Question about Cameras
Film advance lever on petri FT stuck - Cameras
  • Anonymous May 14, 2009
    I can push the film advance lever barely a quarter of the way and it stops. The take-up spool doesn't turn at all when the lever is moved.
4 Suggested Answers
  • 1894 Answers
SOURCE: I have a Pentax and
Never force the advance lever on a camera that is locked. You will only damage more parts, and may render the camera unrepairable. Try moving the speed indicator to different settings. Change the batteries. Jar the camera by hitting it lightly with the palm of your hand. But, never force the advance lever if it is locked and will not move.Click Here for pictures gear.gif
Posted on Aug 31, 2008
voodoomox
  • 1689 Answers
SOURCE: Minolta x370 camera, the shutter
if you are up to repairing the camera yourself, you may want to remove the film first but cutting it from the lock then rewinding it to the tube (make sure you are in a dark room)...
then move to the small article below...
from PointBreak:
The BIG Minolta Shutter Problem Fix Secret EXPOSED!
The Minolta X-Series have been infamous for having their shutters "stuck" and without the film advancing. The LEDS will light up correctly but the film just wouldn't plain advance when you hit the shutter release button. Frustrating to say the least..but alas..alll is not lost. This has been a very common problem and I'll tell you why.
The X-Series, and other possible makers, contains a/an electrolytical capacitor with 1000 hrs of working voltage. When the capacitor reaches its limit it may fail (bulge/corrode). Whether this was an intentional design concept by Minolta is unknown..yeah right! Basically these capacitors hold a small magnetic charge and that when you hit the shutter release it reverses polarity and allows the film to expose, advance, blah, blah, blah..
OK! What I'm going to explain here will save you anywhere from $10 - $200 (meaning you could buy this info. on Ebay or take your X370 to get fixed at a shop). Vendors on Ebay are hocking this info. from $5 and on up..some are actually bidding on this stuff..DON'T DO IT! They will tell you that it's impossible to locate their "product" which consists of new capacitors and the service/repair manual. Well it took some time and research but I have located everything you need so..
Here it is and ENJOY!
1. Download the X370 manuals from http://www.geocities.com/eskoufos/fmm.html. Cost: FREE!
2. Go to http://www.digikey.com/digihome.html. The part number for the capacitor for the Minolta X370 is: P954-ND (Panasonic P/N is ECE-A0GKS221). The actual spec. on the capacitor is: 4v 220uF @ 85 deg. C(entigrade) (6.3X5X2.5 mm).Cost: $7.00 (includes S/H, min. order was 10 pieces @ $2.00 and they charge $5 for S/H)
3. Unscrew the bottom of the camera (4 little screws) and locate the bad capacitor. It's probablu bulging or leaking.
4. If you don't have one, you need a soldering pen and some standard electrical solder. (Go to Radio Shack or any Hardware store)
5. Remove the old capacitor and then solder on a new capacitor. That's it!
if you have other question just lemme know.
Posted on Sep 19, 2008
  • 11967 Answers
SOURCE: Everything seems to function well,
If the lever won't advance even when there is no film in the camera, then I would say there is a problem. (p.s. You haven't told us the make and model)
Posted on May 30, 2011
Film advance lever stuck
Do you have a film in the camera? If so is it all exposed? Best thing to do is press the film rewind button and try the lever at the same time - this will eliminate stuck film issues as it removes film tension from the system. If this does not solve the issue then you need someone to have a closer look.
Feb 07, 2014 | Canon F1-N 35mm SLR Camera
The Film advance lever is stuck, how can I fix this?
This camera is 42 years old. Sounds like a mechanical problem, but I doubt you are going to find any company or individual who knows how to fix it, or can find parts for it, if needed.
Suggest you keep this museum piece as a conversation starter, and invest in a newer model.
If you want to stay with Canon, the Elan 7N and Rebel T2 film cameras are 'only' about 13 years old. I see Elans on eBay starting at $70 (body only).
Jul 04, 2017 | Photography
Film advance lever stuck. Changed batteries but can not move the film advance lever.
Hi fmerlin, If you have film in it you may need to remove the film to free up the advance lever. Go into a closet cover under a blanket etc. Also, Walmart and most drug stores have a big change bag that they could do it for you. With film out it still will not advance it will need to go to Nikon.
Aug 18, 2010 | Nikonos V 35mm Point and Shoot Camera
I have an Canon AE-1 and the film advance lever will not advance the film, the lever goes half way. The shutter will not release. Thanks
The film is either at the end or stuck. The shutter will not release unless the film advance lever has gone all the way and back.
Make a note of the frame counter. Rewind the film and remove it from the camera (When you feel the film to come loose from the receiving spool, stop rewinding to prevent the end of the film to disappear inside the can. This way you can reload it if it was stuck in the middle.) If the film was completely exposed, take it to be developed.
With the empty camera, try to advance the lever and release the shutter. If this works, the problem was the film and not the camera. Everything is fine. If the problem persists, take it to be repaired.
If the film was stuck in the middle, load it again into the camera. With the lense cap on (preferably in a dark room or similar) 'shoot' as many 'empty' frames as you had on the counter plus two more. Finish the film and develop the pictures.
If the film stucks again at the same place, rewind it and develop normally. It was a bad film.
Hope this helped you to solve the problem.
Nov 16, 2009 | Canon EOS-AE-1 35mm SLR Camera
Film Advance lever stuck
When you press on the shutter release does it "click"? A few hard taps with the end of your finger onto the shutter reelase button may unjam it if it is stuck...
Jun 15, 2009 | Minolta X-370S 35mm SLR Camera
Film advance lever.
Do you press the shutter button to release the lever for the next photo? That's how you advance the film from the exposure to light, when first insterting the film.
Sep 16, 2008 | Nikon FE 35mm SLR Camera
Film advance
I removed the advance lever cover as suggested and tightened the screw. This did not solve the issue. However, I then realized the film rewind button on the bottom of the camera was stuck on the "in" position. I could not get it to release which meant I could not advance the film lever to free up the shutter. To solve this issue I removed the bottom cover from the camera (taking out the 3 small screws) and then pulled the advance lever button all the way to the right. This released the button that had been stuck in and allowed me to advance the film lever properly again and take more pictures. Hope this helps!
Jul 14, 2008 | Vivitar V3800N Zoom 35mm SLR Camera
Leica m2 film advance lever is stuck
mandie22,
on this model two strokes are needed to fully advance the film and to set the counter to the next #,
so advance the lever, bring it back and advance again.
Jun 03, 2008 | Photography
Film advance lever and shutter release button are "stuck"
No, it is not the battery. My guess is that the film leader did not stay in the take-up spool and is now bunched up around it. Try rewinding the film carefully as you normally would but remember that you are only rewinding a small portion of the length. You can even just open the film door and start over. You will only loose 3 or 4 frames on the roll.
Apr 27, 2008 | Nikon FE 35mm SLR Camera
Help, my camera wont take pictures
Did you try pushing the shutter button? It may already be wound. Otherwise, try pushing the rewind button in and holding it while you wind the lever. Now, it MAY be that your at the end of the roll-what does your counter say?
Mar 31, 2007 | Nikon FM10 35mm SLR Camera
Cameras Logo
192 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
