Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Problems turning my tv on, need to try several times
I have a Grand Wega and it worked great, but as of lately, most times I have to try several times before it will finally turn on. When new, the TV would make a normal buzzing sound , then the power LED would blink a few times, then video/audio would appear. Now,after the buzzing sound the LED will blink and sometimes fail to deliver video/sound;sequence will repeat a few times and with luck I will be able to get it to turn on. When unlucky, the LED will flash yellow, then turn red and blink five times in a row then a long pause , then red again. After a couple of this RED led cycles it will go solid red and stay off. Sometimes it takes a few of these cycles and even unplugging of the set for a few minutes before I get it to operate. Once it´s on, it will stay on with no problems.
  • Anonymous May 12, 2008
    I must try over and over again in order to get my Polariod TV to come on. When it is on things are fine. I have only had the TV for a few months.
  • Anonymous Sep 23, 2008
    My TV wont turn on any more and the LCD light keeps blinking
I just recently had the same problem and finally my set would no longer turn on. I replaced the projector lamp and now my set works. However, when it first comes on, it only stays on for about 2 minutes and then goes off. After another minute, it comes back on and works fine from then on. I don't believe this double power up can be any good for the lamp, but I don't know if the problem is the lamp or the set. These lamps run on about 65 volts, but require a short blast from 5000 volt source to fire up. At $200.00 a lamp, I don't want to go buy another!
Posted on Jun 06, 2006
    Scholar:
  • 137 Answers
Hello Mel1,
To make a long story short.....You have a bad lamp. That is your only problem. If you hear that buzzing sound, that is the ballast trying to kick start the lamp. Just change the lamp and all is good. Make sure you get the correct lamp...and you wont end up kicking out money for another lamp in 2 months.
Best regards
circuitcity
Posted on Jul 08, 2008
Sony Grand WEGA KF50WE610 tv will not turn off
Problems that do not happen all the time are hard to find--2 things: if set blinks the red light try to count the blinks--usually that is an error code.
Also this set if it does for the most part work should have an error buffer.
With the set turned off and using the Sony remote:
Display
5
Volume down
power
If it has this when it comes on there will be a box in the middle of the screen with several items listed---all must have a zero to the right of them---if one has a number(any number) it means it has detected that error that number of times.
Let me know what you find
Apr 11, 2012 | Sony Grand WEGA KF50WE610 50" Rear...
Problem with Sony Grand Wega TV
This could be due to bad capacitors in the sweep supply, a bad High Voltage block, a bad regulator.
Jul 06, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Recently changed my bulb for my Wega LCD KF-42SX300U TV. Since then it is turning itself off, with no particular pattern. It can come straight on and last for a few seconds, or last the entire evening....
This is a classic case of a faulty lamp(even though it is new). Possible that it is a ballast(lamp power sply) problem but it is more likely that the lamp doesnt quite meet the required specifications. Your lamp may be a Non-OEM or a refurb. You should try to get it exchanged with the vendor you bought it from.
justlamps.com is a great source for bulbs.
good luck
Jan 07, 2010 | Sony Grand WEGA KF-42SX300 42" LCD TV
Picture getting dimmer (?)
Hi, yes it`s time to replace the lamp, and remember to turn maxxed out brightness to normal once you replace the lamp :) good luck, video-tek
Jun 29, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony FD Trinitron KV-40XBR800 wont turn on
30 YR SERVICE TECH.
YOUR UNIT IS EXPERIENCING A POWER SUPPLY FAILURE.(INTERNALLY)
TAKE TO A SONY AUTHORIZED SERVICER.
Jan 12, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv turns off and on
The first time my lamp needed replaced, the red light came on as well. This time my tv did the same thing, but after talking to my tv repair man he thought it was the lamp. He said that if you use your tv often then the lamp probaly needs to be changed after two or three years. I replacedmy bulb and it corrected the problem and I MUCH BETTER PICTURE.
Dec 29, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
TV doesnot Turn ON
sounds like you need a new light bulb
May 08, 2008 | Sony XL-2100U Projector Lamp for...
Sony KDF-55XS955 Rear Projection TV
This is a problem with the AKB circuit. Are you comfortable working with TV circuits? Can you solder? If so, please update this and I'll look up the most likely parts late today and post them for you.
Dan
Mar 18, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
What the @*#@*#
The 4 blink fault code means one of the fans is faulty or the H4 module in the TV.
Jun 07, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
461 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
