Question about SanDisk Sansa m230 MP3 Player
Player shuts itself off
The initializing screen and finalizing update show on the screen and then the whole thing shuts down.
All MP3's are not equal. The Sandisk only recognises 128Kbps. If you load 96Kbps you will get the "Finalizing Update" error. The solution.........disconnect the battery and then reinsert it and immediately connect to the USB connection. Look through the library of recordings and somewhere there will be a non-kosher MP3 file. Delete it and your trouble is over. roberted
Posted on Dec 28, 2006
    Problem Solver:
  • 11 Answers
Obvious stuff first. Check battery. Make sure the spring is making contact. Seeing as you are getting some power I would say thats not an issue. Connect it to a PC and make sure it has songs of the correct format. WMA and MP3. If its not a matter of incorrect file formats, it would be an internal problem. Possibly a short somewhere on the board. I am not sure as to the ease of repair on these players. SO I would look at sending it to the manufacturer.
Posted on Jul 01, 2006
My rca m4304-A mp3 player says profiling requires 20mb free space shutting down and then when i try to hook it up to the computer it will not show that it is hooked to the computer and goes off
Restoring RCA M4304A Recorder Firmware
Symtom: recorder shows OPAL splash screen, then shows "profiling requires20mb of free space, shutting down" and then shuts down. Recorder cannot be accessed by windows or the RCA easyrip software.
Solution: Use the firmware update found here: http://www.voxxsupport.com/images/downloads/OPAL_066F_85A4_85A5_0_1140_SIG.EXE
This update needs to be ran on an xp computer running 32 bitOS. It was tested in a Win 7 64bitmachine and proven to not work.
Necessary steps taken to get the firmware to properlyrestore were as follows:
1. Hold in the power (menu) button for 10 seconds(the splash screen will show and it will give the error message, ignore it)
2. While still holding the power button, press theplay/pause button and hold down.
3. Release the power button while still holdingdown the play/pause button and wait 5 seconds.
4. While still holding the play/pause button plugin the usb cable to the recorder. Continue to hold the play/pause button foranother 5 seconds after plugging the cable in.
5. Release the play pause button then launch theEXE for the firmware update. Minimize the instruction screen so you can see thefull update screen.
6. Leave the format checkbox checked (check it ifit isn't checked) formatting is crucial to this working.
7. Once the status in the update window changesfrom initializing to ready click start to update the recorder. It will go through formatting, then updating.
8. Once the status shows complete disconnect therecorder and with any luck the recorder is usable again. The media files will obviously have to bereloaded, but the recording is functional at least.
Sep 21, 2010 | RCA M4204 MP3 Player
My RCA Opal again...
I had the same problem too. I was about to give up and throw this RCA player away but I it is only 5 weeks old, I got it for christmas and would feel terrible letting it go because of this stupid problem. I noticed soo many other people had this same problem, and since I spend over an hour and got it fixed, I had to share my solution and hopefully help others. I must have tried bwelliver's solution 10 to 20 times before I finally figured out the pattern to doing it. Unfortunately, i should have gone down and noticed what clklause has recommended, which was to ensure that the power is turned off before plugging in the RCA mp3 player.
All I did was download the firmware from the link that bwelliver linked to, unplugged and turned off my RCA M4208GR-8 player, then 1) I ran the firmware software 2) held down the Play(center button) on the RCA mp3 player that the power is still TURNED OFF, and 3) plugged in the player to the USB plug right after starting the firmware program. I watched the firmware program on the screen and noticed it would go from "searching" to "initializing" and I immediately released the Play(center button) on the RCA player and sure enough, the RCA player would begin initializing, and I was able to click Start on the Firmware program from the PC.
Hope this helps
Jan 17, 2009 | RCA M4204 MP3 Player
LG TV 42LB1DR INITIALIZATION PROBLEM
mine did the same thing once, I unplugged it long enough to make sure it shuts down all the way and let it reset itself. Turned it back on and it was and is fine [it's been 2 mos. now] That worked this time.
Last time one of my kids spilled something down the back and it gradually went out. 600.00 to have the part replaced.
oz
Jan 01, 2009 | LG DBRH197H DVD Player/HDD Recorder
There could be a damage or corrupted file in the sansa clip. I suggest to reformat the player. To reformat the player. First turn off the player. Then slide the power switch down it will be showing red, now press and hold the center or the middle button on the player while connecting the player to the computer. It will be detected as a drive on your computer, now right click on it and choose FORMAT, make sure the file system is FAT32 then click start to continue formatting the player. This will erase or remove all the songs on your player but this will fix the problem that you are having
Aug 22, 2008 | SanDisk Sansa Clip MP3 Player
It keeps intializing
Install and run the Philips Device Manager.
Press and hold the [VOL+] button on the player whilst connecting to the PC.
Philips Device Manager will show the device connected in repair mode. Release the [VOL+] button and follow the on-screen prompts.
This will format the player and re-flash the firmware.
Disconnect the player when finished, and re-start it. It should briefly show initiallizing and then shut down.
Re-start the player again, and it should show "updating", then start up.
Occasionally this will cure the problem. If it doesn't try it 2 or 3 times.
If it still doesn't work, then unfortunately you will have to take it back, as there is no other known cure.
Mar 14, 2008 | Philips SA6025 Digital Media Player
Initializing keeps flashing on and off in a blue screen
Uninstall the existing Device Manager.
Download the latest Device Manager software for this device from www.p4c.philips.com and install this.
Repair the player using the updated software.
If the problem still persists, try the update once more.
If this still doesn't work, then the main PCB is faulty and will have to be replaced.
If the repair does work, the player briefly shows a message on screen when restarted, then shuts down again.
You then need to restart the player again and it shows Updating, and then goes to the main menu.
Feb 22, 2008 | Philips GOGEAR SA6045 MP3 Player
Iniatializing keeps flashing on and off
RCA Lyra MC5102A
connect lyra to computer
go to my computer on your start menu
lyra will show up on other devices or portable devices
double click on the lyra icon
this will bring up another lyra icon right click on that
go down to the option format and select that
you will lose all of your music
solved my problem two hours after it started
Aug 31, 2007 | RCA Lyra RD2765 MP3 Player
I Cant start,I cant connect to my pc
hi friend hi me too had the same problem, but for me it was not working merely more than four months and today(2007 june 12) finally i tried it with my PC. What i did i connected it with my PC with locking the device (using the hold button in the opp side of the menu button it has to show the orange face once u pushed it off)more than one hour with the screen of "San disk Initilizing", after an hour i tried with san disk firmware and many tools nothing to do. Finally what i did "realy its amazing to u all,even u people cant beleive it, but it is true", simply i pressed the menu button twice or thrice and no result then i had beat the device it has been worked fine its showned the screen as USB connected by MSC.
May 31, 2007 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa m230 MP3 Player Logo
158 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
