Question about Samsung ML 1750 Laser Printer
Both lights flashing
Samsung says take it to the repair shop is it possible to fix myself tried new cartridge
  • Anonymous Jan 16, 2008
    both the light is blinking continue
  • docpeewee Aug 01, 2008
    red and yellow light flashing, internal error report
  • 161 Answers
No it is not. Both lights point to a bad fuser unit, a part not replaceable by end users.
Posted on Sep 22, 2007
My samsung plasma tv standby red light keep flashing could not power on, how do i fix it myself. Dube
A flashing red light ciran be a faulty power supply or one of the other boards in your television.If you are unfamiliar with electronic repair,it would be wise to seek the help of an experient technician.
Jan 23, 2018 | Samsung Televison & Video
I have an HP Photosmart 7260 printer that my cousin gave to me used so I have no manual. I've replaced both ink cartridges and am trying to print. When I send the print job, a red light begins to flash...
Can you see any symbol when the red light flashes? or any message pops up on your computer? Since your problem's description isn't very specific, I am unable to assume myself. If cartridges are replaced with new ones and the problem persists, it's possible that there's paper jam or carriage jam or contacts on the printer is bad/dirty. While the machine is On, lift up the front access door and try moving the carriage manually. Please follow this LINK to clean the contacts.
Please post back with more specific details so that I can help you better. Good Luck.
Feb 18, 2011 | HP PhotoSmart 7260 InkJet Printer
My phone samsung s5230 touch system cannot working regularly
If you still have warranty, then take it back and ask for a new one, or for them to repair it. If not then it can be several things that are wrong with it...
1) Digitiser is broken
Fix: take it to a repair shop and have them fit a new digitiser (seeing as though the phone works every now and again, this doesn't seem likely, but it is a possibility)
2) There is a loose cable
Fix: Take it to a repair shop and have them clean all the joints at which the flex cables meet components. (this is a huge possibility this would explain it working every now and again)
3) Phone software is corrupt
Fix: Take it to a repair shop and get them to put new software on it. (This is also a likely contender, as the software may be corrupted slightly and is registering the inputs correctly.)
Basically take it to a repair shop, explain the problem, and they will run suitable diagnostics on the phone.
Jun 09, 2010 | Samsung SGH-S5230 Cell Phone
When should I replace the toner cartridge? I found that red light is flashing( the lower light, totally there are 2 lights: upper one is green now). I don't understand what does it mean.
It mean when your toner is near empty,then red light flashing.tow light is fixed or red mean toner cartridge is empty.must be replace toner cartridge.You buy a new cartridge and put in your printer then printer is OK.
you can also get better idea please read printer user guide.
Mar 04, 2010 | Samsung ML-2240 Laser Printer
Trying to turn on tv and no picture. bought new
Rulds2008 is probably right. I had the same problem, but have no TV repair shop near me. So since I have experience fixing computers, I decided to repair the TV myself. I initially repaired the Lamp, but the TV still flashed all three lights. Called Samsung and they told me that I might need to replace the ballast, but it would be best to bring it to a repair shop. The repair shop offered to come out and look at it for $150 or bring it in for $120, even though they were about 30 mins away. Ordered both parts on www.Samsungparts.com and got them in three days. Still had the three flashing lights. Took apart the entire TV (googled it on youtube) and vacuumed and dusted the TV and took apart the color wheel (about 20-30 mins). It was completed busted. Found out that if the color wheel is broken, it will not send a signal to the ballast to tell it to start up and power the lamp. So if you have replaced the lamp and/ or the ballast and it does not light up, it is more than likely that it is your color wheel (buy it on ebay or amazon, got it in three days versus a 3-4 week back order on company sites). Also, make sure the power switch on back is being pushed upwards and not downwards or the TV also will not start. Total parts cost me ($400) versus having someone else fix it and charge me double with labor and parts. TV is better than ever. Hope this helps.
Sep 29, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
All panel lights flashing. Printer seems to initialize, then reverts to all lights flashing.
hi....take it to a tech to check about the system control chip... the control chip would have gone bad... and they will replace u with a new chip..or else Try manually moving the head carriage back and forth a few times!
Also check, if there isn't some piece of paper lodged inside, if yes try to remove it carefully!..
these are the possible solutions u can try out...
thank u
rate me
May 29, 2009 | Epson Stylus Color 640 InkJet Printer
"Invalid Imaging Unit" after replacing toner cartridge
After 2 years ,surly it need to change some part because of life time of some part that is very tired ,try to show it or take it to samsung service center in your country ,...
Jan 18, 2009 | Samsung CLP-550N Laser Printer
Please help...I can't take any pictures!
Possibility one : lens unit faulty and proper focus is not being achieved camera goes into error mode because of this and then it switches off to prevent further damage.( replace /repair lens unit ) Possibility two: shutter faulty . Lens delivers proper focus but when you try to take picture goes into error mode because shutter not coming on line or malfanctions. ( replace shutter only ).
Apr 17, 2007 | Konica Minolta DiMAGE S414 Digital Camera
Samsung ML 1750 Laser Printer Logo
161 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
Steve Allison
Steve Allison
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
