Question about Epson Perfection 3170 Flatbed Scanner
Epson Perfection 3170 negatives - stopped working correctly
In the middle of scanning a bunch of color negatives, all of a sudden my Epson Perfection 3170 stopped scanning them correctly. I get a blurry mess in the preview image that looks sort of like a stack of negatives all on top of one another (OK, not the best description). I've tried turning the scanner on and off, changing settings, etc., but nothing seems to get it back to normal. It scans positive images just fine at the same time. Any ideas?
  • ichant Apr 15, 2009
    I was scanning B&W 2-1/4 Sq. negative and after a few normal scans it is now previewing and scanning wavey images, almost posterized. Tech support reading from what ever they read from, determined I needed to take it for service. I don't feel at the moment they have complete knowledge on their (1st line phone support) level. Somebody talk to me! .......thanks. .....peter
jackboy
  • 2985 Answers
SOURCE: Epson Perfection V100 Photo flatbed scanner
I would not think Norton is the problem but one can never be sure - Uninstall Norton to prove one way or the other Then come back
Posted on Sep 01, 2007
SOURCE: Negative Scanning Problem Using Epson Scan Software
Make sure the rectangular slots at either end of the film frame are not obstructed or covered in any way. When I attempted to scan color negatives I had the same darkness problem in the scanned image. When I cleared those rectangular slots, everything was fine. I hope this helps.
Posted on Oct 18, 2008
  • 2668 Answers
SOURCE: Epson Scanner Perfection 3170 can I down load a
Go here
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=25021&prodoid=35836301
Posted on Aug 31, 2009
ohms
  • 1879 Answers
SOURCE: Epson Perfection 3170 scanner will not turn on.
having the scanner repaired will cost more than a new one.
Posted on Sep 07, 2009
rioglen
  • 95 Answers
SOURCE: Software available with Perfection 3170 Scanner?
yes this option is inclussive with your epson scan program, learn to play with the different modes of the scanner ex: professional, home mode etc. usually these modes have these options.
Posted on Sep 14, 2009
Epson 3170 scanner - have been scanning fine for over 2 years now suddenly says 'unable to write to file' ?! Actually seems to scan OK in preview just will not write file....... any ideas ? Scott
Check to see where it is writing to (which directory) and make sure the directory exists and you do not have duplicate filenames. Check the free space on the drive you are writing to. Run an error check on the drive. If it is a shared folder/directory then check your permissions.
Mar 24, 2011 | Epson Perfection 3170 Flatbed Scanner
Sep 08, 2009 | Epson Perfection 3170 Flatbed Scanner
Sep 07, 2009 | Epson Perfection 3170 Flatbed Scanner
Go here
Aug 31, 2009 | Epson Perfection 3170 Flatbed Scanner
Negative images
Check the settings and try to update the software/drivers if available from manufecturer's website. (ehteshamhusain@gmail.com)
Jul 19, 2009 | Epson Perfection 4180 Photo Flatbed...
Epson Perfection 4180 won't scan my negatives
cant scan film with epson perfection 4180. how can this be fixed?
Jun 10, 2009 | Epson Perfection 4180 Photo Flatbed...
Scanning 110 Negatives
It should work in the 120 film holder, though I doubt you would get very good results unless at a very high dpi setting. You would need to crop the image using the marquee in preview mode.
Jan 19, 2008 | Epson Perfection 3170 Flatbed Scanner
35mm Color Slides
Here they are for Mac and PC
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you receive a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Mar 15, 2007 | Epson Perfection 3170 Flatbed Scanner
Epson Perfection 3170 Flatbed Scanner Logo
124 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
