Question about Sun Solaris 8
Using alternate Ethernet adapter
A lightning strike burnt out the onboard Ethernet adapter so I have added a plug-in adapter. What do I need to do to get the system to recognize the adapter and use it instead of the dead, onboard Ehternet?
I have the knowledge to be able to do that on an Intel PC but need some guidance on doing that on an Ultra 30. Where can I find instructions on how to change BIOS settings on a sparc based system?
Posted on Sep 18, 2008
  • 40 Answers
You should first restart computer, then go to BIOS settings and disable the onboard adapter. Then boot up windows and install drivers for the new adapter and it should work. If that doesn't help, please ask for more help here.
Posted on Sep 15, 2008
I can't get on line via the Ethernet receptacle. I'm using a MSI Ma inboard # K8MM3-V, installed in my Dell Computer. The original Motherboard was struck by lightning a couple years ago and...
Then the onboard Ethernet circuit has also been fried. Go in the BIOS and disable it then install a simple PCI LAN card (that can be bought for less than $15 at every pc shop) to get a new ethernet connection.
Sep 04, 2011 | MSI K8MM3-V Motherboard
When i connect the lan wire my mother board shows lan not connected why/
Either the cable is defective (it has a break inside it so try another one) or the onboard LAN chip was fried by the power surge generated by a lightning strike that came in your vicinity.
That is unfixable, disable the onboard one from the BIOS and install a simple PCI LAN card in its place.
Aug 17, 2011 | Intel D945GCCR Motherboard
Ethernet port not functioning after lifghtening strike
Ethernet port not working after a lightning strike? Then I suggest obtaining an inexpensive Ethernet adapter card, and installing it.
One example of an Ethernet adapter card, (Ethernet Card, Networking Card - Same/same),
The above Ethernet adapter card is a PCI style of adapter card. It plugs into any available PCI expansion slot on the Pavilion a620n's motherboard.
This is an illustration and photo of the Pavilion a620n motherboard from HP Support,
Scrolling to the middle of the page shows first the illustration, then the photo.
In the motherboard photo the three white long expansion slots on the bottom of the motherboard, are the PCI slots.
On this page is information on how to open the computer case, and replace, or install an Ethernet Card,
Click on ~ HP Pavilion PCs - Upgrading and Servicing Guide
This is a PDF file. You may have to allow up to 30 seconds to see the first page, and additional time for the file to fully download.
[Removing and Installing an Add-In Card is information on how to remove, and install an Ethernet Card. An Ethernet adapter card is an Add-In Card]
For additional questions, and/or clarification on what has been stated please post in a Comment.
Apr 30, 2011 | HP Pavilion a620n (PC028A) PC Desktop
Can the Targus APK01 adaptor be used with a 3-prong US device?
If you try using a three prong plug in this you don't get the security of having the item grounded. Having the ground plug helps with situations like a lightning strike, etc. You would be using at your own risk.
Jan 04, 2011 | Targus WORLD POWER TRAVEL ADAPTER (Retail)...
Getting a no network adapter detected message after a nearby lightning strike. No Network folder listed under device manage either. Windows ex sp2
this network cards are the most commun problme on computer if the card is not detected on device manager remplace it
they cost about 10 to 15 dlls
May 04, 2010 | Dell Ethernet Card Network Adapter
Flashing stike laptop won't start
lightning strike usually is battery indicator try charging/replacing battery also battery might be dead and ac adapter broken
Jul 06, 2009 | Computers & Internet
Xbox 360 ethernet port -not working usb??
no the xbox doesnt work with the usb to ethernet adapter. i thought it would work also. and it turns out it does. this would be because you have to install the device drive for it to work, and you cant do this on your xbox. but radioshack sells ethernet ports for about $6 if you know how to switch them out.
Jul 25, 2008 | Microsoft Xbox 360 Console
Home networking.
do you have a pci network adapter intalled with the proper drivers ? did you plug in ethernet cable directly into current pci lan card it will be located on lower part of back of computer? this will eliminate the problems with the router just to see if pci lancard is working or not . if the lan card is working unplug cable and plug in router and then try with router plugged in u might need to reset the router in order for it to work with lan card . if ur using and onboard lan eg attached to the motherboard then you must go into computer bios and enable onboard lan and then the ethernet cable should work with no problem good luck i hope this helps you get up and going getback to me if there are future problems.
Jul 01, 2008 | Linksys Wireless-G WRT54G Router
Ethernet NIC card not seen in Network adapter (code 31)
Code 31 means that the device drivers are incorrectly installed.
In order to solve the issue fully, can you please tell me what Operating System you are using.
Jun 19, 2008 | Toshiba A205-S4577 Notebook
Ethernet adapter jack is broken
There are Ethernet to USB adapter such the products shown here. Alternately, you can use a PCMCIA card with Ethernet such as shown here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 13, 2008 | Computers & Internet
Sun Solaris 8 Logo
44 people viewed this question
Top Sun Computers & Internet Experts
Robin Hill
Robin Hill
Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
