Question about HP Pavilion M70 17" CRT Monitor
Green screen hi when i turn my monitor on somtimes everything goes green,like theres no colour.i can get it back to normal by tapping the side of the monitor.but lately its getting worse.
  • Anonymous Aug 20, 2008
    The problem with my HP monitor is that it turns pink (rather than green). But the problem goes away on its own after some time.
    I don't have the 'tap the monitor to regain normal color' solution available, but if I passively continue with whatever I'm doing the problem will eventually pass.
    A friend suggested that it might be helpful to degauss the monitor, but that doesn't do anything to fix the pink hue.
From your lines... 'Tapping the side of the monitor' Reminds me cracked solder joints. You need to check for this.
First open the Chassis and narrow down the area of the circuit board where exactly applying force makes the monitor fine and in that area of board / around that area look for cracked solders. Definitely this will help you.
Posted on Jan 10, 2008
My Samsung LCD TV slowly flahses colours, each about 2-4 seconds
hi,
your lcd is in test mode. you may try off the power. press and hold menu + source + power on.
this should go back to normal mode.
Apr 01, 2010 | Samsung LA40M81/BDX 40 in. LCD TV
Green horizontal
I believe that you must reset the colors of the screen by the buttons on it or try to set colors by the software that the product came with it if any. There should be a setting to configure the 4 basic colours like red green black etc. Try to adjust green. If nothing helpes go the monitor back to test it by the store you bought it if there is warranty. Hope that helped!
Mar 23, 2010 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
The sceen turns a yellowy tone and then goes back to normal
Possibly there's an internal electronic part/s of your monitor that is cold soldered / defective. I suggest to bring it to an authorized service center to fix the problem. regards
May 29, 2009 | Acer P223W 22 inch Monitor
Dell Monitor goes blank, green light still on.
Have you tried connecting that monitor to another PC. It sounds like you may have a problem with the monitor itself (component failure, heat problem, etc)
Nov 20, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Monitor color changed
there may 2 problems
1 ) Problem with the Data Cable connector the Pins might be damaged try to arrange them if disturbed / bend . if Broken change the connector.
2) Open the monitor see the soldering carefully you can locate out the dry solders easily by seeing the flux colour around it . just put the solder over there..by soldering gun to all places where u can see the dry solder.
Sep 05, 2008 | Gateway FPD2275W LCD Monitor
Bart simpson is green
Hi there.
Here goes.
What you do is first get into tube lenses and wipe them clean.
Then turn down the colour to black and white.
The simplest way to adjust the three separate colours is to get to the hv splitter box and adjust every screen pot until you get a black and white pic.
Then turn your colour back up and you should see a good result.
Jul 16, 2008 | Televison & Video
Screen split into 2 colours - vertical split
I think it is degaussing problem if any thing is lying which has magnet please remove it. &then put of monitor for 15 minutes & then put on again.do not move when it is on. please let me if it gets ok good luck
Sep 09, 2007 | Philips 170B4MG 17" LCD Monitor
Screen also turned blue!!
check cable and resistor that is giving 2number pins signals to video amp. ic and driver of green signal.
Aug 15, 2006 | LG Studioworks 45 14" CRT Monitor
HP Pavilion M70 17" CRT Monitor Logo
95 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
