector
It is the C16 Cap on th power supply. its a $1 and change to buy another one at your local electronic store. need a 16v 100 UF cap. then replace it. i can do it for $100
Posted on Sep 28, 2009
  • 74 Answers
Thats a power supply problem. I can fix it. Ebay ID Gtitubro
Posted on Feb 11, 2009
  • 3 Answers
Thanks Micklo!! and everybody else!! Swapped the cap and all works great. Infocus wanted 500 dollars. I could send it to other repair places like Spectronix for 200. After all now it only costed .60 for the cap.
Posted on Dec 02, 2009
I had the rapid flashing green power LED probelm. Followed Micklo's fix and it worked a dream. 100% recommendation.
You will also need a T10 screwdriver to take the SP5700 to pieces which is not hard. Other than that the whole process took about 30 minutes (including the trip to the store to get the 100uF Cap).
Posted on Nov 22, 2009
    Problem Solver:
  • 6 Answers
I had pretty much the exact same problem, I could hear the fans turn barely on when plugging in, but it wouldn't power up. If you look at the power light in dark conditions, the light was doing a rapid flicker. My power supply had failed. I tried to get a replacement board, but the part is no longer available. Projector Doctor would fix it for $395, but there is a person on this board who goes by Neo32 on here and gtitubro on ebay that fixed it for me for $150. I'm a satisfied customer :-)
Posted on Aug 19, 2009
Millineum honda/franklin ave
anti theif problem. try un hooking battery for a few to reset computer
Sep 19, 2017 | 2003 Honda Civic
Macbook pro won't start/charge
It appears as if your power supply is dead. The power supply is inline with your power cord and has a light on it, if I am correct. Since the green light was dim, then went out all together on your power supply, that would indicate that it would not take a charge any longer, and the dim light, down to none, was the rest of your battery draining. Assuming you tried multiple power outlets, my suggestion would to borrow a power source from a friend and check it, or go to best buy/Apple store and have them use one of theirs to see if it comes on.
Sep 25, 2012 | Apple MacBook Pro Laptop Computer with...
DEll Latitude D520 is not starting at all.
Remove the main battery and try again, no change! remove the ram memory one at a time, testing as you go making sure there is one ram stick in the slot at all times. If none of these work, the motherboard is the likely problem and you will need a technician to access.
Jul 21, 2012 | Dell OptiPlex Computers & Internet
Looking for the speaker colors for a 2001 Jeep Grand Cherokee
Item Wire Color Polarity Wire Location
12V red & pink/black + ignition harness
STARTER yellow + ignition harness
IGNITION dk. blue + ignition harness
ACCESSORY red/black + ignition harness
SECOND ACCESSORY none
TACHOMETER *6 *6
POWER LOCK orn/blk - orn/pur *7 5wi door lock switches *1
POWER UNLOCK pnk/blk - pnk/pur *7 5wi door lock switches *1
PARKING LIGHTS + use (-) lights
PARKING LIGHTS - dk. blue/pink *2 steering column
DOOR TRIGGER *4 - *4
HEADLIGHTS yellow *3 at the headlight switch
WIPERS dk. green/red - steering column
LF WINDOW UP/DN lt. blue - white A drivers door lock switch
RF WINDOW UP/DN brown - purple A passengers door lock switch
LR WINDOW UP/DN dk. blue - red/wht B drivers kick panel
RR WINDOW UP/DN gray - dk. green B passengers kick panel
TRUNK/HATCH PIN tan/black - BCM, above diagnostic plug
HOOD PIN none
TRUNK/HATCH RELEASE none
FACTORY ALARM ARM arms with lock *7
FACTORY ALARM DISARM lt. green/orange *7 - *5
HORN TRIGGER gray/orange - steering column
BRAKE WIRE white/tan + drivers kick panel
LOCK MOTOR orange/black drivers door lock switch
UNLOCK MOTOR pink/black drivers door lock switch
DISARM DEFEAT pink/purple passenger kick panel
DISARM NO UNLOCK none
DOME SUPERVISION yellow/dk. green *7 - BCM, above diagnostic plug
SPEED SENSE white/orange PCM, passenger side firewall
SUN ROOF OPEN/CLOSE none
SUN ROOF LIMIT none
LF SPEAKER grn/orn - brn/red at the radio
RF SPEAKER purple - blu/pnk at the radio
LR SPEAKER wht/grn - grn/wht at the radio
RR SPEAKER grn/wht - blu/orn at the radio
RADIO 12V red/white at the radio
RADIO GROUND black at the radio
RADIO SWITCH white/red at the radio
RADIO ILLUMINATE none
POWER ANTENNA none
Notes: NOTE: Jeep vehicles that use a gray ignition key have an immobilizer system that needs to be bypassed when remote starting. Use DEI part number 555C or 555U. *1 Use orange/black and pink/black at the drivers door lock switch to lock and unlock the drivers door. Use orange/purple and pink/purple at the passengers door lock switch to lock and unlock all of the other doors. *2 The dk. blue/pink will flash the hazard lights. They will flash even with a latch input to the wire. The parking lights can be activated by using a 1300 ohm resistor to ground on the yellow headlight wire. *3 Use a 330 ohm resistor to ground for headlight activation. Use 80 ohms to ground on the same wire to operate both the headlights and parking lights. *4 There are 4 separate door triggers wire, one for each door. Use all 4 wires and diode isolate each together. The drivers door is tan/red at the drivers door lock switch. The passenger door is tan/red at the passengers door lock switch. The drivers rear door is tan/orange and the passengers rear door is tan/yellow at the BCM. WHEN USING A 455J INTERFACE MODULE, IT IS NOT NECESSARY TO USE THE SEPARATE TRIGGER WIRES. USE THE YELLOW WIRE AT THE UNDERDASH LIGHT FOR DOOR TRIGGER. *5 Factory alarm disarm requires a 463 ohm resistor to ground on the lt.green/orange wire at the drivers door lock switch, you MUST use a relay. *6 The 4.7L motor has a separate coil for each cylinder. Go to any coil and use any wire that is NOT dk. green/orange. On the 4.0L motor use any of the tan/stripe wires at the coil pack, or go to one of the fuel injector and use the wire that is NOT dk. green/orange. *7 Can also use DEI part number 455J door lock interface control module. This will control door lock, unlock, arm, disarm, dome light supervision and more.
Sep 26, 2011 | Car Audio & Video
1999 Saturn SL2 electrical problems with fog lights, cooling fan, ac, running lights. None of them are working.
first place i would start are the MAXIfuses in the main fuse panel in the engine compartment, they are huge green fuses that should be 30A. but they control a large array of things.
Dec 07, 2009 | 1999 Saturn SL
What can i do to fix this
it does that sometimes just unplug the system and it should be working just fine
Jul 29, 2009 | Microsoft Xbox 360 Console
PS3 light turns GREEN, w/ blinkin BLUE, to YELLOW, to flashin RED
it is fried and needs repairs if you break the seal by trying it yourself you void the warrany
Mar 15, 2009 | Sony Playstation 3 40GB System Console
Inspiron 9200 cannot power up.
Start by checking the power supply with an ohm meter for the correct output, however, this is generally a problem with the battery or a memory chip. Start by removing the battery and starting up on the power supply only. Dell batteries are notorious for causing a no start. Then try removing the memory and try one chip at a time in both slots. If none of these work, then I'm afraid you have a failed system board component, and you will probably want to take it in for a professional diagnostics. Also, you can find a diagnostics light codes list for your machine at Dell's support site.
Aug 06, 2008 | Dell Inspiron 9200 Notebook
E-Mu 0404 USB Sound Card power ?
Do you have the speaker lead plugged into correct plug on back of computer the color is usually a green one
Jul 17, 2008 | E-Mu 0404 Sound Card
Flashing green light
1. Pls check and inspect the Lamp unit.
2. If Lamp unit is okay, Then the Problem is with
either with Ballast unit or the DMD Module.
Regards
Viren
May 31, 2008 | Sharp XR-10X Multimedia Projector
InFocus ScreenPlay 5700 Multimedia Projector Logo
389 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
