Question about Hotpoint FFM90 Bottom Freezer Refrigerator
FFM90 The freezer part ios in alarm, showing an internal temp of -4C. The fridge section is working OK. Any solutions welcome. There was some ice in the bottom of the freezer, but the door was closed properly.
  • France Matt Sep 14, 2008
    Hi abhishek33,
    Thanks for your help. Could you re-detail how to check for malfunctions, as these do not appear to be in your original message.
    many thanks
  • Anonymous Sep 14, 2008
    My Freezer working fine but the Refrigerator section is not cooling at all. I try shutting of for a day and restart still no change. any tip will help. Thx
    Genius:
  • 1,239 Answers
Hi The limit switch is found only on frost-free refrigerators and freezers. Its function is to keep the defrost heating element from exceeding certain set temperatures. If a refrigerator has lots of frost in the freezer compartment, the problem may be the limit switch. However, other components -- the evaporator fan, the defrost timer, and the defrost heater -- can cause the same problem. Check these for malfunctions, as detailed below. If these parts are in working condition, the problem is most likely in the limit switch. Don't try to fix the limit switch yourself; call a professional service person for replacement.
Posted on Sep 14, 2008
  • ABHISHEK.C
    ABHISHEK.C Sep 14, 2008
    hi
    The thermostat control is usually mounted inside the refrigerator. Its visible control knob is turned to regulate the refrigerator/freezer temperature. The workability of this control can be tested in various ways, depending on the problem. To test the thermostat control:
    Step 1:
    If the compressor runs all the time, turn the control knob to the OFF position. If the compressor still runs, unplug the unit, then pull off the control knob and remove the screws holding the thermostat in place. Pull out the thermostat and remove either the red or the blue wire from its terminal. Plug in the unit. If the compressor doesn't run, the thermostat is faulty. Replace it with a new thermostat.
    Step 2:
    If the compressor runs after the wire is removed from its terminal, there is probably a short circuit somewhere in the unit's wiring. In this case, don't try to fix the problem yourself; call a professional service person.
    Step 3:
    If the refrigerator or freezer runs but the box doesn't cool, unplug the unit and remove the thermostat with a screwdriver. Disconnect both wires from the thermostat. Tape the ends of the wires together with electrical tape, and plug in the appliance. If the refrigerator starts and runs normally, the thermostat is faulty. Replace it with a new one of the same type. Connect the new thermostat the same way the old one was connected.
    Step 4: If the freezer compartment is normal but the refrigerator box doesn't cool, set the dials that control both compartments to mid-range. Remove these knobs (they're usually friction-fit). Then unscrew the temperature control housing; you'll see an air duct near the control. Replace the knob on the freezer thermostat and turn the control to the OFF position. Open the refrigerator door and look closely at the air duct. If this duct doesn't open wider in about ten minutes, the control is faulty. Replace the control with a new one of the same type. Connect the new control the same way the old one was connected.
  • ABHISHEK.C
    hi
    Step 1:
    Step 2:
    Step 3:
My whirlpool frost free fridge freezer's alarm keeps going off, ice-cream doesn't freeze?
Check condenser is clean, fans working, thermostat set correctly, try to check internal temp with digital thermometer
May 17, 2012 | Refrigerators
The fridge alarm will not stop. The fridge compartment is not cold and the freezer is just freezing. Since the problem started, have the fridge turned off for 3 days. Defrosted the freezer, turned it...
this alarm is activate if the temp. of the fridge rises and because the freezer section is full of ice form thats why affect the circulation of cold air. try to check the defrost timer if yuor unit have or heater if working if dont have defrost timer or heater try to lessen the setting of your themostat to cut of unit after reaching desired temp. or conduct weekly defrost manually.
Feb 12, 2011 | Fisher and Paykel Active Smart E522B...
My fridge-freezer (FFM90) has ice forming in the bottom of the freezer section under the last drawer. Why is that and what can I do?
This is due to excessive condensation and in bottom freezers due to proximity of the compressor.There is some residual water falling on to the drawers which forms the ice and this must be prevented. make sure that the frozen foods that was stocked did not loose water into the bottom till we can suspect the freezer. Also frequent opening of the freezer will allow for condensation whicj must be wiped out at intervals.
This can prevent some ice formation and also check if there is leak from the evaporator trays to the freezer during defrosting.
Sep 29, 2010 | Hotpoint FFM90 Bottom Freezer Refrigerator
What temp should my freezer be , also the fan in the top of the fridge stated making a noise when it stopped or started its cycle sounded like something was catching on the fans blades , then it stopped...
I like 0 to 10 Deg. F in the freezer.
As for the Fan. yes it could be ice or the fan blade hiting the shroud, sometimes the fan blade moves on the shaft and starts hiting the shroud.
Jan 11, 2010 | Hotpoint FFM90 Bottom Freezer Refrigerator
Hotpiont ffm90 fridge not chilling
hi if the freezer appears to work and the fridge if warm,the problem is that the freezer is over frozen and blocking the vents which send cold air into the fridge when required,and the noise is the fan hitting the the ice build up,defrost (switch off)your applinace for at least 36 hours then switch back on,you will then find after the freezer reaches -12 the fridge will then start to go cold.
Mar 09, 2009 | Hotpoint FFM90 Bottom Freezer Refrigerator
Fridge is not cooling
if you found the coil iced up then there is a defrost problem check thethermodisc and defrost control board if you know the heater is ok
Jul 09, 2008 | Hotpoint FFM90 Bottom Freezer Refrigerator
Whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted
whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted. the temp display on freezer shows - - flashing
May 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Open Questions:
See all Hotpoint FFM90 Bottom Freezer Refrigerator Questions
Hotpoint FFM90 Bottom Freezer Refrigerator Logo
376 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Gil Shultz
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
