Question about Canon PowerShot A640 Digital Camera
Falsh Problem with Power Shot a640
When i keep my camera in auto mode and take the pictures with flash light on , the pictures turn out dark . Pl help me out
I had the exact same problem. You'll need to send it back to Canon. It'll cost you $87-94, but they'll clean it up, get the flash working, and make it new again. It's a good camera worth getting fixed.
Posted on Oct 11, 2008
  • 50 Answers
I think (as some pros say!) it is natural. if you are in dark place and there is some object near your camera, if you use flash, it will light and others go dark! to solve the problom turn the flash off (if possible) or go to night mode or turn slow sync. on (from menu). I hope this helps...
Posted on Oct 31, 2008
  • shyamww Jun 22, 2011
    Operate on the PROGRAM mode (P) and with the slow sync on , everything seem to be fine.
4 Suggested Answers
dg9dotorg
  • 151 Answers
SOURCE: In AUTO mode, pictures are all dark!
Yes you definitely can,
Turn on the camera.
The mode dial can be turned to any setting.
2. Press the button for longer than 5
seconds.
The message “Reset settings to default?” appears on the
LCD monitor.
3. Select [OK] using the left and right
buttons, then press the button.
The normal screen resumes when resetting is complete.
To cancel resetting, select [Cancel] instead of [OK].
Posted on Dec 09, 2007
SOURCE: digital rebel XS - flash delay
Your camera is set to syncronize the flash on the second shutter curtain. Check your custom functions/custom settings, and disable it. It's called "second curtain sync" or "2nd curtain sync". Nikon call it "Rear Sync".
Hope this helps,
/Chris
Posted on Jan 19, 2009
  • 11967 Answers
SOURCE: same as posted - picture is way too dark when using flash. Help!
Try a camera reset. Go into the setup menu and scroll to "reset" and follow the on-screen instructions.
Posted on Sep 23, 2009
I have canon a640 camera. I am getting problem regarding taking pictures as the flash is not working. I have tried it on Auto mode, Portrate, landscape and others the result is same. Please help me in...
make sure the dial at the top of the camera is set to AUTO or the green camera icon. When you are in position to take a picture, press the left button on the circle pad on the back of the camera; it should look like a SQUIGGLY ARROW this is the sign for flash. that button should turn it on, off, at automatic based on the current lighting.
Hope this helps!
Mar 14, 2011 | Canon PowerShot A640 Digital Camera
How to switch off the flash in Canon Power Shot A510
in the take picture mode, press the button that has an image of the flash on it (the top of the circle) on the right, and keep pressing it until you've selected the image that shows the flash crossed out.
Mar 27, 2010 | Canon PowerShot A510 Digital Camera
Picture in dark condition.
It may be that your subject is too far away. The range of your internal flash is 12 feet if you have the ISO set for Auto, or 23 feet if the ISO is set for to 1000. You may get Normal 0   Normal 0 acceptable results with the ISO set to 1000 without the flash, but you should put the camera on a tripod (the shutter speed could be as low as 1/8 of a second) and use set the zoom for wide angle (the lens lets in almost 8 times the light as it does in maximum telephoto.)
I hope this helps,
Mike
Jan 03, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
How do I turn off flash?
I think the power shot (A series) has the most user friendly interface! Just press up button to select auto/forced/off mode for flash. I hope this helps...
Aug 23, 2008 | Canon PowerShot A640 Digital Camera
No flash in "P" mode
In all of modes you can use "up" key to toggle between "always on", "auto"  and "off" mode for flash. (in some mode there is only auto and off.) also the flash light icon on top right of screen shows th status of flash. I hope this helps...
Aug 02, 2008 | Canon PowerShot A640 Digital Camera
Canon A640 flash problem
I sent my camera into Canon for repair. They said the flash was malfunctioning, and there was something wrong with the flash exposure control. The repair cost about $87. It took approximately 10 days from the time I sent the camera in until the time I got it back.
Jul 11, 2008 | Canon PowerShot A640 Digital Camera
Blurry pictures
Most probably you have incorrectly set your camera to a Camera Record mode other than Auto.
If there is not enough light and you are trying to photograph the scene without flash, (eg. by setting your camera mode to a mode that is programmed not to use flash) then the camera has to compensate for the missing light by keeping its shutter open for a longer period of time so as enough light comes into its sensor.
If your hand shakes during that time, you get blurry images.
Check your camera settings. The Twilight scene mode gives you slower shutter speeds to capture dark, night scenes, but you need to stabilize the camera on a tripod or something, depending on the level of light of the scene you want to photograph. The Twilight Portrait, on the other hand, is the same as Twilight with the addition of flash is used to illuminate a person or foreground subject as well as capturing a night background. This mode also keeps a long shutter time for capturing the night background.
For taking pictures of people, I would suggest you use Auto or Portrait mode where the camera will automatically use fast shutter speeds and flash (if dark).
Hope this helps.
May 22, 2008 | Sony Cyber-Shot DSC-P92 Digital Camera
Sony cyber shot camera 2004
Perhaps you have set the camera to a record mode other than Auto. Twilight mode for example, does not activate flash so as to set the camera on a tripod and shoot dark landscapes.
Check your camera record mode, and use auto or portrait mode, which they usually activate flash when there is not enough light.
Hope this helps.
May 15, 2008 | Sony Cyber-Shot DSC-P92 Digital Camera
Falsh!
Here is a link to the manufacturers link to the manual. Click the one called Operating Instructions. http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSCP41&LOC=3 Look on page 29, this will tell you how to operate the flash. Hope this helps.
Aug 27, 2007 | Sony Cyber-Shot DSC-P41 Digital Camera
Canon PowerShot A640 Digital Camera Logo
380 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
