Question about Electrolux EW1200i Front Load Washer / Dryer
Machine refills with water after cycle
My machine has just started refilling with water after use it takes about 5 hrs to come above the drum any suggestions?
  • 641 Answers
Check first that water supply pipe isn't bend. Water supply to the dishwasher is done through an electromagnet valve,loocated at the pipe's enterance to the machine. Test that it get power (with a multi- meter). In case it get power and dosen't work - You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from the machine before doing it !!!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace the valve. Good luck !
Posted on May 30, 2006
Washing machine starts to wash fine until it goes onto rinse, it starts to fine but then goes back to the begining of the wash cycle and it also doesn't take the conditioner
sounds like the water pressure switch is misreading the water level cycle and refilling and washing over and over? or u could have a bad control board?
Sep 28, 2014 | Hotpoint Aquarius WD640 Front Load...
My 8.5 kg top loader fuzzy logic turbo drum keeps leaking and also has started to refill about a 1/4 of the drum when it finishes a cycle what is the problem
the problem could be that the water sensor is not giving the controller the right signal, you need to unplug the machine take the back off and look for a small 5mm pipe leading upwards, take it off and blow gently into it you should hear a click and one when you let the air out that means that the place you took it from is blocked with soap goo, unblock it with a pipe cleaner of meatal rod and replace the rubber pipe and try to run the machine again eric
Jan 14, 2013 | LG Washing Machines
My pasquini livia machine is leaking from the base of the steam wand. Perhaps it is a gasket how do you replace these?
You have to take apart the system for changing the gaskets.If you are not a technical savvy don't try for it.Here is the parts diagram for your machine.Many of my fixya customers took apart the system to change the valve and they suffered a lot to fix it again back.All the best.
1 Boiler end gasket 11 Expanse Valve 21 Group gasket 2 Heating element 12 Drain 22 Refill solenoid 3 Gasket for above 13 Pressurestat 23 Group touch pad 4 Steam + water valve 14 Main switch 24 Drip tray grill 5 Pop off valve 15 Group 25 Water flow meter 6 Bleed valve 16 Group solenoid 26 Drip tray 7 Water level Probe 17 Group handle 27 Basket 8 Auto refill relay effect 18 Filter basket single 28 Steam-water valve knob 9 Heater exchanger injector 19 Plastic gasket 29 Manual refill valve 10 Heat wand 20 Site glass 30 Shower screen
the gasket look like this.I will cost around 12$.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Dec 29, 2010 | Pasquini Livietta Espresso Machine
How do descale this product sarco magic delux
Hi Read the bottom for programing the water hardness, Very Important!
1. To decalcify your boiler, remove your water tank and fill it with hot water (100 to 120 degrees). Open a pack of decalcifier and mix into the water tank. Place the tank back on the machine, then turn the machine on. 2. Open the steam knob and run approximately eight ounces of solution into a spare container. Turn the machine off and let set about 10 to 15 minutes. It is very important that the machine does not remain on to heat the boiler anymore than necessary. 3. Repeat step #2 for your type of machine. Do this until you have consumed the entire water tank of solution (approximately four to five cycles) . 4.Remove water tank and rinse it with fresh water. 5. Refill the water tank with fresh water and place it back on the machine. 6. Repeat step #2 to rinse the machine, only this time use the entire water tank at one time, and there is not need to let it set. Done refill your tank and you are ready to go. To clear the descale message, push and hold the steam button for 5 to 10 seconds. It will clear.
Feb 11, 2010 | Saeco Magic De Luxe Espresso Machine
Washing machine refills after spin cycle
Can you hear the pump running if not the machine may be syphoning out, if the outlet is into the down pipe too far this can cause it to syphon. The outlet should only be into it by about 6". The machine will fill with more water on the rince than the wash cycle that will cause the problem. If you can hear the pump running the machine mite be over filling there may a blockage in the presure system if you take the lid off (making sure the powers turned off) you will find a round switch with a thin hose comming off it tace the hose and you should find a small bottle this may be blocked. Hope this helps you.
Dec 22, 2008 | Washing Machines
sounds bad contacts in timer replacement only fix no repair to timers
Nov 20, 2008 | Kenmore 98702 Stacked Washer/Dryer
Rinse cycle won't stop
Start rinsing again, when the water comes out, take off the water tank and let the machine go to it stop.
/Mirran
Aug 21, 2008 | Saeco Incanto Classic Espresso Machine
Electrolux EW1200i Front Load Washer / Dryer Logo
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
