Question about TruTech PLV16320 Television
Mod. # PLV16190 can you help me fiend the LP1619 main board ,PLV1619-02-01 , C33-PL1619w101, MP000806A thanks tec. H.A.O*Su.
Main board def. for this mod. plv16190 sea bd # in subject
  • osullivan503 May 11, 2010
    i will give you All the # on this main board plv1619] [ plv1619-02-01 ] C33-pl1619w101 ] MP000806A ]i found 2 ic bad on this board L.#u1 and u4 i need to replace this board thanks you i can never fiend part s for this mod. tv. in jamaica oun. power supply parts like reg.ic opt ic. regopt ic cap. resestor deiode ect.
Can you help me on this tv trutec tv. modle # pLv 16190 , i neen main board plv1619 / plv1619-02-01 or ic Lockation # IC U1 and L. # Ic u4 [ 1517aw ic ] z1010a ic ] please e-mail me ,if you can fiend parts # , for me see; service manual for parts # / thanks H A O*Sullivan
Posted on Oct 11, 2008
    Champion:
  • 367 Answers
What is wrong with your TV?Red standby light is lit,but the TV doesn't turn on?Open the back of the TV,and look at the can shaped items on the board that the power cord is hooked to,as well as the board that goes to the screen that lights up the bulbs.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.Please let me know if you have any questions.Thank You very much!
Tyler
Posted on Sep 29, 2008
Truetech PLV16190 dead no power
Check and replace its main power regulator board.
Aug 31, 2012 | TruTech PLV16190 Television
Working on mod. gss20iepd frig replaced def heater and over temp therm ohm thermistors, seem o.k. coil still frosting, before i replace control board, what puts frig in def cycle?
everything goes through the board,when you pull out the board you'll see a gray connector with three prongs,that's the defrost connector on the board
Oct 20, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
60SDX88B. No video, No sound. DP06 Protection
not a solution but i have a 50gx30b doing something similar, no picture no sound, 3 green leds are lit up on the main board and then one red led lit up also on main board, front panel red led stays on for about 30 -50 seconds and then it all shuts off, I then have to unplug and replug to get the same results.
Mar 03, 2010 | Hitachi 60SDX88B 60" Rear Projection...
Kitchen aid dishwasher with blinking lights. Manual says to call service tech.
and so you did / im a service tec . need more info th help . like mod and ( kitchen -aid ) . try looking in the front toe panel for a tec sheet this will tell you about the blinking lights and what the mean . get back with me if you need more help //mm fed back pls .
Dec 17, 2009 | Refrigerators
Th42px80u- tv wont come on and red light flashes 10 times
Here are all the Panasonic blink codes.
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
Oct 21, 2009 | Panasonic Viera TH-42PX80U Plasma TV
TRUTECH PLV16190 Capacitor replacement what type
I take it there is a bad capacitor on the inverter?The board that powers up the lights for the screen.Any bad ones on the power board as well?The two PLV16190 I fixed had bad capacitors on both boards.Usually the tops,and or bottoms bulge out when they go bad.When you do go to replace them,you can get ones with a higher value on both specs,but not lower.For example,if there is a 10V 1000UF,and a 16V 1000 UF,you can replace them both with 16V 1000UF,and it will work perfect.You can also use different heights as well,as long as there is enough room.The type you want are called Aluminum Electrolytic.I hope this helps.If you have any other questions,please let me know.Thank You very much!
Tyler
Feb 23, 2009 | TruTech PLV16190 Television
I have a Truetech PLV16190 Flatscreen. Problem: Screen Black (no picture)but sound work fine. Any solutions for this problem? ralphw4606
Open the back of the TV,and look at the can shaped items called capacitors on the circuit boards.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Feb 18, 2009 | TruTech PLV16190 Television
How can I add stations to the memory of SONY MHC-C33 Shelf system
Download user manual of MHC-C33 from Sony Support and get to know this system properly.
Thank you.
Dec 01, 2008 | Sony LBT-LX50 CD Shelf System
Trutech plv16190 picture going off after 3o minutes
Open the back of the TV,and look at the can shaped items on the boards.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Dec 27, 2007 | TruTech PLV16190 Television
RCA R52WM24
271852 small signal board, 272082 main input, 271866 fav def
Dec 05, 2007 | RCA R52WM24 52" HDTV Projection Television
TruTech PLV16320 Television Logo
222 people viewed this question
Top TruTech Televison & Video Experts
Radames Pagan
Radames Pagan
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
