Question about Palm Tungsten E2 Handheld
(Sys 0505) (0,746)
I get this message every time I shut down my Palm E2. (Sys 0505) (0, 746)
If I do not touch the (OK) message screen, I have to do a soft reset to restart PDA.
What old programs do I have to remove??
SOURCE: Palm z22 touch screen screwed up
clean the touch screen and go under the edges w/ a bankcard to remove any dirt.
then do a hard reset -- worked for my z22
c boekema
Posted on Aug 06, 2008
  • 89 Answers
SOURCE: screws for palm tungsten e2
T5 or T6
Posted on Mar 13, 2009
SOURCE: Palm tungsten E2 touch screen unresponsive
I noticed this problem with mine and solved it by loosening the 4(four) T5 screws in the back. The problem is caused by a swollen battery. When the PDA is left charging for extensive periods of time, as mine was(several months of inactivity and never thought to unplug it), the battery will swell. It's still a good battery and holds a charge, but the increased girth presses on the internal boards of the PDA causing the screen to register a continuous "touch" and therefore seems locked. It's actually waiting for the phantom touch to release so it can act. Unscrewing the fasteners allows the body to expand, thereby releasing the pressure on the screen and letting the phantom touch go away. I'm going to see how well my e2 does without the screws in it at all for a few days. The front and back panels have "clips" molded into them which hold to the side frames, keeping it closed. But the fasteners are there to ensure the PDA doesn't fall apart all together. So, wish me luck. I'll report back in a few days and update this.
Posted on May 05, 2009
  • 4338 Answers
SOURCE: Still getting error (sys 0505) 0, 841 on Palm TX
Try a hard reset and wiping it out. Then resync it with the newest Palm Desktop manager 6.2
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Jul 27, 2009
  • 346 Answers
SOURCE: when trying to sync, error message reads (sys
Try to perform a System Reset (see article linked below). If it works to break the loop, you should then be able to delete the offending "My Palm" software and perform a Hotsync to backup your data to your desktop.
If that doesn't break the loop, you'll have to perform another Hard Reset. Sometimes, a Hard Reset takes a couple of tries to get it right, since it's easier to do it wrong than to do it right.
This article discusses the various types of Reset for different Palm devices:
Until you break the TX out of its loop, you won't be able to get the data from it.
To see the Palm OS version running on your TX, enter the Menu, select Info, then Version.
To Get Out Of A Loop:
  1. Perform a SYSTEM RESET by doing the following:
a) Press the UP Button
b) And THEN press and release the RESET Button
c) When you see the second Logo (Palm Powered) release the UP Button
d) Now check if your SYSTEM RESET worked by going to Beam Receive. If it goes back to Off even after you put it to On it means you were successful
2. Now Perform A SOFT RESET by pressing and releasing the button in the back once
  1. After a soft reset, a logo screen appears, followed shortly by a Preferences screen asking you to set time and date.
  1. If a soft reset does not break it out of the loop, you may need to try one of the other resets below.
  1. Do an INCOMPLETE HARD RESET by holding down the power (on/off) button on your device.
  1. While holding down the power button, Press and release the reset button on the back of your handheld device
  1. Keep the power button pressed and release it when the “Palm Powered” logo appears.
  1. A message will now appear warning that you are about to “Erase All Data”. And this will happen if you press UP or DOWN.
  1. Instead you press left or right to begin a soft reset, leaving your data intact.
  1. Your device will then take you through a series of screens to calibrate the digitizer and verify the time and date.
Sorry this was so long, I tried to put everything down that might help you.
Posted on Aug 03, 2009
I have a tungsten E2 and rep;aced the battery, after charging it overnight and doing a soft reset I am only getting the start up screen asking for password. On the screen are the number pad,...
Still not working, decided to purchase a new one for mine was 3 years old and it was not worth investing a lot of money to fix it.
Thank you for your help............snicksandsam
Oct 15, 2009 | Palm Tungsten E2 Handheld
My Palm tungsten E2 hand held PDA is totally frozen and locked up
Best thing to do here is to remove any memory cards etc.. and do a hard reset - seems like soft reset will or has not worked...
Press and hold the power button - keep it pressed and gently press the reset button on the back of the handheld.
Wait for the Palm Powered logo to appear and release the power button.
You should get a message warning about erasing all data. Press up on your 5-way navigator to reset.
This will erase all data inlcuding user information from the device, but synchronizing should get it all back - but you will loose anything that was not recently sync'd
good luck
May 27, 2009 | Palm Tungsten E2 Handheld
Tungstun e2 touch screen not working
Perform hard reset. Press on and reset at same time. If this was helpful, please post as such. If it fixed it.....fixya. TY
Jan 19, 2009 | Palm Tungsten E2 Handheld
More applications than I should have
On your main screen touch the menu icon (bottom right in your graffiti box). This will open your drop down menu. Touch "delete" and a list of programs, etc will appear. Select one at a time and then press delete.
Hope this helps
May 21, 2008 | Palm Tungsten E2 (Multilingual) Handheld
Wrong command when I touch the screen
Your battery is perfect no need of changing it.quite often touch screen gradually looses fades out,so u use it till it completely fades out and then get ur display changed.
Jan 16, 2008 | Palm Tungsten E2 Handheld
Won't shut down
There are a couple of things you can try.
1- Poke the hole in the back where it says reset.
This will in essence reboot your Palm.
2- Make sure the Auto-Off after: is set to 2 minutes by going into the Preferences, Power section.
3- If your Palm is not holding charge, connect the Palm to charge it. Turn the Palm on and make sure the battery at the top has a lightning bolt going through it. This will let you know it is charging. Then, push the reset hole in the back to reset the Palm. This should reset the charging mechanism in the Palm and allow your battery to hold power.
If the Palm does not hold power after step 3, you may need to see about getting it serviced.
Jan 04, 2008 | Palm Tungsten E2 Handheld
Palm Tungsten E2 Handheld Logo
47 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
