Question about Sony VAIO RB30C (VGCRB30) PC Desktop
Dvd will not play movies
Hi there my vgc-rb30 will not play dvds. It does play cd on it but once I try to play a dvd it wont. I sounds like it wants to start but it does not. I tried the spray cleaner, the cd cleaning kit but nothing helps. I thought I had removed the windvd so I downloaded it again but nothing. You can hear it is turning inside and the dvd is in a diffrent position. Please help
  • viva0105 Sep 14, 2008
    Thanx AndrewWro for the quick response. Unfortunately no the system does not display anything. Also I have to admit I have not only used factory dvds but also self made ones.I am sorry for the dumb question but what is a drive and where do I get one. I purchased the product at Conns and would rather not go there again. Also I am trying a cd on the dvd slot and it does function am also trying a dvd again I hear it spinning but you also hear like a needle for lack of a better word kind of scratching is that normal? Neighbor advised to remove the outer box of the server good idea or not for someone not to familiar with this?
  • viva0105 Sep 17, 2008
    Once again thanx AndrewWro I am going to try this myself. I"ll open it and take it from there. You never know I might just be the the computer repair wiz or "GURU" I thought I could be. Once again Thank you. I"ll post if I succeded
    Scholar:
  • 32 Answers
I'm assuming the system says that there is no disc and you've tried factory DVDs (self made ones can have intermittent results on different burners).
If that is the case, this is probably a problem with the drive's DVD laser. There are two different lasers in most (probably all) combo drives. One for CDs and one for DVDs. You need a new drive.
Posted on Sep 14, 2008
  • AndrewWro Sep 15, 2008
    The drive is a the CD/DVD drive in your computer. I found a computer like yours on Amazon and is says you have a Dual Layer multi-format CD/DVD drive.
    This part is really easy to replace but I get the impression that you might be uncomfortable doing it. I would recommend that you bring the computer to a shop. It shouldn't cost too much (less than $100 and more like $50-$75).
    If you want to do it your self, figure out how to open your case. Typically in modern computers, one side will slide off towards the back and then the front bezel (all the plastic) on the front will pop off. You don't always have to remove the front but sometimes you do. You will see the DVD drive exposed.
    That a look at the drive (where you put the DVD). It will have a power connector (red,black, yellow, white wires - or some combination) and one other cable. If it is flat and about 2" wide, this is PATA. If it is about 1/2 wide it is SATA. Given the age of you computer, I'd bet money on PATA. Newegg is a reputable computer parts retailer just order this drive at $27 and swap it with your old one (typically 4 screws but sometimes special attachments). If it's SATA just do a search for DVD SATA and look for a drive with high marks that has a + and a - in front of RW. Good Luck.
What graphics card can be installed in a Sony VAIO VGC-RB30 using Windows 7?
Hi Jose,
Asus ATI Radeon HD6450 Silence 1GB DDR3 VGA/DVI/HDMI Low Profile PCI-Express Video Card. Is one of the compatible cards you can put in the system and can be sourced from
http://www.memorygiant.com/video-card/sony-vaio-vgc-vgcrb30-vgcrb30c/
Regards
Proton
Oct 02, 2012 | Sony VAIO RB30C (VGCRB30) PC Desktop
Toshoba tv/dvd combo. won't play many dvd's. makes clicking sound as it tries to load movie?
Dear Lesley!
It looks, like your DVD lens might get contaminated with dust and/or dirt, which is being picked up off DVDs. Let's try to load music CD, instead or DVD. If it loads well, I will suggest, that your DVD player is at fault and you must give up using it. External basic DVD players are quite inexpensive and easy to connect to your TV. But: if no CD, nor DVD load, the solution might be much simpler: use lens cleaner CD with brushes. good ones might even have a special fluid, which applied to brushes(alcohol based). Just load it into your TV's player and follow audible directions. After couple attempts, your lens should be clean enough to play DVDs. Please, don't try to use any "ear swabs", instead. The lengths is not long enough, plus it may damage load mechanism or get stuck inside. I've seen such a cases lately.
Good luck,
Thank you,
Alex.
Dec 15, 2011 | Toshiba 32CV100U 32 in. TV/DVD Combo
My (HL-DT -ST dvd ram-GSA-H22N) Dvd burner wont
www.ashampoo.com go to this site and download and install this burning program and try it, un install the other burning program first, let me know how it went
Mar 25, 2010 | Computers & Internet
DVD-player won't play DVDs, but reads CD/DVDs for programs fine..
Could be a codec problem, try downloading the codecs from codecs.com
download the codec pack for your OS.
Jun 26, 2009 | Computers & Internet
Pioneer dvd r/rw wont play a dvd
If your computer recognizes a disc in the drive and operates normally, Id assume you would need a DVD player or codec to be able to actually watch the DVD. PowerDVD rings a bell.
Have you tired that? I know Windows Media Player by default wont let you watch a movie without first downloading a codec.
Mar 19, 2009 | Pioneer (DVR-K15 BLACK) DVD RW Dual Layer...
DVDs won't play or burn
try to open your desktop and clean the ide or sata cable for your dvd-rom and put it back.
Jan 24, 2009 | Sony VAIO VGC-RB40 PC Desktop
Dvds
your dvd software is capable of playing the type of dvd movie that you have. download and install vlc player and you should be able to play DVDs through that computer.
http://www.filehippo.com/download_vlc/
thanks! :)
Oct 04, 2008 | Computers & Internet
My dvd driive in my computer won't play dvds
Do you mean DVD movies wont play? If so you need to install DVD software. Use Google to search for some or buy some e.g. PowerDVD.
Sep 17, 2008 | E-Machines T3256 PC Desktop
Xbox 360 wont play hd movies
Hi you have to buy a HD DVD player add on for your 360 to play HD DVDs if you go to game or gamestation you will get one there very cheap as HD DVDs are no longer released
Jun 27, 2008 | Microsoft Xbox 360 Console
Sony VAIO RB30C (VGCRB30) PC Desktop Logo
125 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
