Question about Onkyo HT-SR800 System
Onkyo HT-SR800 the surround speakers are not blasting
I did the setup using the audessy setup. All the speakers were producing sound during that time. But when a watch a movie, I get very little to no sound the surround speakers. They are just dumm. Only the front 3 speakers blast.
With this reason I am not able to enjoy the real surround sound.
Help me in resloving this issue.
  • fairlane666 Sep 27, 2008
    this system sucks,cant hardly hear rear speakers,even turned all the way up. now mine are snapping and one is totally dead. not even a year old yet.
I had the same problem and fixed it by manually setting the surround speakers changing the Level Cal to +12dB. You will immediately notice a significant increase in volume and may need to back down on the dB's. What a diffence it makes!
Posted on Dec 17, 2008
Onkyo HT-R693 (HT-S7700) receiver will play video but no audio on Netflix and YouTube. However, sound comes through when connected to Comcast cable and even Pandora. I have tried the different channels...
  • Check your cable connections
  • set the input selector to the proper component sources your using.
  • set your speaker settings to either 5.1 or 7.1, according to your speaker configuration via Onkyo's AccuEQ automatic setup tool- because the same binding posts can be used for hooking up the Atmos height or surround back speakers; you'll need to tell the Onkyo system which setup you're using.
Mar 08, 2015 | Onkyo Audio Players & Recorders
Toslink and 7.1 surround
For you to process 7.1 you need another pair of speakers. Your setup is 5.1 If you want to see some different 7.1 setups just google images of 7.1 speaker setups. Seeing it it easier than explaining it. Hope this helps
Jun 25, 2009 | Denon AVR-886 Receiver
No surround sound on ps3
Set the sound out put on ps3 to the optical out put then set sound on ps3 to give you dolby digital,dts,aac etc.
PS, do not set the hrtz range above 100 as this can damage your speakers.
hope this helps.
CABLE GUY.
Jan 05, 2009 | Onkyo HT-SR800 System
Cutting off and stayin in Stand by mode
To me it sounds like you might have blown a channel(s). The speakers that you are using with unit, did they come with it? If not you need to check the ohms of the speakers. It looks like the Onkyo HT-SR800 can only handle a minimum of 8 ohms. If your unit is under warranty definately send it in for repair
Jun 03, 2008 | Onkyo HT-SR800 System
Only one surround back speaker works
It sounds to me like one of your speakers may be mis-wired. Try reversing the speaker wire (don't switch right-for left, but switch negative for positive) and see if that changes anything.
Dec 31, 2007 | Onkyo HT-SR800 System
Subwoofer volume and sound
i had the same problem when i tried to adjust speaker output levels, distance and equalizer manually without using audessy setup..so i reset everything to factory setting (0s)..and then ran
audessy setup..reduce volume on your subwoofer to slightly above minimum(behind the subwoofer) before running the setup..once audessy setup is completed successfully..i started changing setup
manually..changed speaker config for front speaker to small (it is set as large by audessy setup), this should automatically adjust center and other speaker configuration (if not make sure to set them to small as well), then set the cross over frequency to 120..increase the volume on your subwoofer and now you should hear it fire..if this does not help..try playing some rock music with all channel streo mode..if your subwoofer does not fire even for this..then take the system back for exchange..
Dec 28, 2007 | Onkyo HT-SR800 System
VOLUME CONTROL
Try to increase the speaker levels through setup. I had the same problem and I increased the speaker level from 0dB to +10dB, and seems like it is better now. Let me know how you make out.
Nov 29, 2007 | Onkyo HT-SR800 System
TV to Reciever Sound Problems
MAke sure your channel selection is correct.
Sep 17, 2007 | Onkyo HT-SR800 System
Sound only out of 4 speakers
Make sure that there are no wires crossing do you have different speakers that you can test with try those for each channel. make sure that speaker set A is selected
Aug 20, 2007 | Onkyo HT-SR800 System
Surround sound
It must be about the sound quality need of your amplifier. The sound processor simply needs to get clear signals from sources such as fm/am receiver, dvd/cd players etc. in order to manage'em to give you the optimum surround sound. If the fm receiver has an "FM MUTE" option, I recommend that you turn it on. By doing so, you'll receive only good quality fm stations, furthermore your amplifier will let you get surround sound. The second issue you mentioned has its own answer inside. Use a "new" cd player, you can get optical cables, digital coax cables to improve the performance if you like..
Jun 07, 2007 | Onkyo HT-SR800 System
Onkyo HT-SR800 System Logo
340 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
