Question about Roper RT21AKXKQ Top Freezer Refrigerator
Freezer not working but fridge is
I opened my freezer today and everything was defrosting. The fridge is working fine. I thought maybe did not shut properly so made sure it was closed and 8 hours later it is still not freezing. The fan is working but the air is refrigerator. HELP!!!
  • 750 Answers
Tratra72
You said,
1.Try unplugging the fridge for 5 minutes and then restarting it! This may reset the system!
2.If the freezer is so full that the rear vents are blocked then this may happen. Because the fridge and the freezer share the air!
3. If not then the freezer and the fridge have different controls and the freezer control if faulty!
then you need service. ur site has good service companies in your are for our customers!
Bless You,
please give me a good rating before you sign off!
thank you
Posted on Sep 14, 2008
  • Carol
    Carol Dec 22, 2016
    Will try your advice. Thank you God bless you too
THE FRIDGE STOPPED WORKING BUT THE FREEZER CONTINUES TO WORK AS NORMAL
Posted on Oct 15, 2010
Hello - came back from holiday and my maytag gz2626gekb had defrosted and all food was lost, we thought that one of us had left the door open by mistake so switched it off at the mains then back on and...
If the entire freezer section had warmed up i would be looking at either the condenser fan motor (located behind fridge in compressor area) or the relay and overload assembly (attached to the compressor) as your most likely suspects.
Usually if the relay and overload fail the compressor simply will not run or you will hear an audible buzz and click sound from the component.
The condenser fan motor should be running whenever the refrigerator is on. If the fan is stalling it will cause the compressor to overheat and shut off.
Now if some of the freezer items were still frozen, you may have a defrost issue causing a restriction in air flow within your unit. Your most likely culprit for this would be the defrost control board located in the refrigerator compartment top right corner above your control housing. Part number 61005988.
Jun 13, 2010 | Maytag ZigZagW / B Side by Side...
FREEZER IS FINE. FRIDGE STILL NOT COOLING
it sounds like your circulation fan is not working. it is located in the freezer compartment in front of the evaporator or very close to it. you should hear running either all the time except in the defrost cycle. on some models the fan will shut down when you open the freezer door and restart when you close it. if the fan is OK you have a problem in your defrost circuit. probably a bad heating element or a bad defrost cutout switch or bad connections in the freezer compartment. sometimes the defrost timer can go bad but not often. I have found in my experience that the problem is usually the other two components I mentioned or bad connections.
Mar 13, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Ge freezer works fine but the fridge wont cool.you
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 14, 2009 | Refrigerators
Admrial LTF2112AR fridge not cooling
Sep 12, 2009 | Refrigerators
Fridge won't stay cold
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
OR
Sep 08, 2009 | Refrigerators
Fridge not cold as should be
OR.
Aug 29, 2009 | KitchenAid Architect KBRA20ERSS Bottom...
Zanussi fridge compartment has stopped cooling but freezer is ok
OR.
Aug 24, 2009 | Zanussi ZI918 / 12K Bottom Freezer...
Freezer works fine but refrigerator is not cold
OR
Aug 18, 2009 | KitchenAid Refrigerators
GE Fridge/freezer not working properly!
hey ur thermister has worn out may be due to the power surge when the power came back at that time so change the thermistor then check it out.........
Sep 09, 2008 | Refrigerators
Freezer working fine, but no cold air to fridge
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control unit
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 29, 2008 | Whirlpool GB9SHKXL Bottom Freezer...
Roper RT21AKXKQ Top Freezer Refrigerator Logo
5,235 people viewed this question
Top Roper Refrigerators Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Mike Cairns
Mike Cairns
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
