Telefunken analogue color TV model MP-A2055VT-H to connect up digital decoder set-top box. The TV only has an RF input. no other plugs. Searched all 80 channels and I cannot find an AV channel on the Telefunken to receive the digital decode. How is AV input to his set accomplished?
  • 1 more comment
  • The Reverend Sep 14, 2008
    The TV only has an RF input. No other input plugs. Just the antenna plug. Searched all 80 channels and I cannot find an AV channel on the Telefunken to receive the digital decode. There does not appear to be a channel 0 as the selector goes straight from 80 to "1".
    The TV only has an RF input. No other input plugs. Just the antenna plug. Searched all 80 channels and I cannot find an AV channel on the Telefunken to receive the digital decode. There is no channel "0" as the selector goes straight from 80 to "1". The decoder box (Conia CSTB12) outputs CVBS and the TV accepts it. Loop through terrestrial antenna works perfectly.
    How is AV input to his set accomplished so that I can receive digital TV ?
  • The Reverend Sep 15, 2008
    I have an analogue TV set in another room which is set up for digital TV in exactly the same way and it works perfectly.
    How is AV input to this set accomplished so that I can receive digital TV through the decoder?
    Sergeant:
    Champion:
  • 331 Answers
Why dont you scna through your channels
the analog way that is
try to tune manually..................
Posted on Sep 15, 2008
    Brigadier General:
  • 6,966 Answers
The simplest solution would probably be the use of an RF Modulator. Feed the RF Mod with the A/V signals from the Conia CSTB12, set it to transmit on Ch 3 or 4, tune the Telefunken to either channel.
In most Telefunken TVs we have worked on, the A/V INput/OUTput would be on the SCART connectors as shown below.
To my understanding, a Conia CSTB12 as sold in Australia has a composite RCA (yellow) Video OUTput and L/R White/Red audio OUTputs. What would be needed would be a A/V signal to SCART adapter/converter.
If your Conia CSTB12 has an S-Video, then this may be used.
If your Conia CSTB12 has an HDMI, then something like this may be used.
Incidentally, should you be interested, there are comparable receivers to a Conia CSTB12 that has SCART OUTputs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 14, 2008
  • Louie  Role
    Louie Role Sep 16, 2008
    Hi again,
    Any updates?
  • 10,594 Answers
As you said, its an analog model tv so it doesn't have Audio-Video connectors to hook up set top box.
Sorry.
  • Shahid Electronics
    Shahid Electronics Sep 15, 2008
    You can watch digital TV by purchsing new TV.
    Master:
  • 505 Answers
The av channel is 0 and then you need to search on channel 0 as i mean tune into the channel
as you would tune into network channel for an rf connection tipe
    Genius:
  • 1,847 Answers
You have to change the port at the back of the TV. shift to another input.
  • Legin Varghese
    Legin Varghese Sep 14, 2008
    Try the input where you connect your dvd port colored Red White and Yellow.
I have a Toshiba older TV that doesn't have HD digital converter box I bought a leaf ultimate antenna do I still need to use the converter box with this new antenna
if the tv does not have a built in hd digital tuner you need a Hd digital converter to analogue converter. What you need to be careful about is the available inputs on the TV if it only has AV in then you need a converter that transmits out RCA video or an analogue tv channel on RF the tv can tune into. Some of the new converters have HDMI out so if TV does not have HDMI input it won't connect. The antenna would go into the converter. Not sure how much signal you need you may need an rf amplifier if the signal is poor in your area.
Jun 01, 2015 | Toshiba Televison & Video
Connecting Digital Decoder to Analogue TV.
Sep 14, 2008 | Televison & Video
How do I connect my TEVLON hdd dvd to strong decoder
why would you want to connect a hdd dvd to the strong decoder. Wouldn't you connect it to a television via the hdd dvd av output into the av input of the tv and then switch the telivision on input source to AV1 .
You did not mention the model number of the strong decoder but is this a digital tv to Analogue TV decoder.?
you might also have HDMI output and HDMI input on the devices .
That would be better to use if it exists. If you only have one AV input on the TV use a AV switch box and switch between the decoder and the HDD dvd device using
Jan 24, 2015 | Televison & Video
AV1 input question
The TV probably defaults to the RF channels. If it is an analogue only tuner model then it will go to the last used/programmed RF channel.
Sep 04, 2014 | Televison & Video
How to connect HDMI set top box to analogue VCR and then to Digital tv to record
Most set top boxes with HDMI also have a yellow video out and white audio out for connection to a VCR or DVD recorder. Connect these two RCA cables to the VCR's yellow and white INPUTS for recording. Set the VCR to LINE input. For VCR playback, connect yellow video and white audio OUTS from VCR to your TV's yellow and white INPUTS. Select this input on the TV set.
Feb 13, 2012 | Sanyo Televison & Video
How do I connect the set top box to analogue television
What type of set top box? What outputs are available on the box and what inputs are on the TV?
For a basic OTA digital to analog converter, you put the antenna coaxial cable to the antenna in of the box. Then either connect the coax out to the TV's antenna in (set the tv and the box to Channel 3 or 4) or connect the composite out to the composite in of the TV (set the TV to the AV source).
For a set top box that has a composite out and a TV that only has a coaxial input, you need to add a RF modulator. Something like this: http://www.radioshack.com/product/index.jsp?productId=2103095 . If you have a composite input on the TV, use the composite cable directly; the modulator will decrease the signal strength.
There are other converters for component out to composite video. See http://www.svideo.com/ypbpr2svideo.html . Going from a digital source (HDMI) to analog can be done but the resulting signal is poor compared to the original. Also DHCP content will not be transferred. See http://www.gefen.com/gefentv/gtvproduct.jsp?prod_id=5280 for an example.
I hope this helps. Please add a comment with the specifics of your set top box and tv for the best choice for your situation.
Jun 29, 2011 | Televison & Video
Just installed a sky magic eye to my digital tv upstairs, works perfect. however I have now lost all my digital channels!!
Hi
If you have installed a sky magic eye, i am assuming you have taken a sky feed from the RF outlet of the back of the sky box to view sky in another room, if this is the case, this is an analogue feed which you would have to tune in manually to the second tv, this would suggest that you havent lost the digital signal you just have you second tv selected on analogue. On the assumption your system is connected like the following;
Sky box connections
Main aerial input
sky sat input
rf out to second tv
Reagrds
TechSupp12
Dec 12, 2010 | Televison & Video
Can you tell me how to tune in a channel when ppreparing to use a freeview box on a onyx sw 1536 ld
Unless you've got an "expensive" Freeview box that modulates its output on to the RF (Aerial) connector then you can't. Most Freeview boxes have 2 aerial connectors - 1 IN from the Aerial itself and 1 OUT to connect to the TV - BUT this is ONLY a PASS-THROUGH connection. This means that the digital Freeview signal which is decoded from the aerial signals is NOT output on the OUT connector and sent down the co-axial cable to your TV. Only the "old" ANALOGUE (not Freeview NON DIGITAL) comes down that co-ax. What you should do is connect the Freeview box to your TV with a SCART cable via the SCART connectors on both. You need to select the AV input on the TV using the remote.
Even if you do have an "expensive" box that does modulate the digital decoded programmes and output these of the RF OUT connector, you should still use a SCART cable as the picture produced will be far better
Hope this helps
Jul 06, 2010 | Televison & Video
Recorder has stopped decoding SD digital TV but analogue TV is OK
Dry joint - faulty capacitor on the PC board of the decoder. Found by wiggling the components and resoldering
Feb 07, 2010 | Panasonic Televison & Video
Awa dvd recorder dr711 can this be connected to a set top box
If it's like the DR620 it will only receive analogue from the TV aerial. I connect the AV out connections on my set box to the inlet AV on the recorder and watch and record through the recorder's "rear AV input" selection.
Jun 16, 2009 | Durabrand DVD-1002 DVD Player
Televison & Video Logo
548 people viewed this question
Top Televison & Video Experts
