Question about Hoover Washing Machines
Hoover Gemini remove agitator
I need to remove the agitator to clean underneath.
It does not seem to budge when I try to wriggle it out and I can't see any thing holding it in place.
Any assistance much appreciated.
TIA
Chris
5 Suggested Answers
SOURCE: Now do you remove agitator from washer drum?
There are 4 holes at the base of the agitator. Use a screwdriver to push in at each hole in order to pop the plastic grove that holds it in place. The agitator cap will then pull off to reveal 6 3/8" bolts. Remove these with a socket set and the entire agitator can be lifted to free the garment. To reassemble, position the agitator holes over the holes in the base, reinsert and tighten the bolts, snap the cap back on, and your are ready to go.
Jim
Posted on Jul 12, 2008
abhishek33
  • 1239 Answers
SOURCE: how to remove agitator
hi The washing machine tub, or basket, generally doesn't cause problems. However, at times it may cause damage to the laundry, make a lot of noise, vibrate, or stop completely.
If laundry is torn during the wash cycle, feel around the tub. If you find a rough spot, you may be able to smooth it with an emery board. Sand the spot lightly. If this doesn't work -- or if you have to cut to bare metal to remove the roughness -- the tub should be replaced. In this case, it's probably much wiser to replace the entire washer.
The agitator -- the finned part that fits on the tub shaft -- can also tear laundry if the fins are cracked or broken. You may be able to solve the problem temporarily by pinching off the splinters with pliers and lightly filing the plastic smooth, but this is just a stopgap measure; the agitator should be replaced. Replace a damaged agitator with a new one of the same type. To do this, unscrew the cap on top of the agitator. With the cap off, pull straight up on the agitator; it should lift off. If it doesn't move, rap its side with a hammer. If it still won't lift off, drive wedges under the bottom rim of the agitator to dislodge it. Then set the new agitator into place and replace the agitator cap.
Damage to the snubber, a padlike device sometimes located under the agitator cap, can cause the machine to vibrate excessively. The snubber may have a suspension spring in it. Lift off the agitator cap and examine the snubber. If the spring is broken, or if the pad is visibly worn, replace the entire snubber. Snubbers might also be found at the splash guard at the top of the tub, under the transmission, or as part of the water pump housing. Look around until you see it.
If the machine doesn't have a snubber, listen for noise at the suspension unit between the tub and the machine cabinet. The suspension unit has fins or pads that may need replacement. In some cases, the entire unit may have to be replaced. Another noise point is the basket support nut. Tighten the nut or, if you can't tighten it, replace it.
Posted on Nov 11, 2008
SOURCE: Need to remove agitator as material jammed underneath
remove agitator as material iammed
Posted on Apr 14, 2010
  • 713 Answers
SOURCE: Can't get agitator out of Hoover Gemini 1290
first pull the center of the agitator out and shine a torch down inside . do you see a 10 mm bolt head? if you do, unscrew it then the agitator should lift out. if you dont see a bolt head please reply 4 more help. good luck.
Posted on May 13, 2010
Can you remove the agitator to clean underneath it?
make and model of machine is essential
with simpson, hoover and westinghouse , there is a stud at the bottom of the agitator after you remove the lint filter
the stud is a 10mm and you will need a long extension to get there
when it is loose
the agitator just lifts out
Sep 10, 2017 | Washing Machines
How do I remove the agitator from my Hoover 201M washing machine. It really needs to be cleaned under there with all the muck thats building up. Thanks.
if it is a top loader machine with an agitator that stands up in the center of the tub, try removing the dispenser and lint trap from the center ( normally just a pull up) and right down the bottom there is a 10 or 12 mm bolt that you undo and that allows you to pull the agitator up off the drive shaft
talk with a service agent as to how to get the agitator out or down load a workshop manual from google by typing in --workshop manual for hoover model 201m washing machine -- and if there is a pdf version then down load it
Feb 07, 2016 | Hoover Washing Machines
Hoover UH70935 windtunnel agitator spins like crazy with plate off after cleaning but will not with plate replaced.... what is going on?
If the brush roller was removed, it may have been reinstalled incorrectly, causing it to bind on the bottom plate.
Aug 08, 2014 | Hoover WindTunnel 3 Pro Pet Bagless...
Hoover 500mb washing machine failing to spin.
my does everything but it just wont spin drye
Mar 25, 2012 | Hoover HTC243 Top Load Washer
Can't get agitator out of Hoover Gemini 1290 washing machine ..... How to
May 10, 2010 | Washing Machines
My Hoover 750LB washing machine smells - not the lint filter - how do you remover the agitator to see underneath?
No need!
Put 3 cups of sugar Soap concentrate in machine and fill. Leave 24 hrs and run a wash cycle without clothes.
If this fails....only option is complete strip and clean of innards of the machine,
Oct 24, 2009 | Washing Machines
Can't get agitator off of GE spacemaker model WWP 1180G
There is a bolt, ok. Remove the bolt and lift the agitator by reaching underneath it with both hands on each side and pull it up. If it seems really stuck, apply some WD40 and let it soak a bit before trying to pull it again.
Feb 21, 2009 | GE Spacemaker Washer and Dryer Electric...
Hoover Premier 706 (model A6950) washing machine.When filling water wont shut off.Turn power off water shuts off.If I remove hose from side of bowl and gently blow into it water shuts off.Machine is old...
Inserted flexible piece of thin wire into hose connectioin on outside of bowl and vigoursly wriggled it around - replaced hose and bingo water fills and shuts off and machine operates correctly. Seems like the hose connection was blocked, not a very scientific repair method but seems to have worked. Thanks.
Aug 14, 2008 | Hoover Washing Machines
Washing Machines Logo
42 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
