Question about Fujitsu Siemens SCALEO 600 (FSP:83C005617) PC Desktop
SCALEO 600 P253
Last night my Scaleo hang and I had to re-boot by pressing down the power switch (which I have done many times earlier).
But when trying to boot up again, I don’t hear any “post” beep or see any thing on the screen. But I can hear en se it lights up as “normal” during boot and can hear hard drive or fan spinning, though a bit different sound!!
I’m not sure what kind of bios I have, because I can’t se anything on the screen. Because of that I’m unsure on how to read the “none” beep when starting up?
Anyone having the same experience, or any idea on how to identify this problem?
  • pvestland Sep 14, 2008
    I have tried to unplug several times. I even had it unplugged during the night, but still the same.
    You wrote: ...Connecting power outlet far from....!??
    Can't follow your thoughts on that one!?? My voltage is as it should be!
  • Nyman2 Sep 21, 2008
    I´ve got the same problem - though my 600 began doing this occasionally some weeks back, but could still be started after a few attempts. Now, it´s completely dead, just the HDD and CPU fan starts up, no "beep". Following another lead, I changed the CR2032 battery on the motherboard. Did not fix my problem. I´ve also measured the 5 volt and 12 volt signals powering the disk units, all seems OK.
I had the issue. Bought second hand motherboard on ebay and it fixed the problem. Apparently its a common issue with the motherboards used in the Scaleo 600
Posted on Dec 14, 2008
Vdbfbxb gkjvbwpifbvjmbhdj yd k sbsdkd
Posted on Oct 12, 2008
  • 75 Answers
Try to unplug the pc then try to connect it to other power outlet far from the original outlet from which you unplug... hope it will help
Posted on Sep 14, 2008
  • Jasper Garin
    Jasper Garin Sep 14, 2008
    try to connect the pc unit into other room,and try to test it! because in some cases the outlet in w/c you plugin the pc got the problem. if the problem still exist it is in the connection between monitor and videocard of the pc
Seimans scaleo will not turn off unless i turn off at power switch whenon i get nothing
try to remove unwated application starts with windw or at startup.
it will help you.
Nov 21, 2013 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
I have a Scaleo 600 which has been difficult to switch on for some time. I have been getting it to switch on ok provided I had switched the unit off on the rear panel when I shut down in the normal way....
Apr 05, 2011 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
I can't find a driver for my grafique cart of siemens fujitsu scaleo 600 thank's for help :)
on this page
type scaleo 600 for searh
you will be redirected to drivers download page
Feb 22, 2011 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
I want to download sound drivers for my fujitsu siemens scaleo 600
on this page
type sclaleo 600 for searh
you will
be redirected
Jan 09, 2011 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
Fujitsu siemens scaleo 600 desktop just keeps shutting down any ideas
1) Bad Power Supply. Power Supply has a weak voltage power rail.
Electrolytic Capacitors are breaking down inside the Power Supply.
The capacitors build up a charge long enough to work briefly, then break down.
2) Electrolytic Capacitors on the motherboard are breaking down. Specifically the one's used in the motherboard Voltage Regulator Circuit.
B) Visually identifying bad capacitors,
C) Video showing what happens with bad capacitors (Electrolytic) in the motherboard Voltage Regulator Circuit (Starts at 0:04)
Await your further diagnoses.
May 23, 2010 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
Ich habe keinen Audiotreiber mehr auf meinem Computer Fujitsu Siemens Scaleo 600
The German download page is found here
Fill in the field: Bitte geben Sie die Serien-/Identnummer des Gerätes oder den Produktnamen ein: "Scaleo 600"
Then open Audio, look up in the manual of your Scaleo 600 wich audio
chipset your motherboard has onboard to download the the correct drivers.
Note: Use the Fiujitsu Siemens site with Internet Explorer because it does not work very well with Firefox and next time putt your question here in English, you'll get more help in this way.
Jan 08, 2010 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
Need driver for scaleo 600 network adapter,don't recognize,or find any adapter for network,i use windows 7.please help me,is very important
you can download it from here instal it and check in device manager if is properly instaled(working).
Dec 14, 2009 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
Fujitsu Siemens Scaleo 600. No power to processor.
Probably a PSU failure, although it could just be your power switch. Try shorting the power switch connections on the motherboard, if that doesn't work, replace the PSU with a standard ATX PSU. They're relatively cheap.
Oct 06, 2009 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
Scaleo 600
Are you still having the same problem?
On a computer an amber light is usually a "busy" light from when the hard drive is being accessed.
Nov 03, 2007 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
Fujitsu Siemens SCALEO 600 (FSP:83C005617) PC Desktop Logo
431 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
