Question about Symphonic Televison & Video
White lines at top of tv
There are white lines at the top of the tv that somtimes look like image folds over about 2in, i,ve similar posts here saying its a capasitor, could you tell me which one it might be on this model tv, or where it might be located on the board, or diagrams for it and it it could be checked with volt ohm meter..
  • tigger8232 Sep 14, 2008
    it's for symphonic st27s3
  • tigger8232 Sep 22, 2008
    how do i bridge with new caps or with wire
    Scholar:
  • 173 Answers
Its a capacitor in the Vertical Curcuit almost stake my life on it.. but have seen resistors off value and the Vertical IC itself..... bridge the caps around vertal and fly.
Posted on Sep 14, 2008
  • larry hanson
    larry hanson Oct 08, 2008
    take a high value cap and put it across the bottom of board ..noting polarities... and use a mirror to see if the lines disappear. this is usually done by a highly skilled tech ... for it easy to slipp and damage more parts.
I'm am having image problems with an LG 60pz750 plasma tv. There is intermittent colored shadows/snow appearing in the screen especially in white areas. I've read possible y or z board.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Nov 13, 2016 | LG 60PZ750 60 in. 3D HD-Ready Plasma TV
The top of the screen is folded over about 2in from the top and it starts to blink and the fouces starts to fade what can i do to fix this problema/
Vertical scan output section circuit fault. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Jun 02, 2016 | Televison & Video
Top half of tv is white it started with just a line from side to side and has become worst
half the picture on my tv screen turned completely white. ' IGN ...
www.ign.com > Boards > Community Central > The Vestibule
IGN
May 3, 2014 - 7 posts - ‎4 authors
what half? down the middle or every line of pixels? did you google the issue with your tvmodel? my samsung has issues with bad capacitors ...
samsung led ua40d5000 tv half screen turning white - Forums - CNET
www.cnet.com > Forums > Samsung
CNETMay 16, 2013 - samsung led ua40d5000 tv half screen turning white ... Interestingly after half an hour if i push back the TV from top left corner then problem ... Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Dark shade appears in the below half of the LED TV screen
Oct 23, 2014
LED Samsung Smart TV half screen lose in colour
Sep 11, 2013
Runco PL-61cx plasma tv, top half goes black
Jan 13, 2010
More results from www.cnet.com
LCD TV Samsung LN32C450 top half screen problem ...
? 3:58
https://www.youtube.com/watch?v=SawMHKpsYOA
Jun 8, 2015 - Uploaded by Vladimir P.
This is for my Samsung LN32C450E1DXZA that is having major image issues with the top half of the screen ...
Samsung ScreenTartan/Plaid Pattern on top half of screen ...
? 1:22
https://www.youtube.com/watch?v=ue9IQwj7CVM
Feb 03, 2016 | Televison & Video
Samsung ln55a950. There are black horizontal lines that start of strongest on the very right of the screen and fade to gone at about the middle. The lines are maybe 3 pixels tall before fading, but they...
I have similar issues with my Samsung TV model LN55A950... all I did was take the back cover off...unplugged the two wide ribbon cables of the panel from the T-Con board, then turned it on...I waited for a minute until everything normalized. at first, all i see were similar lines...horizontal pin stripes on white background...white background because the panel is not connected to any image source. Then all lines are gone, after the 'normalization." you should only see white all through out. I then turned the unit off...connected the two cables back, turned it back on...voila! my TV is back to normal viewing, no more lines!!!
Jul 06, 2011 | Samsung LN55A950 55 in. LCD TV
I have two 2in vertical lines going down my TV. :(
If you wish to get some details; visit the site linked here. Pull up older posts.
Jun 06, 2017 | Daewoo DP42SM 42 in. HD-Ready Plasma...
White lines at top of av27230
Your posted description is a known (common) problem for the JAV-27230 and should be easily repaired. The vertical capacitor (C424 - 100uf/35V) needs to be replaced. It is relatively cheap and can be bought from any electronics parts store.
in some instances, it could be the vertical IC starting to fail or even a simple case of cold solder.
As always, extreme care when repairing the insides of a TV unit since HV can still be present even when off and unplug. A little knowledge of electronic components and use of a soldering iron should do just fine. Should you not be comfortable doing a DIY, then perhaps you can ask the assistance of a buddy who has some soldering experience.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
good luck and kind regards.
Feb 10, 2008 | JVC AV-27230 27" TV
White Horizontal Lines near the top of my Screen
this symptom is what we called vertical fold-over. vertical fold-over is characterised by a white horizontal bar on the bottom or top of the raster due to the concentration or compression of the trace lines. it an image is present, the bottom or top portion is fold over. this is caused by a vertical deflection current with poor linearity, which compresses the trace lines at the bottom or top of the screen. this symptom is is caused by a defective sawtooth wave genetator circuit, or improper biasing or defective feedback circuit of the vertical drive or vertical output transistor/ic. the negative feedback circuit in vertical deflection circuit compensates for the linearity of the trace portion of the sawtooth wave. a decrease in the capacitance of the sawtooth generator capacitor is usually the trouble. but if you do not understand anything what i have written here, better bring it to a qualified tv technician for your own safety also. good luck!
Mar 01, 2007 | JVC TM-2703SU 27" TV
Panasonic tv has white lines at top of screen
suspect it's 1 or a couple of bad capacitors in the vertical deflection circuit the caps are in the 400 series, c400,c401,c402, etc... check or replace c414,c418 & c417
Aug 30, 2006 | Panasonic CT2722H TV
Televison & Video Logo
94 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
