Question about Kenmore 24032\24036 Top Load Washer
No hot water
The problem I'm having is there is no hot water coming through to the washer. The cold is working fine and everything else seems to be working fine but I'm not getting any hot water in the washer. I've checked the connection from the other end and the water is flowing freely but when I turn it to "hot", nothing goes into the washer. Please help!
  • gannonsfr Dec 10, 2008
    I have the exact same problem with my Roper top loader.
  • 83 Answers
I guess you have check the settings on the machine.
So I am guessing possibly the acuator (electric) that switches the hot water flow on and off and being initally controlled from the timer circuit. Both hot and cold have actuators. These are usually what the flexible hoses screw into. The will have connections on them inside the machine.
You need to have the machine looked at.
If you tamper with or check the wiring yourself, ensure the plug is removed from the powerpoint.
You can still get an electric shock of the neutral wire if it is plugged in, even if the powerpoint is turned off
Posted on Sep 14, 2008
I can't get the cold water to fill the tub/rinse. the hot works.
Your problem is either a clogged COLD fill valve or a bad water fill valve. Turn the water off. Remove the COLD hose from the WASHER. Check the filter screen inside the valve for sediment. If you find sediment,remove the screen and clean it. Replace the screen and turn the water back on. If you do not find sediment on the screen,replace the water valve.
Sep 21, 2009 | Frigidaire FWS1339A Top Load Washer
Mixed Water Fill Causes Issues with Water Pressure
You will have to be specific about what problem the pump is having. It seems to pump ok for everything else. Could the hot solenoid be shorting and sending electricity down the water to bother the pump? Solenoids are not real expensive, try a new one.
Apr 25, 2009 | Kenmore 22422 Top Load Washer
Washing machine won't heat water
it sounds like the hot water supply hose on the back inlet water valve is not opening up,to check it switch the hoses,cold on hot,and hot on cold,put the washer on fill cold,if hot water comes out you know it's the water valve-mike
Mar 21, 2009 | Kenmore 80754 Top Load Stacked Washer /...
Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Hotpoint washer , top load
This sounds like a faulty water valve. Water is coming in the cold water valve when it shouldn't. If the machine has an automatic temp control make sure it is turned off.
Jan 01, 2008 | Hotpoint VBXR1090D Top Load Washer
GE Washer wbsr3140d5ww water problem
Hello Chad
Sounds like the cold water knob or switch is not switching and may be faulty.
I have a problem with my washer
For some reason when I try to start the washer and I have it set to cold it does not work if I put it to hot then its fine
The cold water does work though because if I change the washer to a later cycle cold water comes out just fine.
So it almost seems like its the timer knob
any ideas?
Please remember to leave a rating
Jun 04, 2007 | GE WBSR3140D Top Load Washer
Intermittent hot water valve not opening
problem may be low water pressure. try putting in a y-piece so cold water is supplied to both valves. only effect will be that wash cycle will be a bit longer
Dec 17, 2006 | Miele Novotronic W1918A Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
46 people viewed this question
Sal De
 Brian Main
Brian Main
