Question about Video Game Consoles & Games
Boot i want to make boot from my generic usb hub from removable disk or memory card.my windows xp full version is in my memory card.so i want setup from memory card.But it cannot making boot.Plz give me the solutions
    Problem Solver:
  • 7 Answers
Turn on pc...immediately press n hold down delete key on keyboard...BIOS opens....navigate to boot configuration menu....select the order of the boot devices as per ur choice...ie...ur memory card as first boot device...save and exit....restart pc with the memory card connected....it'll boot..
Posted on Sep 14, 2008
Blue creen with blinking cursor
you can do a clean install from your usb. i use this setup for all my flash drive boots.
WinSetupFromUSB - Install Windows XP from USB Flash Drive
This guide will show you, how to use WinSetupFromUSB to create a bootable USB Flash Drive including all Windows source files, plus the following installation of Windows XP. Compare to the different USB_Multiboot versions, WinSetupFromUSB comes with a Graphical User Interface (GUI) and is in my opinion easier to use.
Here you can get the latest version of the program and you will also find many detailed informations about WinSetupFromUSB.
I've tested this guide with a 32-bit version of Windows XP and a 64-bit version of Windows Vista and it worked flawlessly.
Prerequisites:
All you need is:
a USB Flash Drive with at least 1GB of storage
the original Windows XP Setup CD
WinSetupFromUSB
If you use nLite to slim down your version of Windows XP, please keep the following in mind:
DO NOT remove "Manual Install and Upgrade"
under Operating System Options!
I also recommend to integrate Service Pack 3 into your Windows XP source files.
1. Preparations
Download and install WinSetupFromUSB. Default installation path is C:\WinSetupFromUSB.
Create a new folder with the name WINXPCD in the root directory of drive C:\ and copy all files from your Windows XP Setup CD into this folder. Depending on your version of Windows XP, the content of C:\WINXPCD should look approximately like this:
Content of WINXPCD
The following files will show you, which Service Pack is already integrated into your CD:
WIN51IC.SP1, Sevice Pack 1
WIN51IC.SP2, Sevice Pack 2
WIN51IC.SP3, Sevice Pack 3
2. Start WinSetupFromUSB
Connect the USB Flash Drive to your PC and start WinSetupFromUSB. It should show up under USB Disk Selection :
WinSetupFromUSB - main window
3. Select your Source Path
Click on Browse under Windows 2000/XP/2003 Source and navigate to the folder with your Windows XP Source Files. It should be C:\WINXPCD:
Browse to Folder
Click OK and C:\WINXPCD should show up under Windows 2000/XP/2003 Source :
WinSetupFromUSB - source path
4. Format USB Flash Drive
PeToUSB or HP Format Tool are used to format the USB Flash Drive. There is no need to download these programs seperately as they are already included in WinSetupFromUSB.
USB Flash Drives up to 2GB should be formatted with PeToUSB in FAT16, USB Flash Drives with 4GB or more with HP Format Tool in FAT32.
I will use PeToUSB to format my Kingston Data Traveler with 2GB.
In the main window of WinSetupFromUSB click PeToUSB under Format target using to start the program. The USB Flash Drive should show up under Destination Drive. Check USB Removable, Enable Disk Format and Quick Format. Uncheck Enable File Copy under File Copy Options :
PeToUSB
Click Start and answer the following two questions "Continue?" with Yes.
All existing volumes and data will be lost!
If everything goes well, the message "Operation Completed Successfully!" should appear. Click OK and close PeToUSB.
The process with HP Format Tool is similar.
5. Copy Windows XP Source Files
To start the process of copying the Windows XP source files to the USB Flash Drive, click GO in the main window of WinSetupFromUSB. Depending on the write speed of your USB Flash drive it may take a while to copy all files.
WinSetupFromUSB - file copy
At the end the following notice about the Windows installation process should be displayed:
WinSetupFromUSB - notice
Click OK and close WinSetupFromUSB with EXIT.
6. Windows Installation - Part 1
Connect the USB Flash Drive to your PC and turn on the computer. Press ESC at the boot screen and you will be able to select the USB Flash Drive as your boot device from the boot menu.
The ESC key is used by ASUS for the Eee PC series.
Other manufacturers may use other keys, e.g. F8 or F12.
After booting from USB Flash Drive, the following menu should be displayed:
Windows XP/2000/2003 Setup - First and Second parts
Press Enter or wait 10 seconds to get to the next menu:
First part of Windows XP Home Edition setup
Second part of XP Home Edition setup+Start Windows for first time
First part of Windows XP Home Edition setup is already selected. Press Enter or wait 10 seconds to start the Text mode part of setup. During this part you can create, delete and format partitions and finally the setup files are copied to your hard disk. At the end the system will restart automatically.
7. Windows Installation - Part 2
After restart, boot the PC again from your USB Flash Drive. The same menu should be displayed:
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to start the GUI mode part of setup. During this part you will be asked for your product key, timezone, usernames and other necessary informations. At the end the system will restart automatically.
8. Windows Installation - Part 3
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to Start Windows for the first time. The Windows installation process will be finished and finally the Windows Desktop will appear.
DO NOT disconnect the USB Flash Drive too early!
At next startup you can boot into Windows from your hard disk.
Notes:
After successsful installation, the following boot menu will always be displayed during startup:
Please select the operating system to start:
Microsoft Windows XP Home Edition
USB Repair NOT to Start Microsoft Windows XP Home Edition
If you don't plan to use the repair option and want to boot directly into windows, you have to do the following:
Open the file boot.ini in the root directory of drive C:\ with Notepad:
[Boot Loader]timeout=30
Default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS
[Operating Systems]
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(1)partition(1)WINDOWS="USB Repair NOT to Start Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
Delete the following line:
DO NOT delete the wrong line!
Your computer may not boot the next time!
Save changes to the file.
At next startup the boot menu will not be displayed.
If you want to keep the repair option, you can reduce the time to display the operating system options from 30 to 5 seconds:
[Boot Loader]
timeout=5
At next startup the boot menu will be displayed only 5 seconds.
gd luck
Mar 09, 2014 | Computers & Internet
NTLDR compressed on a Compaq Presario SR105CL cant enter bios to set to boot
Step 1:
Which operating system ?
Computer is booting from a non-bootable source. Computer hard disk drive is not properly setup in BIOS. Corrupt NTLDR and NTDETECT.COM file. Misconfiguration with the boot.ini file. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT.32 New hard disk drive being added. Corrupt boot sector / master boot record. Seriously corrupted version of Windows 2000 or Windows XP. Loose or Faulty IDE/EIDE hard disk drive cable. Failing to enable USB keyboard support in the BIOS. Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD ROM First verify that no Floppy Diskette or CD is in the computer, unless you are attempting to boot from a diskette. b> Note: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any card reader or flash reader make sure that no memory stick is inside the computer. Additionally disconnect all USB drives, cameras, ipods, iphones, etc. from the computer. If you are attempting to BOOT from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files or is corrupt. If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive. Second, when the computer is booting you should receive the below prompt. Press any key to boot from the CD
Mar 10, 2013 | Compaq Presario sr1055cl PC Desktop
My toshiba cannot boot through USB. it dispalays "windows missing" yet the flash disk has got a windows xp setup
Your flash drive only has the setup program not the actual OS as it would be on your hard drive.
The fact that it won't boot through your USB is because there is no OS on your laptop with the required drivers for your USB and other hardware, for that.
You need to have OS installed on your hard drive to be able to run all the peripheral hardware, else nothing happens.
Please install the apropriate Operating System (OS) on your hard drive, and voila!!! magic happens after that.
Cheers, Peter
Feb 21, 2013 | Toshiba Satellite A135-S4477 Laptop AC...
Down laod xp recovery disk
If you're running Windows XP and Windows crashes or becomes unusable, you may have to run a Windows XP recovery setup disk to make your computer usable again. When purchased, many computers don't come with a Windows XP recovery setup disk, but you can download one for free from Microsoft. The Windows XP recovery setup disk holds the computer software and files that you need to assist you in rebuilding your operating system.
Place a formatted floppy disk in your floppy disk drive. You will need six formatted floppy disks. Visit Microsoft's Download Center and download the version of the setup disk for your version of Windows (see links in Resources). http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=E8FE6868-6E4F-471C-B455-BD5AFEE126D8 Home Edition http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=8030 Professional Edition set up disks for floppy http://www.download3000.com/download_17676.html XP Recovery CD Maker Windows XP Home Edition and Windows XP Professional Edition have their own recovery setup disks and you must use the correct disk for your version of Windows. Click "Download" and then "Save." Find your floppy drive or optical media drive on the menu and click "OK." If Windows isn't functioning at all, you will have to perform these actions from a working PC. Remove the last floppy disk when the Windows XP recovery disk download is complete and place it in the computer on which you need to use it. Shut down your computer and then turn it back on. If your computer prompts you to boot from the disk, press Enter. If it doesn't, you'll have to go into your BIOS to set the computer to boot first from your disk drive. When your computer boots from disk it will automatically start running the Windows XP recovery setup disk from which you can then set up Windows XP. Hope this helps.
Jan 30, 2012 | Microsoft Computers & Internet
Ntlrd missing xp tablet on my hp tc1000 with no cd rom
Causes
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
  10. Failing to enable USB keyboard support in the BIOS.
Solutions
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette or CD is in the computer, unless you are attempting to boot from a diskette.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files or is corrupt.
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Note: If you are not receiving the above message and your BIOS boot options are set properly it's also possible that your CD-ROM drive may not be booting from the CD-ROM properly. Verify the jumpers are set properly on the CD-ROM drive.
Verify that your computer hard disk drive is properly setup in the CMOS setup. Improper settings can cause this error.
Corrupt NTLDR or NTDETECT.COM file
Windows 2000 users
Windows XP users
Sep 24, 2011 | Computers & Internet
NTLDR is missing
this is a very common Issue:NTLDR is Missing.
Related errors:
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Causes:
  3. Corrupt NTLDR and/or NTDETECT.COM file.
Windows XP users
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
    copy e:\i386\ntldr c:\
    copy e:\i386\ntdetect.com c:\
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
hope that it will be help full
thanks
Oct 27, 2010 | Dell Computers & Internet
Hi.I want to format my hard disk and install windows xp home edition. But it end up by saying it cant detect my hard disk. im using MSI km400 with sata.
Windows XP comes in 2 'flavors', one being the OEM or 'Full' version, and the other is the 'upgrade' version. The Full version will setup and format the hard disk, applying the boot track. The Upgrade version expects to see the boot track there, and will not proceed further. You may need a utility like Seagate Diskwizard to setup the hard drive for installation. That program can be downloaded from Seagate's website.
Apr 02, 2010 | MSI KM4M-V KM400 SocketA 333FSB 2DDR...
Memory card write protect?
i had same problem..couldn't solve it with tape over the lock switch and many other ways.. so i purchased a usb card reader (about $5 max) and now it works fine!...just make sure the lock is off!
Jun 02, 2009 | SanDisk 1GB microSD Memory Card
Reboot
To Reboot a computer is to turn it off, wait at least 20 seconds, then turn it back on.
A.If you're thinking of Reboot, as to reinstall the Operating System, you use a Restoration Disk, (sometimes listed as Recovery Disk), insert it in your CD/DVD drive, and restart your computer.
(Just press the CTRL, ALT and Delete keys AT THE SAME TIME.
Not shouting. Windows XP and Windows Vista are examples of an Operating System)
B.If you're trying to install an Operating System, from a CD disk that you bought, I suggest you go into BIOS Setup, and in Boot Order, change the first boot device to CDROM. Insert the CD disk in your CD/DVD drive, and restart the computer.
If you buy a Full Installation CD disk, as listed above, you have to change the Boot Order.
For example:
1.You have Windows XP on your computer now. It has problems, and doesn't work correctly. Instead of getting the Restoration Disk from your computer manufacturer, you decided to just buy a genuine copy of Windows XP, and install it. (This is a Full Installation Disk)
The Windows XP you have installed now, will not let the one you bought install over it, by just putting the disk in the drive. Change the first boot device, in Boot Order to CDROM, and it will. The Windows XP you have now, will 'see' the Windows XP you're trying to install, as just the same version. You have to install a better version of Windows, in order for it to write over what is installed.
Such as Windows Vista.
2.You have Windows Vista on your computer, and are not happy with it. You would like to put Windows XP on instead. Windows XP is considered a lesser version, and Vista won't let it write over it.
Go to BIOS Setup, change the first boot device in Boot Order, to CDROM, and it will.
May 10, 2009 | Compaq Presario R3000 Notebook
Microsoft Windows 98 for PC Problem is there any software driver for pen drive so that my win98 o.s. computer can detect any type or companies pen drive plz tell me
wow, the 90's are a calling... sure their is a roumor of a usb pen driver for win 98' ....
Windows 98, especially in it's second edition (also known as Windows 98SE), handles USB fairly well, however there are no generic/universal mass storage device drivers preinstalled in the operating system, so you will need to install some additional drivers for it. Some manufacturers do however, provide the Windows 98 drivers on CD, others have them available to download, and others simply do not have them available at all!!!!!!!
generic Windows 98SE USB mass storage device drivers:
http://www.technical-assistance.co.uk/drivers/nusb31e.exe
instructions?? :
  1. Download the exe file to the desktop
  2. Remove ALL drivers for USB flash drives in Device Manager
  3. Remove ALL drivers for any USB 2.0 controllers (many have an uninstall option)
  4. Remove ALL unknown devices from Device Manager (*carefull)
  5. Run the exe file you downloaded, and follow the instructions, rebooting after installation
  6. When the computer boots up again, it may detect new USB 2.0 controllers, in which case you may need to reboot again
as always good luck! now im going to go back to my windows 95 and play Bioshock on full graphics!! excuse me = )
Oct 13, 2007 | Microsoft Windows 98 for PC
Video Game Consoles & Games Logo
100 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
