Question about Mitsubishi VS-50605 50" Rear Projection Television
What is wrong and how much is it going to cost?
When i turn on my tv it is all scrambled for about 5 to 10 mins, then it starts working. Then after about 1 min it starts getting scrambled every 10 secs until the screen goes crazy and starts bouncing around.
    President:
  • 3,130 Answers
It sounds like the Picture in Picture PC Board. Its a little stand up type board that has a bunch of small capacitors on it and it goes bad just the way you descrbed cause its clipping the sync out of the video. I dont was told it wasent available anymore and there was a kit available to jump out the board on ebay somewhere. If you know electronics then you should have no problem locating and possibly getting a part from a shop that may still have one BUT if you dont know the insides of the TV set get a pro to assist you as theres a lot of voltage kickin around inside of a set even when its unpluged. Good Luck
Posted on May 30, 2006
Hdtv
I am not a TV man. For mine I turned it off, un-plugged power cable. held the "ON" switch down for 5 min, to dissipate the current in the capacitors. then re-plugged the TV and it working fine. I am not a TV repairman. Big Al
Apr 19, 2014 | Dynex 32 in. LCD Flat-Panel HDTV
Fuzzy/Scramble screen when first turned on.
check solder joints on top of screen some screens were sub contracted to a chineese company called chi mai and had inherant defects
Nov 30, 2012 | Samsung LNT5265FX 52 in. LCD Television
Flashes to scramble with loud high frequency noise no green tint
this sounds very much like either the lamps are going or the cooling system in the set is gone bad and its over heating. either way it's going to cost you a few bucks to get it fixed.
May 04, 2010 | Olevia LT42HVi 42 in. LCD Television
TV scrambles with LOUD buzzing and then turns off
There is a part inside the TV that needs to be replaced. If the TV is 2 years old, then the manufacture warranty is over. If you have an extended warranty, you can get the TV replaced. Otherwise, you're only hope is to call Memorex to see if the problem is a known issue with your model which could mean they're willing to do something for you even though the TV is out of warranty.
The biggest problem with their TVs is part availability. Under their warranty, most TVs are simply replaced not repaired, so they don't have many parts available for purchase. Then there is the fact that even if you can purchase the needed part, the cost of the part combined with having a TV repair guy install it for you would exceed the cost of a new 19" TV since prices have fallen so much in the last 13 months.
Don't bother taking the TV to get it "looked at" because all of the repair shops will charge you a diagnostic fee just to determine the problem. This fee ranges from $50 to $120. Since you already know the total cost of repair will exceed the cost of a replacement TV, why spend money that can go toward that purchase?
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today!
Please post a comment if you need additional assistance so that I can help you further.
Feb 07, 2010 | Televison & Video
Picture is scrambled when first turned on
connect a dvd up,and see if you still have the problem with the dvd.i thank you have a proplem with your cable or antenna.
Aug 19, 2009 | Toshiba Televison & Video
Red to pink screen after 5-10 minutes of play....
This is not the tube, it's most likely the colour controller and system function ic has gotten scrambled, taking this to a tech to re program should not cost more than about $150 AU
Feb 09, 2008 | RCA TruFlat 27F520T 27" TV
1/3 of picture becomes partially scrambled
sounds like you have a frame fold-over fault, does banging the tv have any effect (slightly bang the set on the sides), if it does then its more than likely a dry joint, check all around the frame output chip, hope this is of some help to you
Jun 02, 2007 | Sony KV-35S26 35" TV
Scrambling for first 15 mins
That is the exact problem I am currently having with my toshiba 50 in. I did some reading and it sounds like there is a temperature drift across one of the capacitors on the board and it takes longer and longer to warm up. Havent fixed it yet...
Mar 18, 2007 | Toshiba TP50H50 50" Rear Projection...
TV scrambles
Sounds like from what your describing, a horizontal sync problem and there are a few capacitors in this model that does cause that. If your not a tech this is something you should mess with as the way to trouble shoot this problem would be by using a scjhemetic, a isolation transformer and an ocilliscope. its a possiblity that you could also have a tune rproblem thats giving the sync separator circuit a weak sync pulse from the video its putting out. Good Luck
Jul 31, 2006 | Philips Magnavox MS2530C 25" TV
Mitsubishi VS-50605 50" Rear Projection Television Logo
56 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
