Question about Canon PowerShot A410 Digital Camera
Canon A620 No Picture
First problem I have had with this camera but when I turn it on in camera mode the lense opens up, but the screen is black I can see the display and turn that off and on but I can't see what I am taking a picture of and when I snapped a picture it was blank. When I turn it to view the photos all my pictures are there and I can view them. My camera is probably a couple years old is all. It has not been dropped. Any ideas????? PH when I turn it on in camera mode the lense opens up, but the screen is black I can see the display and turn that off and on but I can't see what I am taking a picture of and when I snapped a picture it the everything is black. When I turn it to view the photos and videos all i can view is color black. My camera is probably a couple years old is all. It has not been dropped. please help!
  • Canon Master
  • 4,738 Answers
First try hitting the DISP button (sorry if this offends, but many people have made this mistake). If this doesn't help, next try resetting the camera. Turn on the camera, and hold the menu button for at least five seconds. Believe reset is also in the menus.
If the above doesn't help, then unfortunately this sounds like your CCD image sensor may have failed. This would then require professional repair. Contact Canon at 1-800-OK-CANON.
Posted on Sep 14, 2008
I HAVE A CANON A620 THE SCREEN WENT BLACK. CAN SOMEONE HELP ME OUT? I READ ON LINE COULD BE A STICK SHUTTLER.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jan 10, 2011 | Canon PowerShot A620 Digital Camera
Canon a620. no image on display and pictures turn out black
Oct 24, 2010 | Canon PowerShot A620 Digital Camera
Canon A620 is taking black images/ Can't see images on screen
First try pressing the DISP or DISPLAY button on the back of your camera. If that didn't fix it... A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 28, 2010 | Canon PowerShot A620 Digital Camera
My Canon PowerShot A620 has a black screen, any ideas on how I can fix this? I can't even take pictures, all of them come out black
My A620 JUST started doing the same exact thing last night. LCD works, lens works... but something possibly wrong w/the shutter so it won't open.. everything black.
Jan 05, 2010 | Canon PowerShot A620 Digital Camera
Power Shot A620 Canon 7.1 mega pixel 3 years
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Dec 30, 2009 | Canon PowerShot A620 Digital Camera
Power shot a620. screen is not showing pictures, all icons are there but screen is black? Help please!!
Sounds like you might have accidentally pressed the DISPLAY button on the back of your camera. It turns the screen on and off to save batteries. Turn on your camera, and press this button once again to turn the screen back on.
But if your camera is also taking black pictures,
a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Jul 30, 2009 | Canon PowerShot A620 Digital Camera
View screen black when on & no longer takes photo's
Sounds like a dead CCD. Contact your local Canon service center.
Tom
Jul 24, 2009 | Canon PowerShot S3 IS Digital Camera
Screen will not read lense
Sounds like you accidentally pressed the DISP or DISPLAY button on the back. This manually turns the screen on/off to save batteries. Just press it one more time to turn it back on.
Apr 25, 2009 | Canon Cameras
Canon powershot A620 black screen can't take pictures
A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Dec 25, 2008 | Canon PowerShot A620 Digital Camera
When your on a photo taking setting and your camera isn't picking up what your seeing...this isnt a problem.
simply press the "disp" button until your picture shows up and the extra features for that setting.
Aug 15, 2008 | Canon PowerShot A410 Digital Camera
Canon PowerShot A410 Digital Camera Logo
237 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
